Washer wont stop pumping water - Washing Machines
    Sergeant:
    Champion:
  • 235 Answers
The circuit to the solenoid valve seems to be closed. Try disconnecting it for a minute and see if this opens or frees the circuit. If nothing happens then your valve will need to be replaced.
Posted on Jun 30, 2009
My washer wont spin out
Usually what happens here is that the pump to expel the water is not functioning, the normal problem here is a coin or hair grip gets lodged in the pump and stops the impeller from turning, generally the pump can be removed and opened up to remove the offending article and allow the impeller to operate again, once cleared of obstruction reassemble the pump and refit it. ( be aware, as the machine is still full of water, when you remove the pump the water will flood out so you need plenty of towels so soak up the water that spills.
Aug 05, 2016 | Samsung WF337AA Front Load Washer
Water wont stop draining when in wash cycle
In the front load washer is use the drain pump to drian out the water. so the water out tube (pipe) was hang up hihtger them to washer tube. your machines problem I thinh it is the drain out tube (pipe) was fall down lower them the washer tube.please correct it.
Jul 11, 2011 | Washing Machines
Whirlpool washing machine wont stop all lights
Check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out.
While the machine is on press "end of cycle" for 3 seconds, then wait for 2 minutes to try the door. Try this again if it does not open, this is the child lock program - to lock and unlock; it is the same procedure.
How abt a nice rating for the free help? Thnks
Jan 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer wont drain
The washer's pump unit has stopped working. It may not me getting the signal to pump after the wash cycle (controller problem) or the pump has let go and needs to be replaced.
Aug 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water pumping out at a trickle. stops in mid cycle
The timer seems to have gone out on you. Try to manually set it on spin and if that works then the timer is out.
Jun 30, 2009 | General Electric WSSH300G Front Load...
Kenmore elite washmachine
kinked hose adjust hose so unkinked
or water pump clogged sometimes socks get past drum into water pump
water pump sends the water out
these are the main reasons the washers wont drain
couple things needed for pump removal
bucket and a couple small cups
pull water out
once low disconnect power turn the water off disconnect
you will need someone strong and a dolly
take out side the little water left in will make washer heavy
once outside tip back lay down on side angled up a little pull pump out pull debry out with needle nose pliars 2 people needed here then put pump back in done
this is self service solution
this can be done without service person
or you could call maytag
Jul 06, 2008 | Kenmore 22422 Top Load Washer
Avanti W797: Tub won't spin or water does not empty.
Had the same problem. The water pump is not working and since it cant drain water it wont spin. A easy fix. There's a magnet located on the water pump thats comes lose. Simply tie it back into place.
Nov 20, 2007 | Avanti Top Load Washer W797
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
