Question about Saws
My model 63 10" artasan tabel saw. The blade is not parallel to the miter slots. how do I adjust?
    President:
  • 1,996 Answers
First off, check the blade itself for true by marking a tooth and rotating the blade to see if it deflects out of flat.
Then, with a known flat blade or plate, you can loosen the bolts that hold the trunnion to the bottom of the table and adjust the position of the works relative to the mitre slots. Use a dial caliper with a magnetic mount attached to the miter guage and you'll be able to slide it back and forth to check the final position for accuracy. Then carefully tighten the bottom back up, Make sure all raising/lowering and angle adjustments are working properly, and you're good to go....
You might be able to get a service manual from powermatic to help you through the process, but you'd have to call them to check.
Good luck. It can be a real pain in the....
Give yourself a day or so....
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 08, 2009
How do I make adjustments on my ridged r4512 table saw?
The carriage under the table is held to the underside of the table with several bolts or screws. Loosen those screws.
Raise the blade and clamp a stiff metal straight edge to the side of the blade. Use a carbide blade and clamp the straight edge to the sides of the teeth. Move the carriage around until the straight edge is parallel with the miter gauge slots, then tighten the bolts.
Oct 12, 2014 | Ridgid Saws
Centering saw blade
The most important thing is that the blade and riving knife are centered with each other. If not, you may have to shim the riving knife.
The bolts that hold the carriage under the table are intentionally sloppy so that you can loosen them and align the blade/knife with the miter gauge slots.
Lay a long metal straight edge against the side of a carbide blade teeth with the blade all the way up, and make sure the straight edge is parallel with the miter gauge slots in the table. Then tighten the bolts on the underside.
Sep 07, 2014 | Craftsman Contractor Series 10" Table Saw...
How do I adjust the blade so that is parallel to the miter slot on my 10" table saw that is about 10 years old?
I fond some model numbers for table saws and I would recommend going to managemyhome.com with your model number and you can download a manual for this tool with detailed instructions on how to align so it is cutting square. I used the model number 11329884 just to see and I was looking at page 55
Aug 28, 2010 | Craftsman 10" Table Saw
Powermatic 3000 saw not cutting true , have blade true w/top & top true w/fence & even removed splitter to no avail???????????
The blade and fence must be parallel to the miter slot. Splitter or riving knife needs to be parallel to the blade.
Mar 16, 2010 | Saws
I have a Craftsman 10" table saw model number: 137.248830. The saw doesn't make square cuts, it is more of a problem when using the miter. I have followed the alignment procedure so that the right...
I assume that your alignment procedure is about adjusting your miter gage. But you should first verify if the blade is parallel to the miter slot (the slot the miter gage slides in). This is adjustable underneath the saw, and sometimes comes crooked from the factory or comes loose later on. To check if the blade is parallel to the miter slot you can do this.....1. unplug the saw. 2. Raise the blade as far as it will go. 3. Clamp a piece of wood to your miter gage so that it just touches the blade as close to the front of the saw as possible. 4. Use a marker and mark that spot on the blade. 5. Now slide the miter toward the back of the saw, and rotate the blade by hand so that your piece of wood hits the same spot as where you checked in the front. You can see a large misalignment by eye. But you can get a little precise by using a piece of paper between the wood and the blade as a feeler gage. Or better yet, use a drop indicator instead of the piece of wood and you can measure the difference. If this isn't as close to parallel as you are able to measure it, you need to turn the saw over and find the bolts that attach the whole assembly under there to the table top. Once you have this in alignment, you should be able to set your miter to be square against any good square. If you don't have a high quality square, you can go to a tool store (Sears or whoever) with your miter gage in hand, and set it to be square against their most expensive square. If the square is square, and the blade is parallel to the slot and it still won't cut square you either have a bad blade or there is too much play in the saw's arbor. Try to wiggle the blade side-to-side - any wiggle at all is too much.
Jan 20, 2010 | Craftsman 10" Table Saw
The saw blade is 1/16" out of parallel with the miter groove in the table. How do I adjust the blade/motor? Thanks
To be that far out of alignment, there must be something loose. Unplug it, turn it over and look for what it is. If you have a drop-indicator gage, and you can clamp it to your sliding miter gage, it will help you get the alignment dead-on. Slide the miter gage toward the front and back in the slot with the tip of the indicator in contact with the blade. Have the the blade at fully elevated postion. If you don't have such a gage, you can clamp a piece of wood to the miter gage to get pretty close. You will probably have to do this with the saw laying on it's backside so that the top and the bottom are accessible at the same time.
Here's the owner's manual
http://www.hitachipowertools.com/product/files/saws/table_saws/C10RA3_OM.pdf
Here's the parts list with an exploded view
http://www.hitachipowertools.com/product/files/saws/table_saws/C10RA3_Breakdown.pdf
Jan 15, 2010 | Hitachi C10RA3 Electric Table Saws
New Dewalt 745 saw, blade not parallel with Miter slot
Either take it back, or take it apart and make the holes bigger. For that kind of money, you should be able to adjust it dead-on. I thought I had the same problem on an old Craftsman, but I found that I just hadn't loosened things up enough. It's hard to see how much wiggle room you really have under the washers. And if there are aluminum castings involved, there can be a burr raised by the initial setting that it gets stuck on.
Dec 28, 2009 | Dewalt DW745 10" Compact Job Site Table...
Adjusting Blade/Miter Groove Alignment on 1950's Craftsman Table
Try using a 1/16 thick flat washer as a shim where the mounting bolts/trunions mate with table. 1/16 shim on front mounting bolt will shift front of blade over 1/16 or 1 on the back mounting bolt will shift back of blade over
Oct 28, 2009 | Craftsman 10" Table Saw
How do I align the saw blade with the saw table I have a 10 inch Delta Contractor's saw that is about 10 years old. The blade is not straignt with the miter slot. andyc@bergeralllied.com
The Blade Arbor is held to the bottom of the table with mounting screws and stop/adjusting screws. Loosen the mounting screw and adjust the stop screws to make Blade true with miter slot.
Sep 14, 2009 | Delta 36 982 10 Inch Left Tilt 1 1/2...
Blade Alignment?
ok yep your blade is out of alignment with the fence. It is closer to the fence at the rear than the front. You need to make the modification or adjustment to your fence, if it allows that, and then worry about the miter slots later (which should be adjusted miter slot to blade, not miter slot to fence). You might be able to adjust the miter slot to blade by moving the actual table and then securing witht he table mount bolts. Check your manual for how to align the fence.
You do want to fix that though as it can be potentially dangerous and result in kickback of the workpiece which is a rather SCARY thing, and very dangerous.
Jun 01, 2009 | Dewalt DW744S 10" Portable Table Saw with...
Saws Logo
59 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
