Question about Western Digital Computers & Internet
WHICH PIN IS THE MASTER AND WHICH IS THE SLAVE?
  • 375 Answers
It is on the top of all WD drives - they have a little map.
Posted on Jun 30, 2009
Dvr not recognized by pc
check the pin on your dvr with the pin on your hard disk is master or slave if hard disk is master then make the dvr slave or check the pc bios
Jan 20, 2014 | Computers & Internet
Need to know which is master, slave and cable select
these may vary depending on the make of your hard drive
enable cable select:I:: master or single driveI:::
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope this helps
Jan 23, 2011 | Computers & Internet
Can't detect the hard drive?
The drive has several aspects to pay attention to. IF it is an IDE, make sure the cable is properly inserted (pin one to pin one) (unless you have a connector that is keyed)
The power cord. And the disk select. This is 6 to 8 pins that designate the drive to be a Master drive, slave drive, or cable select.
The motherboards usually can on handle 4 ide devices, (unless additional hardware is installed)
IDE1 one master drive and one slave drive (Master on IDE1 is usually the MAIN boot drive)
IDE 2 one master and one slave drive
Hope this helps, without more information on your problem, this is what I think will help.
good luck and don't forget to vote!!!
Oct 10, 2010 | Dell Computers & Internet
80 GB WD hard drive being used as master with windows xp when used once as slave with other WD hard drive, when tried to use it again alone or as master is no more bootable, but only as slave it is ok, I...
u ll have a jumper which is located at the back where u hv ur power supply pin.. there u ll hv one pin with 6 needles on which a plastic jumper ll be there only on 2 of the six needles. that plastic jumper may be in slave mode do remove the jumper and place it in master mode.....
thnkyou
Jun 29, 2009 | Western Digital Computers & Internet
Installing 2harddisk pimary/slave pin connection
The jumper configuration is listed on each harddrive. You have to make one the master, and the other the slave
May 22, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Need master slave configuration
You should have a jumper configuration written somewhere on the front (up) side of the hard Disk ... Look there, or look just around the Pins... Look for M, S, CS (Master, Slave, Cable Select)
Darko, Serbia
Mar 20, 2009 | Western Digital 60GB U100 5400RPM 2MB...
Master slave jumper settings on 250gb Maxline Plus II SATA
There are no master/slave settings on SATA drives because each drive has its own cable. The drive order is determined by what SATA port they are plugged into, or by the BIOS configuration.
Mar 16, 2009 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
Diamond max 20 hard drive won't install - jumper problems - want as slave, my old one as master
on the back of the drive there should be a black, white or yellow jumper. If you look very carfully at the back of the harddrive where the jumper is, it will tell you which position you need to have the jumper in for slave and which position you need to have it in for master. If it is already in the master position, carefully pull it out then push it back into the correct position to act as slave. Some hardrives simpley have a M for master and a S for slave while other harddrive will actually have the words. I hope this helps.
Oct 23, 2008 | Maxtor Hard Drive
Slave pin settings
hi frined
remove your hard disk jumper & u r hard will be slave
Apr 12, 2008 | Maxtor 20.4GB 7200rpm ATA-100 HDD p/n...
Jumper layout?
You wont have pin numbers however it will be marked sla or sl..Also there's also cs(cable select) mode where in the computer will automatically detect the master first hdd as master and the second one as slave..
Nov 13, 2007 | Western Digital Caviar WD200BB 20 GB Hard...
Computers & Internet Logo
172 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
