Question about Maytag MED9600S Electric Dryer
Flashing "touchup" and dryer won't start
I have a Maytag Epic front load electric dryer, model number MED9600SQ0, that I bought new 4 months ago. It will not do anything. The light for the "touchup" cycle keeps flashing. I turn the knob to a different cycle and nothing happens.
  • 5 more comments
  • BigJay462 Nov 11, 2007
    I have the exact same problem
  • Homealone Nov 14, 2007
    I called maytag, they sent someone out that looked at it and said, "Yup, that's what it's doing. We'll have to order a new control panel." This will take at least a week then they will come back out and install it.
    Maytag said they would send it out priortity and get it to me in 2-3 days. We'll see.
  • pigh Feb 12, 2009
    Same problem here, the unit is 17 months old, touchup is lit, but no start! I will contact a repair, I did try the unplug and off switch suggestion with no effect.
  • mailbox7644 Apr 26, 2009
    I, too, have a flashing "touchup" and the dryer won't start. Why doesn't Whirlpool issue a recall on this problem. Obviously, I am not the only one with a faulty control panel.
  • Anonymous Mar 15, 2014
    When I press start, after a few second delay, I hear a click and the F 01 fault code displays. Prior to it not working at all, we often had slightly damp loads when cycle completed and had to run again to get fully dry.
  • Anonymous Mar 16, 2014
    It is flashing F-01 and will not start.
  • Anonymous Mar 21, 2014
    Over heats at times
Yes the unplug for one minute and press off button once then again for 10 seconds absolutely worked for me!! Yay thank you fixya!!! and Bigjay!!
Posted on May 25, 2012
  • 25 Answers
This unit should be on warranty, call back the seller for service.
Posted on Nov 08, 2007
  • 3 Answers
What I did was unplug it for 1 min., plug it back in. Push the "off" button once, then push the off button again and hold it for 10 seconds. This is supposed to reset the computer. It worked for me.
Posted on Nov 14, 2007
What does error f 1 mean?
Type Maytag Epic Z error into YouTube and see if the video comes up, thanks
Jun 21, 2015 | Maytag Epic z Front Load Electric Dryer
Maytag epic electric dryer takes a long time to dry clothes
check your vent by removing the vent from the back of the dryer run a normal load in the dryer and if it runs normal you have a crushed vent hose or it is plugged somewhere
Nov 17, 2013 | Dryers
Maytag epic front load electric dryer is turning but only blowing cold air ?
Unplug dryer. Remove heater element, and inspect element for damage. Use an ohm meter to check for continuity. Should have some resistance. Should not be open or short.
Oct 18, 2013 | Maytag MDE9700AYW Neptune 174 Electric...
I have a slow drip at the bottom of my front load washer door (Maytag Epic Z). It leaks through the bottom of the door and drips down the front of the washer onto the floor. Has done it since I bought it...
Yes the seal might need replacing. but in my experience a simple strand of hair caught on the seal will make it leak. So i suggest that you try thoroughly cleaning the seal fist. If its needs to replaced, its not that difficult, but its kind of tricky. Check if your machine is still under warranty by contacting the manufacturer. hopefully it is and they will change for you for free. If its not under warranty let me know and i'll try my best to give you detailed instructions on how to change it.
Feb 06, 2011 | Maytag Epic 7.0 Cu. Ft. Super Capacity...
Maytag washer and dryer Epic Z
Just go to and go into the service tab, you will be able to download and print it from that page
Jun 11, 2010 | Maytag EPIC MFW9700S Front Load Washer
Washer flashing 02 F. Maytag epic washer won't spin -flashing 02 F about 15 minutes into the cycle. We just had new electrical components put into it.
You need to use the HE detergent. I believe that is a drain problem. By using the regular detergent that causes more suds and in turn clogs your drain
Jul 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
I have an Maytag model # MAEDZ600TW2 Epic Z Electric dryer , the drum turns but no heat , circut breakers were checked , lint screen is clean , btw , date of purchase was 3/23/09
There are 2 common reasons your dryer will not heat.
1. Your limit switch is out on the dryer not allowing the heating element to switch on.
2. Your heating element is out.
before you try to fix this yourself it should be covered by warranty.
Apr 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
I have a maytage front load washer,it is stuck in control lock ,and i can't get it to do anything. the model#is mfw9800tq0. washer
med9600sq0 model #
as per maytag website=hold the "cycle signal button for 3 seconds" and it w i l l unlock. I just did it!!!
Aug 02, 2008 | Dryers
Maytag MED9600S Electric Dryer Logo
563 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
