Question about Samsung HLN4365W 43" Rear Projection HDTV-Ready Television
Tv used to make a whining sound when we turned it on, we would turn it off and on a couple of times and then it would be fine. now the tv won't come on at all, it blinks a green light and then shuts down and trys to restart then i get all three lights blinking. i tried replacing the lamp and it did not help so i returned the lamp, i just replaced the color wheel last night and it did not help. can you help? it is a hln4365w1. thanks
  • 261 Answers
Well that humming sound is indeed the color wheel, you say you already replaced it.
The thing is that there are two types of color wheels one with a silver bearing and another one with a gold one, for example if your Tv uses a gold bearing colorwheel and you buy a silver one, it's not going to work, if you still have the orginal colorwheel which i think you did since you replaced it last night, just make sure what color the bearing is. Because the color wheel is the one causing the issues on your TV.
Posted on Jun 30, 2009
1999 Pontiac Sunfire 5 speed won't start. Replaced spark plugs and checked ignition coil (fine). Sounds like it wants to turn over but makes a "whining" noise. Please assist. Thank you!
Is the engine turning over with the key in the start position? If the engine is not spinning over and you hear a whining noise, the starter is not engaging the flywheel. If the engine is turning over with the starter engaged, the engine has most likely jumped time that creates low or no compression which results in the whining noise.
Mar 03, 2015 | Pontiac Cars & Trucks
Whining noise
your color wheel is going out. order a new one and come back to me I will walk you through the process of replacing it
Nov 27, 2013 | Mitsubishi WD-57734 57" HDTV
Starter problems with my starter on a bmw x5. replaced starter and now all I hear is a whine from the starter, but vehicle won't turnover. what could be the problem.
sounds like the bendex in the starter is not kicking in take it to a local auto electrician and get him to check it out
Feb 27, 2013 | 2001 BMW X5 4.4
Screen won't turn on , and now it just makes a loud whining sound .that is coming from this yellow box like thing .
Is this TV a flat screen Sylvania? Does this happen when the TV is off and on standby. If so, give me the model number. I have corrected this problem a time or two...just need some more input. Thanks for listening.
Feb 27, 2013 | Televison & Video
I have a phillips 60 inch hd rear projection television model number 60pw9363, i have recently replaced both convergence and the tv was working perfect for about 6 months, i went to turn on the set and a...
Whining noise sounds like the power supply in the TV ... not putting out the voltage it needs to project the image.... might have to consult with your TV repair
Sep 18, 2009 | Philips 60PW9363 60" Rear Projection...
Dryer wont start
Your motor is bad.
Apr 19, 2009 | Dryers
RCA F32650 production May 2003. Was working fine. Turned it on the next day, got no picture and a high pitched whining noise.  Please let me know what I should do to fix it.
If it weren't for the high pitch whining noise. I would say it probably is an internal fuse inside the chasis. It is rated at 1.5 to 2.0 amps. With the whining noise it sounds like a trouble shooting bench
job. Problems occur when a electrical/electronics device is turned on and turned off. Inrush voltage,
when it is turned on, can go up to three times more than normal. This also happens at turn off. Solid state components usually fail at this time. I don't feel that this is a problem that can be fixed in the home.---BBB
Jan 25, 2009 | RCA F32650 32" TV
Samsung HLN4365W 43" Rear Projection HDTV-Ready Television Logo
174 people viewed this question
Jerry Greenberg
Jerry Greenberg
