Question about Kubik Digital Electronics Kubik Evo 8Gb Mp3 Player With Radio And Expandable Microsd/Sdhc Slot - Black
How do I put MP3 files on Kubik Evo 4gb? - Kubik Digital Electronics Kubik Evo 8Gb Mp3 Player With Radio And Expandable Microsd/Sdhc Slot - Black
    New Friend:
  • 3 Answers
The easiest way is to plug it into a PC - any Mac, Linux or Windows machine will see it as a USB flash drive. Copy the mp3 files you want to listen to into the Music folder. The trick is when you disconnect - unmount the flash drive (or eject it if using Windows) and then wait for the Evo to switch from USB connect symbol to the charging symbol. If it does not change after 5 minutes, unplug it, flip the side switch to off, then back to on and it should be OK.
Posted on Aug 01, 2014
SOURCE:
How do I fix my Kubik Evo 8Gb? The software doesn't work. The screen is black and I can not get access to the menu. My files are ok I can see them when I plug it to my computer. Thank you
Your electronics are ng. U might try to reset unit by doing a hard reset to see if that clears up the anomaly. If not, replacement, not repair, is in order.
Aug 27, 2016 | Kubik Digital Electronics Kubik Evo 8Gb...
Wont turn on when not plugged in. but will turn on if charg plug is plugged in and you turn on the power switch and unplug the charger it will stay on but wont play, keeps coming up format error.
Customer Reviews: Kubik Evo 8GB MP3 Player with Radio ...
www.amazon.com/Kubik-Player.../B0041MMMWW
Amazon.com, Inc.Find helpful customer reviews and review ratings for Kubik Evo 8GB MP3 Player with ... Con's - Wonder if some of these items can be fixed with a firmware update. ... Just push the main button (or any button) and it will turn on and function as usual. ... 2) Play while plugged in charging works with the wall charger, but still NOT ...
Evo won't charge via USB ' Android Forums
androidforums.com > Android Phones > HTC EVO 4G
Jun 29, 2010 - Whenever I plug in my Evo, I select Charge Only (or if I do nothing, it selects Charge. ... If I turn off my Evo it charges from the USB fine. ... Check your computer's stats... what does it say about its USB status when your Evo is plugged in or ... I had a problem a while back where it would charge via USB, but not ...
Dec 29, 2015 | Kubik Digital Electronics Kubik Evo 8Gb...
When I try to play a track I get a message "No files"
Try formatting the sd card to fat 32 before saving the mp3 files to it. Also try using a high quality low capacity sd card. Scandisk 8gb for example.
Jan 05, 2015 | Kubik Digital Electronics Kubik Evo 8Gb...
Deleting music from kubik evo 8gb
Select track to be deleted, press and hold the volume button, a box will appear asking if you want to delete, select yes and press the large centre button,it will then state file deleted .
Sep 28, 2014 | Kubik Digital Electronics Kubik Evo 8Gb...
How can i get files back on player?
I have the same problem. I used Ubuntu to put files on, then erased the "Dan-o" directory. After that I could not auto mount the drive. I tried to reformat the drive using a Win7 machine, and that worked, but Ubuntu can not see the drive. I have not yet tried using an SD card.
I send a message to Kubik support, but got no reply. If anyone knows how to recover the player I'd appreciate knowing how to do it!
Jul 05, 2014 | Kubik Digital Electronics Kubik Evo 8Gb...
Why am i having transferring files problem with kubik evo
What are you using to transfer the files?
Attach the device to your computer using the USB lead
Wait for your computer to find the device
Then use Windows Explorer to drag and drop the files onto the device
Make sure the files are in a compatible format to the device
Once transfered power up the device and rebuild the Index of Music using the option under the music menu
Jun 22, 2014 | Kubik Digital Electronics Kubik Evo 8Gb...
How to put a playlist on a kubik evo
Try rebuilding the Music Index using the option under the Music Menu when the device is powered on
Apr 12, 2014 | Kubik Digital Electronics Kubik Evo 8Gb...
I have converted a film to the correct avi format/size/bitrate/audio..etc etc and tried every configuration and even contacted kubik. the film will not play due to unrecognised format
You can install the software off the Kubik site
AVI Converter Kubik Digital and this has the advantage of being set to the correct size for output (160x128) but I have had mixed success with this. Some files have worked fine, others just stall and the batch processing feature does not appear to work (at least for me) so I am searching for more reliable alternatives.
Oct 29, 2013 | Kubik Digital Electronics Kubik Evo 8Gb...
Kubik Digital Electronics Kubik Evo 8Gb Mp3 Player With Radio And Expandable Microsd/Sdhc Slot - Black Logo
642 people viewed this question
Top Kubik Digital Electronics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Kubik Digital Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
