Question about Acer Aspire 3100-1405 Notebook
Acer 3500 bluetooth says no device when search button is pressed
I have a bluetooth button next to my Lan button. The Lan works but the bluetooth says on screen 'no device'. There is a blue tooth symbol next to clock on screen and its red. I'd like to know how to activate it. Thankyou.
  • 255 Answers
Download this bluesoleil 6
http://www.bluesoleil.com/download/index.asp?topic=bluetoothsoftware
install it, your bluetooth will work.
Posted on Jun 30, 2009
My biuetooth does not work properly in my acer aspire5750
Activate the Bluetooth features of your Acer Aspire to unlock your laptop's wireless function. Bluetooth technology allows your computer to control and share data with external devices without having to use a connection cable or download drivers.
In order to establish the connection with other enabled devices, you must first enable the Bluetooth antenna so other devices can locate your computer.
Press the "Bluetooth" button found just above the keyboard.
The LED above the button should illuminate.
Click "Start," "Control Panel" and "Add a Device."
Your Acer scans for other Bluetooth devices in the area.
Click the name of the device in the window that appears, and click "Next" to establish a connection with the external device.
Microsoft bluetooth support
http://support.microsoft.com/kb/883259
Aug 05, 2013 | Acer Aspire 5500 5570-2609 Laptop
Wen i was installing bluetooth driver on my extensa 5620 it was saying that no bluetooth device found please make sure that it ws enabled....but how to enable it..?
hi, look for the button than turns your wireless lan on, most systems that's the same button that turns the bluetooth on. You can run a search on the start menu search bar. Just type bluetooth into the bar and everything related to the bluetooth will come up.
hope this helps
pls rate this
Jul 06, 2011 | Acer Extensa 5620-6119 Notebook
I am using Acer Aspire 3500. I have a bluetooth button next to my Lan button. The Lan works but the bluetooth says on screen 'no device'. There is a blue tooth symbol next to clock on taskbar on screen...
In order to use the Bluetooth connection, you have to have a Bluetooth device to pair with your computer. Put the device in pairing or listening mode, then right click on your Bluetooth icon and choose the option for searching for a device. (You may be required to enter the device's passcode -- if you don't know it, try 0000.)
Dec 27, 2010 | Acer Aspire 3100-1405 Notebook
Acer Travelmate 5620 bluetooth button won't turn on
Do you actually see the Bluetooth device in device manager? Normally if it's not turned on it won't appear in device manager. The next thing I can think of is that if the Bluetooth module was not turned on when you loaded the drivers then they won't work.
And lastly the module may have come lose or unseated from the slot. Are you absolutely 100% sure there's Bluetooth hardware on this laptop? Is this built-in or a USB dongle?
If built-in have you turned it on? Acer uses a slide switch to turn Bluetooth and Wireless LAN on and off.
The first thing you probably need to establish is whether the laptop has a Bluetooth module fitted. Plenty of Acer laptops support Bluetooth in some markets and not in others and actually have slider switches to turn Bluetooth on/off but don't have the Bluetooth module fitted.
Does the unit say that it supports Bluetooth on the sticker attached to the front of the laptop? The models that have Bluetooth typically have this listed on these and will also list it on the packaging that came with the laptop that lists its specs. If it doesn't mention it odds are it's not fitted.
Acer laptops have the Bluetooth buttons, but not always have the Bluetooth Module. Check the bottom white sticker for a Bluetooth symbol under the laptop. If you do not see it, there is no Bluetooth. Also, if you press/move the Bluetooth button, and the light doesn't turn blue, there's no Bluetooth module with your laptop (only the button), so your laptop did not come with Bluetooth.
Also, you can add Bluetooth, but you need to be able to take the laptop apart to a certain extent, such as taking off the cover (top portion), keyboard, and maybe the speakers. The Bluetooth should have a 4pin, 6pin, or 8pin Bluetooth Cable connected to a Bluetooth module. You need to purchase the Bluetooth module, and install it, but you need professional help for that.
In case your laptop won't have a Bluetooth module fitted. The switch doesn't mean anything, it's present on all Acer laptops whether they have Bluetooth fitted or not.
You can buy the module as a spare part from Acer and fitting it is easy however buying a cheap USB Bluetooth dongle will be a cheaper option.
Thank You for contacting Fixya.com
Feb 02, 2010 | Computers & Internet
Where or how do I find the wireless switch?
On the front of the laptop there is a Bluetooth button, and a wireless button.
On the front edge of the laptop, starting from the Left;
Speaker, Bluetooth button, Wireless button, Power indicator light, Battery indicator light, Microphone-In jack, Line-In jack, Headphones jack, Speaker.
The Bluetooth button has a light in the middle of it. If the light is on, Bluetooth is enabled.
If it is on, turn it off. (Push the button in, let go. The light should be off)
The Wireless button, also has a light in the middle of it. If the light is on, wireless is enabled. Be sure it is on.
During cleaning the virus out, the Bluetooth, and wireless LAN driver may have been corrupted.
Here is Acer Support, and the Drivers Download page,
http://support.acer.com/drivers_download.aspx
On this page you are going to find the wireless LAN drivers, for your Acer Travelmate 4200 PC Notebook.
1.In the Select Product Family box, Left-click on Notebook.
Wait a second, the next box will come up.
2.In the Select Product Line box, Left-click on
Travelmate.
3.In the Select Product Model box, scroll down, and left-click on Travelmate 4200.
Use the blue bar, on the right side of the Driver file name box, and scroll down.
You will see there are 3 wireless LAN drivers listed.
1.Wireless LAN - Atheros
2.Wireless LAN - Broadcom
3.Wireless LAN - Intel
Left-click on the orange box, to the left of the appropriate wireless LAN driver you need.
(Orange rectangle with down arrow pointing to a line)
A small window will come up. There is a circle to the left of - Open with,
and a circle to the left of - Save File.
Left-click on the circle to the left of - Save File.
Now go down to the right, and click on OK.
This file will either go to your Documents folder, or it will go to your desktop screen.
In either place, when you see the file name, Double-click right on it.
The Installation Wizard will come up.
Click on Next, Next, and Finish.
(Bottom of each window)
Restart your computer.
To know which wireless LAN driver you need, (Atheros, Broadcom, or Intel), go to Device Manager.
1.Left-click on Start, (Vista logo button)
2.Left-click on Control Panel
3.Left-click on System and Maintenance
4.Left-click on Device Manager
(If you are prompted for an administrator password, or confirmation, type your password)
When Device Manager loads, look at the file tree before you.
Go down to - Network adapters, and left-click on the + sign to the left.
Across from wireless LAN you will see the name.
Dec 25, 2009 | Acer TravelMate 4200 Notebook
How to enable bluetooth
First of all you need to connect bluetooth device to the laptop because most Acer laptops don't usually come with bluetooth device but they have the software/driver that will make bluetooth to work on it. So, I will advice that you get an external bluetooth device connect it to your laptop, the bluetooth application will make the bluetooth device to work. Thanks
Sep 30, 2009 | Acer Aspire One PC Notebook
I press the bluetooth button on my laptop and red cross apears
Acer currently maintain a wide variety of models of notebook computer in the current range, and for any given range of notebooks the onboard options may vary but the case remains constant across the range for each series of notebook. This means that some machines will have case buttons that lack functionality. The most common of these are the Bluetooth and Wireless LAN toggles on the front of many of the cases. You may have the button but the device isn't there, it is only on the more expensive models. Easily fixed by getting a USB Bluetooth adaptor
Aug 09, 2009 | ASUS Z83V Notebook
How can i enable the bluetooth in acer extensa5230
ur blue tooth driver is not installed properly....go to controle pannel....click on add new hardware...then add ur blue tooth device and provide path of cd to install it
Mar 10, 2009 | Acer Extensa 4620 Notebook
Is Acer Aspire 4720z equipped with a built in blue tooth device
The quickest and easiest way i have found is to press the Fn button + the one that turns on your wireless networking if you have one.
But i looked up your system and it says it comes with blue tooth.
"Communications Intel® Wireless WiFi Link 4965AGN network connection supporting 802.11a/b/g/Draft N wireless LAN, Acer® SignalUp technology for enhanced antenna efficiency
or
Intel® PRO/Wireless 3945ABG network connection supporting 802.11a/b/g wireless LAN, WI-FI CERTIFIED™, Acer® SignalUp technology for enhanced antenna efficiency
Bluetooth® 2.0 + EDR (enhanced data rate) wireless PAN (select models only)
Gigabit LAN, Wake-on-LAN ready
V.92 56Kbps* data/fax modem, PTT (postal, telegraph, telephone) certified in select countries, Wake-on-Ring ready
Acer® Video Conference with integrated Acer® Crystal Eye webcam supporting Acer® PrimaLite technology, which consists of a premium sensor, firmware and lenses to provide superior video performance under low-light conditions (select models only) "
I found this here
Feb 27, 2009 | Acer Aspire 4720 Notebook
Do i have bluetooth?
Well the Acer site says that it has built-in bluetooth!(Aspire 1690) If you go to device manager (Right click on my computer, click on manage. Under System Tools in the left pane click on device manager) you should see one of the device categories there as Bluetooth, if you don't see it and see a yellow icon that means you might need to install the bluetooth drivers! If you don't either you might need another component(bluetooth hardware) for the bluetooth to work! hope this was helpful regards, babb
May 03, 2007 | Acer Aspire 1690 Notebook
Acer Aspire 3100-1405 Notebook Logo
689 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
