Question about Kyocera KM-1505 Copier
What is c710 flashing - Kyocera KM-1505 Copier
  • 56 Answers
Re: What is c710 flashing
Problem with toner concentration in developer unit .Try to replace developer,after that run U130. If not,replace Developer.
Posted on Nov 08, 2007
0 characters
3 Points
C710 Code on Copystar 2030
C710 Interrupted Communication at the Destination. If you're the sender, it's happening outside your machine. Most likely, phone line.
Feb 20, 2008 | Copystar CS-2030 Copier
Lexmark Optra C710 keeps on having paper jams
Make sure the rear door is properly seated on it's hinges. Also look for any burs in the plastic guides that the paper might be catching. If you see any burs, try to smooth them out with a nail file or something.
Jan 10, 2008 | Lexmark Optra C710 Laser Printer
Paper jam due to water condensation in fuser unit Optra C710
The problem is that you have paper that contains too much moisture. (I bet it's been in the printer for a long time and has absorbed moisture form the atmosphere.. has it been rainy lately? When the moist paper gets heated in the fuser, the excess moisture turns to steam which then condenses back to water
on paper guides etc. Your diagnosis that the water is causing the jam is correct.. Try using some dry paper and it should be fine.
May 27, 2009 | Lexmark Optra C710 Laser Printer
Error c710
it means that toner cannot enter the developing section of the copier, all you have to do is remove the developing unit, then pour it with enough toner, the problem will be solve.
May 17, 2009 | Kyocera Mita KM-1815 All-In-One Laser...
What does C710 stand for?
Feb 09, 2009 | Kyocera Copystar CS-1820 Black and White...
Can not clear Error Code AP
You are out of toner...It means ADD POWDER
Feb 05, 2009 | Kyocera Mita KMR-1810P Laser Printer
Error c710
Your problem could be one of several things:
1) The Carrier (iron filings) inside the imaging unit is deteriorated and needs to be replaced.
2) The Toner sensor inside the imaging unit may be giving an incoorect reading, due to be faulty or because of old toner/carrier mix blockage close to sensor. Give the imaging unit a good service and replace the carrier.
3) The wires behind the black cover of the imaging unit have been picnhed and is shorting on the metal plate
4) The main PCB of the machine could be faulty
May 27, 2008 | Printers & Copiers
C710 Toner sensor problem
• The sensor output voltage is outside
the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run.
Try removing and refitting drum and toner.
if this does not help you may have damaged your toner cartridge or the sensor
Error appearing on screen C710
Did you disconnect telephone line?
C710: Interrupted Communication at the Destination.
Feb 15, 2008 | Copystar CS-2030 Copier
Kyocera KM-1505 Copier Logo
163 people viewed this question
Top Kyocera Printers & Copiers Experts
NewYork kyocera HP...
Bob Wescott
Level 1 Expert
Are you a Kyocera Printer and Copier Expert? Answer questions, earn points and help others
