Question about Zanussi WJS1397W Front Load Washer / Dryer
Zanussi Washer Drier
The dial clicks round but the letters corresponding the to cycle don't move with it!
We had same problem with same model machine - basically you have to ignore the letters behind the see through plastic window and write new ones around the dial with a permanent marker that you know are correct and correspond to what you want. It's a lot of trial and error - try and go for the simple dryer function first and mark write the corresponding letter against the dial straight away, then work out the distance between each letter on the proper dial and and you should replicate these distances and letters with your pen.
Posted on Aug 14, 2009
Indesit w83 dial just clicks round, is there a reset button some where
Washed any coins lately? I had a front loading washer and when mine did that it was still under warranty so the service came out and pulled a quarter out of the drain trap. If you not sure where that is contact me
Dec 20, 2013 | Indesit W 83
Zanussi zwf1421
Thermostat or heater most likely causes. Does timer button move round without doing anything? Timer knobs on Zanussi notorious for breaking off inside.
Apr 28, 2012 | Zanussi F1245W Front Load Washer
Washer does not progress through cycle
it might be the pressure switch which in part controls the cycles eg when water enters drum air pressure builds up through a tube connected to pressure switch which has electrical contacts.it is round in shape and if is the fault, it has to be replaced. regards
Jul 29, 2009 | Maytag Washing Machines
Washing machine not spinning at the end of cycle
if the dial is moving round as normal and the machine is filling and emptyin change the motor brushes this will cure the problem
Dec 20, 2008 | Hotpoint First Edition FEW12 Front Load...
Unsure how to access drier to put on new drive belt
Here is my own solution...
Disconnect from mains (of course) remove top (2 screws at back near top) Unplug electric connectors (on back panel, top RHS). Make sure note what goes where! Lie unit down on front remove screws (2) holding the drum spindle cover (centre of back) and remove cover pop off the circlip holding drum spindle, and washer unscrew back panel - hex headed screws round outside of back Remove screws at bottom of back panel which screw into the plastic vent housing (3 I think) Lift whole back off. (there's a plastic lip at bottom - need to pull away from this a bit) The drum spindle will be unsupported now, so don't move unit Full access now to drum and motor beneath Get and put on new belt reassemble.
Actually, having got into unit, found could not get belt from local spares shop (it had closed down), so bought new drier!
Dec 15, 2008 | Zanussi TD4212W Electric Dryer
My washer wont spin
on the motor there are what you call carbon brushes.. these wear out over time, this then the motor stop spining check and get back to me . cheers doc
Nov 20, 2007 | Zanussi FS1455W Front Load Washer
Zanussi wdj 1094 washer dryer
possibly the motor brushes are worn, the clicking is the pcb relay changing the motor direction.
May 19, 2007 | Zanussi FJS1225W Front Load Washer
Water leaking and dial spinning
unconnected faults. does water come out of drawer when filling? if so fault is a blockage in hose down to tub from drawer or drawer may need cleaning if fault happenns on rinse. fault on knob is broken inner knob and poss cam as well
Mar 14, 2007 | Zanussi FLA1201W Front Load Washer
Zanussi WJS1397W Front Load Washer / Dryer Logo
113 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
