Question about Texas Instruments TI-83 Plus Calculator
Random symbols, upside down and on the bottom of the screen
I did not drop it, it worked fine the other day. Turned it on in class today and when i type aything in i get randm symbols or the numbers are on the bottom of the screen some upside down some right side up on a different line. Never seen anything like this, changed batteries tried clear and reset ram when i was able to kind of understand what the calculator was trying to say.
  • Texas Instru... Master
  • 8,073 Answers
You should reinstall the system which you find here
http://education.ti.com/educationportal/downloadcenter/SoftwareList.do?website=US&tabId=1&paneId=2
Use the link below to install TIConnect software
http://education.ti.com/educationportal/sites/US/productDetail/us_ti_connect.html You can also download the latest OS there.
Install TI connect on your computer and run it to open the main Window. Then connect you calculator to a USB port and, in the TIConnect main window Click the TIDeviceInfo icon. Software will try to retrieve the info. If it does your calculator is fine.
If it tells you Device Not found , Click communication settings in same pop up window where it said Not found, and Select Device, Select Cable, Select Port and Click OK..
If you are lucky and it works, you should reinstall the OS, which can be downloaded from education.ti.com. You drag and drop the OS on the TIconnect main window. Calculator must of couse be connected to computer.
If you have problem with TIconnect, use the calc-to-calc cable to transfer the OS of a working calculator. Yous should be on Receive mode [2nd][Link] --->>Receive. (When both calculators are ready hit enter.) The other calculator, you guessed exactly right, must be on Send [2nd][Link][SEND][G:SendOS]. (When both calculators hit [ENTER])
If all that does not work, then it may be time to head for a place of worship to pray for its resurection, or look for a repair shop.
Hope it helps
Posted on Sep 14, 2009
How do you fix your screen on your iphone 4 if it goes upside down
Multitasking bar, unlock rotation symbol will come up when you slide to right
Nov 30, 2011 | Apple iPhone 4 Black Smartphone
A bottle of water jumped into the bottom-edge of the laptop. Turning it upside down pours out few drops of water but some drops came out from the volume control ball headphone plug space and card reader...
If you have a small fan and can blow air across it for a couple of days you may find it works just fine once it's dry. Do keep the battery diconnected while you do this. Also, try to position it so that water won't run down toward the screen side of the case.
Jun 20, 2010 | Toshiba Satellite A135-S4527 Notebook
Epson P5000 won't switch one
its software have been frozen or crupted connect it to pc and upload a software
Mar 23, 2010 | Epson P-5000 Digital Media Player
Printer has been working fine. all of a sudden the paper started to load crooked and jammed. now it continues to do this...why?
Usually it's because something has fallen down the back where the paper goes. One person on here turned her printer upside down and shook it and a Bic pen fell out. I got one last week with a wood screw inside. sometimes I find push pins, candy or jewelry. If nothing comes out try looking inside with a light and small mirror.
Jan 25, 2010 | Lexmark X4650 InkJet Printer
Epson Stylus T10 printer prints out random symbols from PDF file
When you attempt to print, make sure you are using the correct printer. If you had an old printer before, its name will be still in the printers' list.
and unknowingly you may be trying to print with that printer. To check this:
Goto the File Menu -> select Print-> Highlight the printer you are currently using, and then Print.
I am pretty sure this will solveyour problem.
If it does, give a rating to this answer.
Have a good day.
luciana44
Jan 06, 2010 | Epson Office Equipment & Supplies
Screen on 7550 is upside down
there is a Windows XP setting to invert the picture (I guess it is if you hang the CRT upside down from the ceiling). I don't remember the key presses needed, but check under Properties for the CRT
Aug 19, 2008 | HP Compaq FS 7550 17" CRT Monitor
Random characters lines and pixels
I've had a similar problem in the past with my TI-86. It still happens sometimes when I don't use it for a while. To fix it, all I did was set the screen to its darkest setting and left it on for 10 minutes (keep it from turning itself off, by pushing buttons every few minutes.) It works great, and the calculator is fine unless you leave it unused for a month or so. A similar solution may work for you.
Dec 12, 2006 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
287 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
