Question about Mitsubishi VS-5043 50" Rear Projection Television
TV image is one greenish color image hardly visible.
I have a Mitsubishi WS-65909 and the picture started out with double images that were washed out and bent. It looked like one of the colors was missing also. It has gotten much worse. Now it is all just one color and no image visible. Is it beyond repair and if not, what tools/equipment would I need to fix it? Thank you DaveP.S. If it is fixable I will get the tools/equipment and use your to do it.
  • wdavidrankin Jun 30, 2009
    I pulled the circuit board tray out and discovered that there was a plugged that had come loose. I put it back in, now the picture comes on. There is still the problem with the two different pictures. I understand that is is a common problem with the Convergence chips. But looking at the circuit boards, I don't see any big chips. I think I need a schematic. I would like your help. Do I need this schematic? I would like all the tools and be ready to fix it. Please let me know how I can get this all together so that I can best utilize your assistance. Regards, Dave
    I found the chip. I read that there are two fuses that look like transistors that should be checked and that one should show that it has gone bad. Those I can't locate and I am wondering if this is over my head. I would really like to do it myself.
  • 767 Answers
Two big chips on one seprate pc board
sk_ _ _ _ _ _ ? get the number google it
cost about 10.00- 20.00 etch order them
go to raido shack get solder soldering iron
40watts and solder braid (whicket)
remove the solder pull the chips ,one
small screw holds them to the heat sink
replace with ordered parts set up
covergance Done. you just saved 300.00
Posted on Jun 30, 2009
  • Rod Sims
    Rod Sims Jun 30, 2009
    there are three tubes R,G,B there is a heavy black wire
    coming from all three, High Voltage . Then there is a smaller
    bundle of wires coming from the same . they all connect
    to the Convergence Board , or very near to the two large
    semi square black modules that are attached to a heat sink
    find out what p/n ie sk_ _ _ _ _ _ stk_ _ _ _ _ _ there
    both the same.
My Tv started shown double image yesterday. What
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 13, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Hello, I have a mitsubishi ws-65907, It has
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Your TV2_bing.gif may have one or more of the following symptoms....
Apr 07, 2010 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi WS-55511 convergence problem?
No,need to diagnose.It a 100% convergence problems.Convergence problems very easy diagnose.The picture look like 3D,colors lines don't lines up.Fuzzy,out of focus.Convergence controls don't work to lines up any colors cross.The tech is cheating u if he said cost $125 to diagnose.If u know how to solders u could fix this convergence problems about $100.U can buy a convergence kit at Websites Tv repair World.com,Tvrepairkits.com.The shop everythings fix parts and labors only $300.
Mar 16, 2010 | Mitsubishi WS-55511 55" Rear Projection...
The picture is showing a double image and is distored.
The problem you are refering to is more than likely a convergence problem. The convergence circuit in your tv is controlled by an IC (integrated circuit) stk392-110 and it makes the 3 colors (red, blue, green) line up/converge together to create a clear picture. You'll know when this part needs to be replaced because the picture you see is 3d looking and possibly bowed on the top or bottom or on the sides in any or all 3 colors.
Jan 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Blue, green, red parallel curved lines at top of screen
hello sorry but it sounds like the chip have gone again when you replace these chips you might have to change the resistors and the 2 capacitors as well
shaun
May 08, 2009 | Mitsubishi WS-55905 55" Rear Projection...
Replaced Convergence but pictures still display with double images
i went to converge my mitsubishi ws 73903 and the blue line wont go down to match the other ones
Oct 09, 2008 | Mitsubishi WS-73903 65" Rear Projection...
Mitsubishi Daimond Series 65" Model#WS-65909
Most common repair is one or two open fuses in power supply
and bad convergence Ic's = expensive repair.........Also, have
the tech check for coolant leakage from CRT's...........T.
Dec 30, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi ws-65909
I suspects you have bad convergance IC's
It takes a good tech around 3 or 3 hours to take the old ones out and solder in the new ones. Also, it is likely one or two resistors are burnt and will need replacing as well.
Don not run the tv till you have it fix you will cause more damage!
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 30, 2007 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi platinum plus ws-55857
Solder connects = temporary fix.......Replace IC's..best
order two STK392-570 good quality.....16 to 22.00 each
...............................T.
Dec 26, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Onscreen menu appears greenish
call tech and suggest to balance your screens ..they will know the procedure.
Nov 02, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Televison & Video Logo
111 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
