Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
Grinding coffee but water not making coffee
Making no coffee - just soughted out ventilate machine is now showing all the right moves giving out hot water from steam maker grinding the coffee beans but doesnt actually make the coffee!?
  • shazadoo7 Jul 01, 2009
    Hi ried that, makes all the right noises displays no coffee beans, the water isnt comming out of the nossles coming out in the drip tray and underneath!
  • bansheracer May 11, 2010
    Hi What happens when you push the pre-grind button but don't put any coffee in (blank shot) and then push the large coffee. Does it brew water?
Check to make sure the quantity button has not been reprogrammed. To do so, push and hold the coffee button until coffee flows through. Also be sure to check the brew-unit. In some cases if the b-unit is plugged, it will not allow water to flow through. Also check to be sure you are not grinding too fine, if coffee is too fine it too will plug the chamber...........Hope it helps.
Steven,
info@northwestkitchenware.com
Posted on Jun 30, 2009
Water pressure too low for coffee making - error Grind is too fine....
maybe the grind is too fine. Too fine will make it harder for water to pump through the coffee.
Jul 27, 2015 | Coffee Makers & Espresso Machines
I have saeco incanto deluxe coffee machine,ventilate msg appears
Check the end of the steam nozzle, make sure it is not blocked. If not then with the knob open for hot water cycle push in on the knob if that works then the tap rod assemble or the steam valve needs to be replaced.
Feb 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
No water dispenses when making coffee, the hot water feature works fine. I have descaled twice
Descaling or boiler problem doesn't seem to be your issue as your single boiler is both used to make hot water and coffee. As the hot water is working fine we should concentrate on the brewer unit blockage ( give it a good clean and remove Brewer screen or screens and un block dirty clogged holes ). Then if problem still exists make sure you are not grinding your coffee too thin ( will cause blockage and machine lockup ) if this is the case. I have also come across customers who for some strange reason turned off their machines before it could finish the coffee dumping cycle and leaving it for a while ( left over coffee goes hard and cloggs ). Hope this helps.
Dec 05, 2009 | Saeco Magic De Luxe Espresso Machine
Ventilate problem
check hous from tank to steam valve,maybe just plugget out,or your flowmetar is not good any more
Aug 28, 2009 | Gaggia Syncrony Espresso Machine
Constant ventilate message
mine says the same thing, run hot water from the hot water/steam nozzle until the message disappears. do this a few times, mine is working fine after doing that. hope this helps
May 09, 2009 | Saeco Royal Professional Espresso Machine
Display says "ventilate" and won't operate
run hot water from the steam nozzel (for few seconds) to purge the air out of the system
you propabably ran out of water making your previous coffee?
Apr 08, 2009 | Saeco Royal Professional Espresso Machine
Royal Professional machine
try to set the grinder to grind little more coarse, you have to make 2-3 cup to get the new settings to work.
To get off the ventilate you have to press the button for hot water and make a cup of water.
Hope this will help you.
/Mirran
Aug 11, 2008 | Saeco Royal Professional Espresso Machine
Saeco Incanto not grinding
Hi Chris,
The leaking is your steam valve that has to be replaced, you can see this if you open the door and look up in the right corner there you will see water drip.
If not then you have a pipe or boiler leak.
How old is your machine?
How often do you descale the machine?
When you try to make a cup of coffee, starts the grinder for two seconds or is it dead?
Jul 19, 2008 | Coffee Makers & Espresso Machines
Ventilate Problem
Hi, deventilate by tapping hot water from the pipe. The message should clear an you can make a nice cup of coffee!
Feb 02, 2008 | Saeco Royal Professional Espresso Machine
Trying to ventilate and hot water not flushing through on button 26
Before you press water button to vent you need to restore to factory settings.
First press menu (far right button) then toggle to restore factory settings (using far left button), press menu button then far right again until yes comes up, then press menu button. Press esc button (3rd from left), machine should now be back to normal. Then press water button (3rd from right) and turn steam knob to vent until free water is coming through.
This is the only way I could get mine to work!
Dec 30, 2007 | Gaggia Titanium Espresso Machine
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
182 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
