Question about BenQ FP567 (White) 15" LCD Monitor
Fp567 replaced bad capacitors resoldered has backlight no video
Benq fp567 no video after power on
  • 585 Answers
Check the connections at both ends of the cable to the LCD. If you've damaged the cable you can probably find a replacement on the world's most popular auction site.
Posted on Jun 30, 2009
  • Bruce Volkers
    Bruce Volkers Jul 01, 2009
    If it's not the cable, then inspect your work, if you made a solder splash in desoldering and didn't catch it, it could cause what you see. Remove any solder that doesn't belong. Did you observe polarity when replacing the caps? What symptoms were there before you replaced the caps?
Replaced mosfet and capacitors in power supply but screen still only lights up for a second or so then dark?
Check micro fuse, 2 power transistor. If still cannot, then resolder all joints and see got dry solder or not.
Oct 26, 2013 | BenQ FP91G+ 19" LCD Monitor
Still flickering monitor Proview MA-782KC
Hello, Did you just resolder the capacitors? They need to be replaced not resoldered. When they start failing they can give exactly the type of problems you have, flickering or wavy picture, Slow display of picture when you power up monitor or very dark picture. Here is a link to an article that talks about replacing the capacitors and what you need to look for and what to replace; http://www.ccl-la.com/blog/index.php/capacitors/ If you have any questions please let us know at: tech@ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 29, 2010 | Computers & Internet
Trouble with my BenQ monitor
As a general rule, this is a panel failing.
The panel is working for a few minutes until it heats up then begins to breakdown. Blowing air onto it wont help since the area in question is under another panel inside the monitor.
The video control board (inside the monitor that converts signals between your PC and the physical panel) could be failing.
Another source of the problem, though rare, is the capacitors that filter power for the panel's power supply (on the main powerboard) begin to break down and that is enough to cause the issue.
Because this is a BenQ, it may come back to life if you replace any capacitor that looks even remotely suspect & resolder all the main components on the powerboard.
Be warned, there are dangerous voltages stored by the main filter capacitor that can kill even if the monitor has been unplugged for several hours.
Peter
Mar 26, 2010 | BenQ FP71G 17" LCD Monitor
Monitor turns black after 3 seconds
teo6925, "Switch-mode-power-supply" is in partial shutdown mode. Can you see any electrolytic filter capacitors that have a slight "swelling" to their tops? They should be flat!! You may also need to inspect all the soldered component connections very closely for cold, thermally intermittant, "frosty" looking solder joint connections. May need large magnifying glass or 10x to 20x inspection microscope to locate these thermal/vibration "fractures" and then resolder them! If you have a capacitor problem, then you will need to carefully remove and replace with new ones. If you are novice at soldering I suggest that you document your work with digital camera or video tape so you can get everything back together with no "leftover" pieces! Teo, all you need to do to find out how BAD the problem of poorly manufactured capacitors is would be to search WEB for BAD CAPACITORS!!! Look for pic's of ELITE capacitors or CAPXON brand. You will be stunned beyond belief!!! Reading is free!! READ, READ, READ. Let us know what you find and do additional comment here on FIXYA. 12fixlouie
Jan 09, 2010 | BenQ Computers & Internet
No backlight
ya its a circuit problem
Sep 15, 2009 | BenQ FP747 (Beige) 17" LCD Monitor
BenQ LCD Monitor FP567, no display.The Green Led flicker,but no image.Please send us some tips
dreaded inverter board problem..here is a tip on where to look inside your lcd as is similar models...http://www.electronicrepairguide.com/benq-t705-lcd-monitor-repair.html
Mar 03, 2009 | Computers & Internet
Benq FP937s Monitor - no display
Usually this type of problem is due to a faulty electrolytic capacitor on the monitor's power supply board or the inverter board that powers the backlight lamps. If you have a soldering iron and some technical skill it's possible to repair this yourself, if you can determine the bad component. Look for a capacitor with a domed top, or what looks like corrosion or leaked fluid on the top. If you replace the capacitor with one of the same rating and type (in volts and microfarads (uf)) it may fix the problem.
The backlights are usually not the problem in this case, I've fixed dozens of monitors and it has always been a faulty capacitor.
If you are willing to try this, there are lots of resources on the internet that will provide instructions for how to do this. Replacment capacitors can be purchased (usually $0.50 or $1 each) from many electronics suppliers and on eBay.
Good luck, happy repairing!
Jun 10, 2008 | Gateway FPD2275W LCD Monitor
Benq fp737s monitor failure
try resoldering the joints on c826 &c824 near the 4 yellow transformers in the power supply.
hope this helps
kevin numbnuts07
May 28, 2008 | BenQ FP737S-D 17" LCD Monitor
Proview 700p problem
DISPLAY IS GOING OUT SIMPLY GET NEW MONITOR
Jan 16, 2008 | Proview PL 566s 15" Flat Panel LCD Monitor
BenQ FP567 (White) 15" LCD Monitor Logo
134 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
