Question about ASUS P5VDC-X Motherboard
Can I run Sata and IDe Drives together? - ASUS P5VDC-X Motherboard
  • 375 Answers
Yes. You have two IDE ATA/133 sockets and two SATA sockets. So you can run a maximum of 4 ATA devices and two SATA devices.
Choose your boot order in BIOS.
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5VDC-X/e2466_p5vdc-x.pdf
Posted on Jun 30, 2009
    President:
  • 942 Answers
Yes you can run sata and IDE together, you just set you sata enable in the BIOS the fist thing you do is when you turn on the PC just press delete kay successively in you keyboard, the after that set the IDE and SATA enable, then press F10 to save changes
  • 10,515 Answers
Yes you can.
Thanks!!
3 Suggested Answers
  • 75 Answers
SOURCE: Sata and IDE hard drive
hi there,
yes your motherboard would allow this .. once you configure in the bois your boot drive being the IDE drives ....the operation of the other drives should be a breeze ...
Posted on Apr 27, 2008
ElDopa
  • 295 Answers
SOURCE: Want to run both Raid 5 (4 drives) and a single SATA boot drive
Download the latest beta BIOS 1238. I had the same problem when adding a Samsung 1TB HDD to my RAID config. Updating to BIOS v1238 solved the Intel RAID Matrix "hanging" instantly.
You can't download it through the official Asus support page yet, but there's a topic in the Asus support forum with a link. You could also call Asus support and request the file, or just download it here: http://rapidshare.com/files/186891601/P5B-Deluxe_1238.rar :)
Posted on Feb 07, 2009
What kind of HDD should I plug into a standard PC, SATA or IDE?
Current generation PC motherboards generally support only SATA drives, both HDD and CD-ROM. Some older motherboards may support both. Consult the manual for your computer under Specifications and it should say. There are adapters available to convert IDE drives to SATA and USB enclosures and converters that can run IDE drives on otherwise SATA-only desktops. You have to be more specific with manufacturer and model numbers of your PC to get more specific answers.
Jan 13, 2015 | Computers & Internet
I have a Windows Server 2003 system on a old Dell desktop. I want to move it (hard drives) to a Systemax Venture.
You need an IDE controller board to boot from. The SATA drives have not system on it only data, so it cannot boot from these drives.
Oct 01, 2014 | Systemax Computers & Internet
I am using a single SATA II Drive in a new system, GIGABYTE GA-MA790X-UD4P, AMD 790X & SB750 chipsets. I know I can let the SATA II be a "Native IDE" but isn't that loosing any benefit of the SATA II...
The "Native IDE" mode causes the motherboard to "report" to the Operating System that the installed SATA drive is an IDE drive, rather than reporting "no IDE drives installed", and then requiring the Operating System to load a SATA device-driver to interface with the SATA drive.
Using RAID to "mirror" your hard-drive is a very-cool way to provide a "real-time" and "up-to-date" backup.
Should one of your drives suddenly "die", the other will continue to work, and you can buy another hard-drive, re-establish the "mirroring", and continue to work productively -- no fiddling with offline/stale backups.
Sep 18, 2009 | Gigabyte GA-MA790X-UD4P Motherboard
Connecting new hard drive
If the old one is still conected you can connect it the same way if not here is how to::
Well firstly they are 2 types IDE (large connector) and SATA (small connector)
IDE
of an ide cable has 3 jacks 1 for the main board and 2 for IDE drives
2 drive must be set to master and the other to slave
Set the drives by using the jumper on the back the instructions are written on the drives
Connect the Ide Cable and then the power and turn you system on
IF ITS SATA
connect the sata cable to both hard drive and main board
connect the power cable and your done!!
NB:: sata ports are labeled SATA 1 SATA 2 etc
IDE are LABELED IDE 1 IDE 2
Ide is a large grey cable black connector SATA is usually orange or red and small
Oct 26, 2008 | Gateway (M520HD80G) Hard Drive
Motherboard problem
Hi Conor, every SATA drive is a master drive. With that in mind you're SATA must have windows installed on it. Please disconnect the data cable & power cable's from the IDE drives.
(Do not reconnect either IDE untill you have finished).
Install windows on the SATA drive. Install all the needed drivers, than update windows. When finished Check the pin setting on the IDE drives. Set one as the "master with a slave" & the other as the slave. Than you can add both into the system. If you had windows on one of the IDE's just delete the root files on that drive so it does not conflict with the new windows on the SATA drive. Go in the bios make sure you have the SATA drive as the boot drive & not either of the IDE drives. If the system still shuts down after all this, try replacing the data cable for the IDE drives (Both should be on the same data cable). Swap the power connector from the CD-ROM drive to the IDE.
Next, if you're system still shuts down after adding either of the IDE drives, than swap the ports. Connect the CD-ROM to the primary IDE port on the board & the IDE hard drive to the IDE slave port. (This is for testing only). Double check all power connections from the power supply to the motherboard. Leave the case opened. Look at the board when booted. Watch for the the case LED's lighting up & flashing cr-rom's LED flashes, look at the CPU fan. Make sure all fan's are running & listen for the drives running.
Let me know if anything changed or not. Post any thing odd or if any thing did or didn't work & I'll go from there. Everything is a test & error soulation. One change at a time.
Mike
Jun 27, 2008 | Gigabyte Motherboard, GeForce 7100, Core 2...
HOW TO CONFIGURE RAID
I needed to see your board & can at this site. http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=493&DetailName=Manual&MenuID=1&LanID=0
This is good for you as well. It shows me & you that your board can handel 4 each DMA/ATA-133 (Ultra) IDE Hard drives/ CD/DVD drives IDE-1Primary & IDE-2 Primary Slave. Each can run 2 IDE drives. Also 4 each Serial ATA SATA's. Two separate SATA controllers with integrated PHYs, each supporting two
drives in master mode. In your manual on pg.32 & 33 will help you to setup a RAID if you wish. Or you can also set the RAID to IDE which will allow you to use all your SATA hard disks as a single drive without setting up a RAID system. The site above supplies all your drivers needed & manual. If you need more help please let me know here.
Luck!
Please vote......
Jan 13, 2008 | EliteGroup NFORCE4-A939 (NFORCE4A93910)...
Sata , ide
Initially connect only the sata drive from which you want to boot the OS. Establish the OS successful operation from this drive. Then connect the remaining drives in conventional way or the RAID array you want to have.
Oct 25, 2007 | Computers & Internet
Sata, ide
Update: SATA II drives do have jumpers to make them backwards compatible with 1.5 Gb/s (SATA II drives are 3.0 Gb/s). So if your system is older and can only handle SATA (first Gen) then you have to add a jumper (Seagate has the jumper setting on the drive but sometimes supplies no jumper i.e. you have to have your own).
Sep 30, 2007 | Computers & Internet
Sata & ide darddrives
Hi, All dual drive capable boards read the SATA first, just make sure both SATA & IDE are enabled in the BIOS, load your O/S as normal this will load on the 1st SATA and the others will be auto detected as drives D and E, the IDDE will be E by default. Regards mistyman
Sep 22, 2007 | Soltek SL-75FRN2-RL Motherboard
ASUS P5VDC-X Motherboard Logo
177 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
