Question about Epson Stylus C20SX InkJet Printer
Need to change black cartridge but cartridge won't stop in position to allow me to remove it.
  • 326 Answers
Http://safemanuals.com/user-guide-instructions-owner-manual/EPSON/STYLUS%20C20SX-_P
you can download your manual there, mines a different model but i have to press the button twice to go into position for me
Posted on Jun 30, 2009
When I try to change black cartridge in Epson NX100 the carriage will NOT STOP - flips back and forth. How do I get it to stop so I can remove the cartridge - Black is only one out.
1. Turn on your Epson Stylus NX100 Series printer. Your printer should be plugged in and connected to your computer.
2. Lift open the scanner and prop it up with the support bar. Press the stop button on your printer. The print head will move along the printer and will stop to allow you to change cartridges.
3. Squeeze the tab on the cartridge that needs to be replaced and remove the cartridge by lifting it straight up. Dispose of the used cartridge immediately.
4. Shake your new cartridge several times before removing it from the package. Remove the cartridge from the package without touching the green chip. Take the yellow tape off the bottom of the cartridge. Insert the cartridge into the holder by pressing until you hear it lock into place.
5. Release the support on the scanner and put the scanner back into its original position. Press the stop button to let your printer know that you have changed the cartridge. It may take up to two minutes for your printer to be ready to use. When the "On" light stops flashing and remains on, you may begin to use your printer
NOTE: Beware that you must have all ink cartridges full because Epson uses color even when only printing black and white (lots of comments here about that scam!!)
Sep 05, 2011 | Epson Stylus NX105 All-In-One Printer
How do i change my lexmark x4650 print cartrige?
Installing/Replacing your ink cartridges:
1. Open the printer, and then press down on the cartridge carrier levers. printmastert_52.jpg
2. Remove the used print cartridge or cartridges. 3. If you are installing new print cartridges, remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid. 4. If a black cartridge is included in the box contents, remove the tape from the back and bottom of the black cartridge, insert the cartridge in the left carrier, and then close the black cartridge carrier lid. 5. Close the printer.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
May 15, 2011 | Lexmark X4650 InkJet Printer
Just need to know how to put in black ink in the z1300
Follow these steps on how to install the cartridge: 1. Make sure the printer is on. 2. Lift the access cover. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. 3. Press down on the left cartridge carrier lever to raise the cartridge carrier lid. 4. Remove the used print cartridge(if you are replacing). Insert the new black cartridge in the left carrier. 5. Snap the lid closed.
3. Remove the used cartridge.
4. Load the new black cartridge. Close the cover.
Apr 29, 2011 | Lexmark Z1300 InkJet Photo Printer
Do not know how to change ink cartridge x2650
Lift the scanner unit, and then press down on the cartridge carrier latch to raise the cartridge carrier lid. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
Remove the used print cartridge. Insert your new cartridges.
Apr 28, 2011 | Lexmark C533DN InkJet Printer
Need all steps in changing black ink cartridge
Hi Good day!!! Here are the steps how to replace cartridges
2. Lift open the scanner and prop it up with the support bar. Press the stop button on your printer. The print head will move along the printer and will stop to show you which cartridge is low and needs to be replaced.
3. Press the stop button once more. If other cartridges need to be replaced, the printer head will indicate which ones by stopping on those cartridges each time you press stop. If no other cartridges need to be replaced, the print head will move replacement position on the right.
4. Squeeze the tab on the cartridge that needs to be replaced and remove the cartridge by lifting it straight up. Dispose of the used cartridge immediately.
5. Shake your new cartridge several times before removing it from the package. Remove the cartridge from the package without touching the green chip. Take the yellow tape off the bottom of the cartridge. Insert the cartridge into the holder by pressing until you hear it lock into place.
6. Release the support on the scanner and put the scanner back into its original position. Press the stop button to let your printer know that you have changed the cartridge. It may take up to two minutes for your printer to be ready to use. When the "On" light stops flashing and remains on, you may begin to use your printer.
Don't forget to vote thanks!!!!
Nov 02, 2010 | Epson Stylus NX105 All-In-One Printer
How to open printer to change cartridge?
In order to replace the cartriage, please follow the steps below:
1 Keep the printer on.
2 Lift the printer (scanner unit) until the scanner support keeps it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is
busy.
3 Squeeze the tabs on the cartridge lids, and then lift the lids.
4 Remove the old cartridges.
5 If you are installing new cartridges, remove the stickers and tape from the bottom of
the cartridges.
6 Insert the new cartridges. Make sure the color ink cartridge is secure in the left carrier
and the black cartridge is secure in the right carrier, and then snap the lids closed.
7 Lift the printer (scanner unit) and push the scanner support back while lowering the
printer (scanner unit) until it is closed.
Sep 15, 2010 | Dell A920 InkJet Printer
Cant change ink cartridge on my Epson C91
cannot change ink. Turn on, and just unplug power when cartridge is moving. cartridge will stop not in parking position. Just move head by hand to replacement position.
May 02, 2009 | Epson Stylus Photo 1400 Printer
I need to replace the color ink in my Epson stylus color 740
To force a Cartridge change press and hold down the Paper feed (load eject) button for over 5 seconds and the cartridges will move into a change position. Please note: if the cartridges move to a position where only the Black cartridge can be changed pressing the Paper feed button once will move the head so that the colour can be changed.
Before changing the carts it is recommended that you run the head cleaning utility.
When you have poor print quality and have tried the head cleaning utility it is recommended that you replace the cartridges. Ift the red lights aren't on to indicate the ink is out you need to force the cartridges into a change position. To do this press and hold down the paper feed button (load eject) for over 5 seconds and the cartridges will move into a change position. Please note: if the cartridges move to a position where only the Black cartridge can be changed pressing the Paper feed button once will move the head so that the colour can be changed.
Regardds
Jan 04, 2009 | Epson Stylus Color 740 InkJet Printer
Epson Stylus C20SX InkJet Printer Logo
215 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
