Question about Panasonic NV-GS230 Mini DV Digital Camcorder
NV-GS230 does not work in Firewire mode
I'm trying to capture from a Panasonic NV-GS230 to a Macbook Pro under OSX using the DV (Firewire 400) output. This should work according to the manual, but is not reliable. I have occasionally got it to work, but most of the time nothing happens. iMovie (I'm using v8) does not detect the camera as a capture device. I've rebooted, made the connection before powering up the devices, all in the order the manual suggests. No go.
Note that the manual states that the USB connection does not work under OSX. I've tried it under Windows and it works fine there. But that's not what I want.
I notice that a few others are having the same issue. The firewire port works fine with other devices. I;m starting to wonder if it is an issue with that camera and the particular model of firewire port on the Macbook.
sainisonu
  • 156 Answers
SOURCE: Problem in connecting Camcorder with Laptop
Use USB data cable which u get with ur cam.Install the panasonic software also packed with cam.And get ur video copied to pc.But this is a slow process because of Movie copied while playing.
Regards,
Sandeep
Posted on Oct 23, 2007
sainisonu
  • 156 Answers
SOURCE: Panasonic NV-GS15 Mini DV Digital
U get usb cable and a software cd with ur cam.Install the software and attach ur cam to pc with the help of USB cable and get ur movies copied from cam to pc
SOURCE: sony handycam DCR-HC26 and mac not recognizing with firewire
mlkml
Posted on Apr 23, 2008
renx
  • 71 Answers
SOURCE: firewire
Okay then let's start with that. Download the drivers from:
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Camcorders/MiniDV-Camcorders/Drivers-Downloads/model.PV-GS39.D#ts
Install the drivers and you should be good to go! Let me know if you're having any problems after that.
Posted on May 08, 2009
MNfisherman
  • 11896 Answers
SOURCE: how can i change my panasonic nv-gs230 mini dv
Best
1. Copy the video to your computer with WinDV. No "capturing" involved. The video resolution and PAL/NTSC format will be the same as the source.
2. Then convert to whatever format you like.
You could also use something that copy and converts the video directly from the DV, like convert to dvd with Ulead DVD Workshop.
DV is a fixed standard and comes in 50Hz and 60Hz versions.
50Hz ("PAL" 625/50) 720x576, 25fps interlace (aka 576i)
4:2:0 components, 25Mb/s Video Rate
LPCM audio 2ch 16bit 48KHz or 4ch 12bit 32kHz
60Hz ("NTSC" 525/60) 720x480, 29.97fps interlace (aka 480i)
4:1:1 components, 25Mb/s Video Rate
Meaning, You cannot change the camera. It is either a pal camera or a ntsc camera. Othewise you will have to by a firmware update from the manufacture's website.
Posted on Oct 14, 2009
I cant connect my DV with windows 7 in my laptop
Use a firewire cable and open Windows Movie Maker to capture.
Apr 17, 2011 | Panasonic NV-GS230 Mini DV Digital...
I BOUGHT A FIREWIRE 4PIN END TO END FOR MY CAMERA. CONNECTION FAILED. COMPUTER DOES NOT DETECT MY CAMERA
Open Windows Movie Maker and have the camera set to VCR mode, that's the one thqat replays the tape.
Try again.
Mar 26, 2011 | Panasonic NV-GS230 Mini DV Digital...
What kind of cable for panasonic NV-GS230 to connect with pc
A firewire cable with a full size firewire on one side and a small rectangular one on the other side.
Mar 08, 2011 | Panasonic NV-GS230 Mini DV Digital...
Hello, could you advice where I could purchase Panasonic NV-GS150 DV Camera MAC OSX 10.5 Support? I cannot connect my Panasonic NV-GS150 DV camera with my MacBook Pro. Thanks a lot for your help!...
Panasonic usually includes the Mac software program "Imagemixer 3" that imports the videos/photos you have on your camera. If the software isn't included with your camera, try Googling around for the program and it should come right up! I hope this helps. - Omn1cide
Mar 05, 2011 | Panasonic NV-GS150 Mini DV Digital...
Panasonic NV GS25GN How to download from camera's tape to a new iMac OSX? Do I need special drivers? My iMac has a firewire 800 connector (not a 400).
I expect that Firewire 800 is backwards compatible with 400. You just need a cable with the appropriate connectors on each end. The Mac surely comes with the drivers already installed.
How it works with my mini-DV recorder (on a PC) is that when I fire up the video editing software, it sees the camera as a source and can control it from the computer to rewind and download. The book says use the mains power adapter to make sure the camera stays powered.
Nov 30, 2010 | Panasonic NV-GS25 Mini DV Digital...
Where can I get panasonic nv-gs11eb drivers for mac?
There are no drivers needed- you need to use the DV output (which is actually just a mini firewire 400 port) the other end of this cable is a full sized 6-pin firwire 400 cab;e that should slot into any mac (pre 2009 when some changed to the bigger firewire 800 ports). You cant use the USB. to capture the video, I use final cut pro athlough I'm sure imovie will let you do it.
May 29, 2010 | Panasonic NV-GS11gc Mini DV Digital...
My new computer has windows 7, i cant find any program who will work with my panasonic nv-gs230.
try using windows XP mode to run an older program (you can download windows xp mode from microsoft.com)
Nov 28, 2009 | Panasonic NV-GS230 Mini DV Digital...
How can i change my panasonic nv-gs230 mini dv
Best
Oct 14, 2009 | Panasonic NV-GS230 Mini DV Digital...
Capturing DV
same thing for me any help ?
Jan 08, 2008 | Panasonic NV-GS230 Mini DV Digital...
Panasonic NV-GS230 Mini DV Digital Camcorder Logo
315 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
