Question about Nakamichi DVD-15
Nakamichi dvd-15 remote control
Lost remote control to my nakamichi dvd-15 player. system requires remote to turn on from standby and function. Unable to locate oem remote. any assistance appreciated.
2 Suggested Answers
SOURCE: No audio output hooked up to my Vizio 37" LCD
You need to select digital out in the menu of the dvd player..
Posted on Jan 08, 2008
My Sound Space12 powers on but there's no display and no manual or remote functions to operate the discs or the other functions.Can you provide a answer.regards
If the system is connected properly and the main tuner power is on you will see the orange standby light on in the front of the main diamond shaped control unit. If that light is not on, you have not connected the system and power cables properly.
If the standby light is not lit, press the power on/off button in the middle of the rectangular processor/tuner to turn it off and unplug the main power cord from the main tuner/processor from the wall. Next, ensure that all of the power, video and audio cables from the diamond shaped control unit are properly connected to the large tuner/processor. Since you are there, check any other av in/out connections.
Now that you have checked and adjusted the cables between the controller and the tuner, plug the tuner back into the wall and push the power on button. Now check the standby light again on the diamond shaped controller unit.
Once that light is lit, press the silver, horizontal on button in the middle of the diamond shaped display unit, or the Power Standby/On button on your main remote control and you are operational.
Mar 05, 2011 | Nakamichi SoundSpace 12 System
Hi, I've a small problem cocerning this dv-363 player. I accidentally set it to 'progressive'. Now I cannot undo. I tried holding the buttons on remote and on machine itself, still not working, can you...
Progressive Scan is a menu option relating to video output of this player. Assuming you have the original DVD remote, this should be easy.
* From the user manual (pages 50-51 of the pdf document):
About progressive scan video
Compared to interlace video, progressive
scan video effectively doubles the scanning
rate of the picture, resulting in a very stable,
flicker-free image. Progressive scan video is
available only from the component video
output.
If you connect a TV that is not compatible
with a progressive scan signal and switch
the player to progressive, you will not be
able to see any picture at all. In this case,
switch everything off and reconnect using
the supplied video cable (see Easy
connections on page 14), then switch
back to Interlace. Switch the player to
standby then, using the front panel
controls, press STANDBY/ON while
pressing 'back to Interlace.
Hold these 2 buttons together for about 10-15 seconds or so, but only while the player is in standby mode. *
If you have lost the manual, you may be able to download the user guide (as an adobe reader (pdf) document) from:
http://www.retrevo.com/support/Pioneer-DV-363-K-DVD-Players-manual/id/385bh937/t/2/
(it will ask you for an email address prior to downloading - use a blank address if possible and enter the security code in the fields then save the document)
If the above suggestion does not switch it back to interlace, you will need a TV with progressive scan function to enable you to access the player's on-screen menu and in 'Initial Settings' 'Video Output' 'Component Out' section, select 'Interlace'. and press OK from remote as required.
Either way, it should NOT require a workshop service, and is simple enough to do at consumer level with the right TV type.
Mar 05, 2011 | Pioneer DV-363 DVD Player
I am trying to get my philips universal remote to workcr with a sony dvd/vcr player..how do i do it?
please go to the below website and select the model of your remote.
An page opens in that you have REMOTE CONTROL CODE FINDER,click it
Choose the device type and device make it gives the code for your remote.
Then follow the procedure given below,
1 Turn on the DVD ( The DVD should play ).
2 Select DVD on the remote (= Press the device key for which you are programming the remote ) :
keep the key pressed for 5 seconds until it blinks twice and then remains lit.
3 Enter the given four-figure code for your brand , using the digit keys .
– The DVD key will now blink twice and then remains lit.
• If the DVD key blinks once , the code has not been entered properly or
The wrong code has been entered. Start again from step 2.
4 Press and hold the “ standby/power on” key and immediately release it when the TV
switches off (standby).
– This may take up to 30 seconds.
5 Turn on the DVD and check if you can
operate all needed functions on your DVD
– Make sure the receiving device is able to respond and accept the desired command .
6 Press the DVD key twice to exit setup mode and save your settings.
– When no key is pressed for 2 minutes or more the remote control
will exit setup mode automatically.
• If the device does not respond at all or not to all of the key commands or if you cannot find
the code for your brand, enter ‘0, 0, 0, 0’ in step 3 and continue with step 4.
The remote control will now search the full database for a code that works with your DVD
Full database search may take up to 15 minutes.
thanx
Jul 21, 2010 | Universal Remote Control Hampton Bay...
Need DVD Hack code for Asda LEDVD0802.
The word Hack gives an impression of illegality, however the term is used in error for what is a series of remote button pressing to unlock the players potential. Sources are freely distributed by the very people who make the units. Now this model I have found is the basics of a Phillips model 610. So here is the unlock sequences..
To change the region on this player 1. Press the Standby button on the DVD player to power off the machine 2. Press the Standby button on the DVD player to power on the machine 3. Press the Blue button on the remote control 4. Press the Play button on the remote control
NB: This and the following steps may need to be carried out quickly following the previous step 5. Press the 1 button on the remote control 6. Press the 5 button on the remote control 7. Press the 9 button on the remote control 8. Press the 1 button on the remote control 9. Press the 2 button on the remote control 10. Press the 1 button on the remote control 11. Press the 2 button on the remote control 12. Press the 1 button on the remote control 13. Press the 2 button on the remote control 14. Press the 0 button on the remote control 15. Press the 0 button on the remote control 16. Press the 5 button on the remote control 17. Press the 2 button on the remote control 18. Press the 5 button on the remote control 19. Press the 5 button on the remote control 20. Press the Play button on the remote control 21. Press the Standby button on the remote control
Hope this works for you.
AndystUK
Nov 08, 2009 | Televison & Video
Lost my remote
MOST LIKELY THAT REMOTE IS NOT GOING TO WORK, BECAUSE IT DOES NOT HAVE THE SAME FUNCTIONS AS THE ORIGINAL, LIKE SPEAKER CONTROLS AND SO ON.
May 07, 2009 | Coby DVD-925 System
Program RCR4358 to Control Philips DVD player DVP5982/37 C1
I am having the exact same problem. Did anyone ever find a fix for this?
Mar 24, 2009 | RCA Universal Remote Control
I have a rca universal remote control also a cody dvd player.
Hi freeent316,
Unfortunately, the RCA 15-2104 does not have a code for Cody brand DVD players. The list of codes can be found at the following web address:
http://support.radioshack.com/support_video/doc67/67141.htm
Since there is no published code for Cody brand devices, I recommend using the CODE SEARCH function. Here's how:
1) Turn on the DVD player
2) Press the DVD key on the remote
3) Hold down P until the red light blinks twice
4) Press 9-9-1 (the red light will then blink twice).
5) Slowly alternate between pressing the DVD key and the POWER key - when the device turns off, that means the remote has found a code for the DVD Player and should then operate it.
You can read the details about the CODE SEARCH feature in the user manual, which can be viewed at the following web address:
http://support.radioshack.com/support_video/doc66/66339.pdf
I hope this helps - please let me know if I can be of any further assistance.
Dec 11, 2008 | Radio Shack 15-2104 Remote Control
Unlocking my DVD Player
Try this,it should work....Rod
To change the current region setting on this player
1. Press the Standby button on your remote control to place the unit into Standby
2. Press the Standby button on your remote control to turn on the unit
3. Press the Open/Close button on your remote control to open the drive tray
4. Press the Clear button on your remote control
5. Press the 1 button on your remote control
6. Press the 3 button on your remote control
7. Press the 6 button on your remote control
8. Press the 9 button on your remote control
9. Press the 0 button on your remote control
10. Press the Open/Close button on your remote control to close the drive tray
11. Press the Standby button on your remote control to place the unit into Standby
12. Press the Standby button on your remote control to turn on the unit
Jul 16, 2008 | Durabrand Televison & Video
Tryed the code to unlock region
1. Turn on the unit
2. Open the loading tray
3. Press the "Setup" button on the remote
4. Navigate to the "Preferences" page using the right arrow key
5. Enter 138931
6. You will now see the current region code displayed
7. Use the Up/Down arrow keys to select the region required or "0" for all regions
8. Press the "Play" button on the remote
DVP 5106k
1 - Make sure there is no disk in the player
2 - Press EJECT on the remote or on the player. The eject icon has to be visible on screen for the hack to work!!!
3 - Press MENU (System) on the remote
4 - Press the RIGHT button on the remote until you get to the PREFERENCES screen
5 - Now enter the sequence 135566 with the remote control
6 - Now "Region Code" should appear
7 - Select the 0 (multiregion)
8 - Press MENU (System) on the remote to exit the setup screen
9 - Press the power button on the remote to set the player on standby, this saves the new setting.
Apr 19, 2008 | Philips DVP5140 DVD Player
Durabrand LEDVD0701 dvd player
Taken from another site in case you still need to unlock it.
The Pacific hack works for this one!
Multi-Region Hacks for Pacific DVD-1001
Oct 20, 2007 | Televison & Video
Nakamichi DVD-15 Logo
57 people viewed this question
Top Nakamichi Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
Lawrence Oravetz
Are you a Nakamichi Televison and Video Expert? Answer questions, earn points and help others
