Question about Kyocera Mita KM-2530 Laser Printer
Our Kyocera KM2530 has previously been set up to scan to three separate pcs on the network. Nothing has changed yet it will now only scan to one. How can I fix this problem?
  • Kevin Cole May 11, 2010
    Something has probably changed on the 2 PC's. If it will scan to one PC, chances are that the Kyocera is ok. It could be anything from a firewall setting to an IP address change. If provided with more info on how the scan has been configured, I could provide better feed back.
  • 622 Answers
The ip address for the other two computers might have changed... you need to go into the scanner via the IP address of the scanner and change the IP address for the scan to pc folders destination list to the new one for both computers... or change the ip address to the pc name... pc name may work... but IP address will...
Posted on Dec 24, 2009
Kyocera mita km2530 paper misfeed jam00
This usually means that no paper has been fed from the paper cassette or the machine was turned off when you had a paper jam.
Remove the paper cassette from the machine and ensure that nothing is stopping the paper from feeding.Also look into where the machine locates in the copier to ensure that no paper is jammed behind the cassette.
The paper feed rollers may need cleaning or replacing.
Jan 03, 2012 | Kyocera Mita KM-2530 Laser Printer
How do i connect to the scanner.I have this connected for the printer,now i need items scanned to send e-mail don't know how to do this
It all depends on how your set up is. If you are connected through USB, you will need to download the twain driver from the Kyocera website. Then you can utilize any scanning program that you wish to collect the document image.
If you are connected through ethernet, it's a little more complicated. The first choice you need to decide is what you want done with the document image after it has been acquired. There are three main choices: Upload to FTP server, Send to a folder on a computer through SMB, or email.
All three of these options are obtained through the Kyocera Command Center software installed on the printer. Point your browser to http://192.168.2.10/ and you can login. If it asks for password, the unit ships with password "admin00", so that should get you in unless someone changed it.
You can adjust the settings through this screen. Head over to the "scan" tab, and you can put in the information for whichever way you want it. If you decide on Email, you will notice at the bottom of the page a link to set up the SMTP options for sending the emails.
Another note with email: you will need to set up a DNS server in the TCP/IP section under "Basic" settings. If you don't have a DNS server on your network, you can utilize universal ones. I recommend using Google's DNS servers (8.8.8.8 & 8.8.4.4)
Sep 21, 2011 | Kyocera FS1128MFP AllInOne Laser Printer
My belkin router will not recognize the LAN connection of three PC. It will accept my laptop using the same Ethernet cables. I have recycled the router and reset my network. Still no connection. We had a...
Did you try direct wiring the other pcs to see if they will connect separately? If they won't then check the network settings on each pc that won't connect. Make sure that the gateway address is the same ip address as the router is.
Did it work before the outage, all of them at once? If so go to the Command Prompt (RUN, type in cmd, enter and a small window will pop up), and where the cursor is blinking type in - ipconfig - (some win versions use winipcfg) , hit ENTER. That will tell you what address are set to. It should say 192.168.xxx.xxx.
Type in - ipconfig /release - ENTER. That will reset the addresses which should now all be zeros.
Now type in - ipconfig /renew - (make sure you have the blank space between the g and the /). This should give you the 192.168.xxx.xxx address for IP if your network settings are set correctly under Network Connections- Properties-TCP/IP
Sometimes under outages you need to reset both the modem, the router and the pcs to acquire the new addresses.
Feb 22, 2011 | Belkin Computers & Internet
How do I change a password for a scanning folder from a networked kyocera KM4050I
browse the ip address, go to basic settings on the menu go to contacts, access your name and change the password then submit
Jan 26, 2010 | Kyocera Copystar CS-1820 Black and White...
What is the code for KM-3035 printer's scanner network card?
Print/Scan System (U) 083H9503 Network Print Controller and Network Scanner
Feb 12, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Cannot setup/connect to Kyocera CS-2050
go to kyocera mita america online. they have all the drivers. you need the KX driver
Jan 21, 2009 | Kyocera CS-2050 Black and White Copier
Kyocera km 2050
The 2050 uses 2 network connections, one for the printer and one for the scanner.
Before I go into any great detail,
Do you have a home network? Are you using a switch?
Are you printing through the network connection or the USB/parallel port?
Are you trying to twain scan? Do you have the software CD for scanning.
If not, you will need to download the drivers from the Kyocera web site.
Mar 08, 2008 | Kyocera Mita KM-5035 Printer
KM-3035 scanning issues
the 30/40/5035 series machines have two network cards in them. One for printing and one for scanning. and they have separate IP numbers also. make sure you have scanfile utility running on your pc or wherever you are sending the files and the folder set up in the utility. then set it up on the scanner network card.. Not the printer.
Oct 15, 2007 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera Mita KM-2530 Laser Printer Logo
1,243 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
