Question about Grundig Televison & Video
I use Elegance 70 MW 70-150/8 Dolby. problem is picture distort in vertical line and text out of screen area. is there any factory setting code from remort to get the picture back to normal
    Problem Solver:
  • 11 Answers
Go to the Installation menu
enter code 8500 in the servicemenu for dealer
choose item 1: screengeom.
Now adjust your settings
Good luck
fransverhees@gmail.com
Posted on Sep 13, 2009
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
VIZIO 42 CLASS RAZOR LED SMART TV M420KD picture has lots of green ghosting and thin white vertical line through left side of screen also
Hi Charlene,
please try with video input from any device,and i think you are using local antenna and it has gain problem or your tuner section of the tv is not working correctly.
if distroted pictures comes with video input signal it is video amp and processing unit problem.
you have to go for repair shop for fix that.
regards,
nuwan
Jan 24, 2014 | Vizio Televison & Video
Vizio M420kd vertical thin white line on left of screen pictures have lots of green ghosting
If you've ruled out that the source you're displaying from is good, I would contact vizio for a warranty repair
White vertical lines across the screen. Why and what can be done? Thw white lines appear and stay all the way across the screen. They are about 1.5" inbetween each vertical line,
You have a failure in the vertical circuit. Service can run between $75 to $150 depending on your area.(In home repair will cost more) If set is older then 3 years and under 27" recommend replacing it.
May 06, 2010 | Mitsubishi WD-62327 62" Rear Projection...
Missing child lock (code Numbers)
Get into the secret service menu. Should be a chassis hardware access or by remote control. Any qualified repair shop can help you out.
Apr 18, 2009 | Televison & Video
Distorted picture on my 32" Proscan TV...(about 15 years old)
The RCA GE sets have a problem with bad solder connections in the tuner unit which also causes numerous symptoms including poor regulation, no vertical deflection, low audio or dead set.
Pulling in from the sides is either poor regulation or a bad eeprom/solder join issue
Mar 13, 2009 | Proscan PS36123 TV
Screen distortion
Is it a clean vertical line or a fuzzy vertical line? It could be as simple as a cleaning.
Apr 25, 2008 | Hitachi 53SDX89B 53" Rear Projection...
Philips 42 inch Plasma television
I habve seen this issue with this sets and if the vertical lines are in the menu as well and there are more than one line the panel would need to be replace. Contact a tech in your area to see if then can put the set in white screen mode and leave it there for a couple of hours and see if the lines go away. If not then the set would need a panel.
Sep 27, 2007 | Philips 42PF9630A 42 in. Plasma Television
Black horizontal lines across bottom 1/3 of screen
This is due to vertical section failure. Change the vertical supply rectifier diode and supply filters. Then check zener diode leakage in pumpup circuit section. Also check any electrolytic capacitors leakage in vertical section. If it is old model tv change vertical height, vertical lenearity presets also. I hope given details useful to you.
Aug 23, 2007 | GE 27GT722 27" TV
Jvc av-27730 27"
One thing you should not do with electronic devices which have a start up proceedure is to turn the power off, and then on again without a wait of about five minutes. Some equipment manuals warn you about this, and specify a longer period. The start-up has to have time to reset. It will be more likely to reset if you do not leave it on standby, and even unplug it. In your TVs case you need to describe the distorted picture as it may give a clue to a fault, or incorrect start-up. The horizontal line indicates the frame timebase had stopped working. No picture could be a fuse blown inside the set, or a timed cutout which may reset after a time. Try after several hours to see if it comes on. If it is just the frame timebase (vertical) it is worth repairing.
Oct 22, 2006 | JVC AV-27230 27" TV
Televison & Video Logo
359 people viewed this question
Top Grundig Televison & Video Experts
Raj Patel
Are you a Grundig Televison and Video Expert? Answer questions, earn points and help others
