Question about Maxtor OneTouch USB (A01B120) 120 GB Hard Drive
The blue lights do not go on when I power on the HDD. I can hear HDD humming but just can't get a light to indicate its working. As a result I also can't get my Vista laptop or XP laptop to recognise the USB when I connect it to the either computer. Any ideas what's wrong ? Is the case broken ? If so surely I can put the HDD in another case ?
  • 846 Answers
Sounds like a broken power supply. If you want somebody to repair or replace it for you there is Hard drive repair. Also there is good information on hard drive repairs on hddguru.com.
Posted on Jul 04, 2010
Nv52 has the power light come on but no display or hdd light
cmos battery being charged. You can keep the laptop on to fully charge it or replace it with a new cmos battery.
Mar 15, 2012 | Gateway Computers & Internet
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I have a 2TB hdd kiosk ls memup external disk. It worked ok until now. Suddenly when i turn on the hard drive, the blue activity indicator light turns on for a split second and then turns off immediately,...
The board power seems to be lost power/damage.
1. try using another adaptor/charger with the same power consumption eg.12v/1Amp . if still remains >>>
2.disambled the case >>> release the hard drive
3.buy a new case external with same capability up to 2TB ( 7200rpm )
4.Check your hard drive for corrupt by entering commad prompt . type: chkdsk /f
akee_akee@live.com
Aug 17, 2011 | Computers & Internet
What does the blue blinking light at the very bottom, under the blue power button indicates?
According to the Dell 531 owners manual:
"Drive activity light-
blue light - A blinking blue light indicates the computer is reading data from or writing data to the SATA hard drive, CD, DVD or HDD."
http://support.dell.com/support/edocs/systems/inspd531/en/OM/appendix.htm
Safe to ignore. It will blink even when the computer appears to be idle.
Aug 15, 2011 | Dell Inspiron 531s Desktop Computer
My simple tech 320GB external hard drive will not work the red light is on but the blue light is dead, nothing is happening.
Hello mbrin72,
If there is no activity when powering on your external drive, this usually indicates a failing drive. If you do not hear a hum or feel vibrations, this means the drive has gone bad.
Check the warranty of your product. The manufacturer may replace it at no cost. (other than shipping)
If recovering the data is of high importance, I recommend this service: http://www.datarecovery.net/hard-drive-recovery.html
I highly recommend getting a quote. Although, they do not charge if they can not recover your data.
Hope this helps!
Jun 29, 2011 | SimpleTech Computers & Internet
I have a Dell Latitude D830 Laptop. One day i found out i can not turn on the laptop. The power light is on, and so the HDD light indicator.. and the caps lock light is blinking. But the screen keep...
Have you tried it with an external monitor?
If this does not help. then you may have a motherboard problem. The Dell motherboard is easily replaced and you can get one on e-Bay
Jun 07, 2011 | Dell Computers & Internet
My ps3 wont power up
try powering the system up by HOLDING the on;off button , it will reset all your audio and video settings . then plug the system using the AV cables (default) .
else, you should take it to an assastance centre for hardware issues checking . can be a problem with your RAM or GPU units that makes the system unable to startup it's firmware .
Jul 27, 2009 | Sony Playstation 3 (PS3) Console
Maxtor external HDD not detected by Vista
try to format it.it might need a quick format for you to use it. if still doesnt work check for the sata,pata cable that connects your motherboard.
Apr 30, 2009 | Maxtor Hard Drive
Dell D600 latitude will not power up
you can try to replace the motherboard, which is apparently totally UnHappy
Mar 16, 2008 | Dell Latitude D600 Notebook
Drive Being Recognized as Removable Disk
Same issue with my 500 GB TFD500U16. A little more description is that my PC is detecting the power when turning on the drive and the HDD itself is spinning up. Also the Blue light that normally indicates HDD activity by turning Red no longer shows activity but just stays Blue. This indicates that the data side of the HDD is not seated properly. Since mine is out of Warranty, I took it apart and found this to be the exact case.
! ! ! ! Please perform this at your own risk ! ! ! ! Especially if your warranty is still in effect! ! ! By loosening the HDD mounting screws inside that will allow the connection to seat properly and data to be seen.
Dec 16, 2007 | Fantom Titanium II (TFD500C16) 500 GB USB...
Maxtor OneTouch USB (A01B120) 120 GB Hard Drive Logo
94 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
