Question about NetGear WGR614 54 Mbps Wireless Router - Wireless router - EN, Fast EN, 802.11b, 802.11g
How to set my xbox360s NAT to OPEN Witha netgear WGR614v7 Router?
Okay so bassicly my problem is, is that my xbox360 for the past 3 weeks has set it self to a 'Moderate' NAT for some reason I am unaware of. I would like to know however how to fix this and configure my router so it doesnt happen again.
Details:
SURFBOARD Modem, ISP : Bigpond Telstra, 54MBPS Netgear WGR614v7 Router, IP of ROUTER: 192.168.1.1, IP of XBOX: 192.168.1.4, IP of PC: 192.168.1.3 and router does have secerity set on it.
PLEASE HELP! THANKS IN ADVANCED!
  • 60 Answers
Basically you have to open the application port of XBOX on your router. To do that you have to access the router's GUI and forward the ports. To access the router go to http://192.168.1.1 username is admin and password is password by default, click the port forwarding tab and open this ports
  • TCP 80
  • UDP 88
  • UDP 3074
  • TCP 3074
  • UDP 53
  • TCP 53
  • Click add customer service and type xbox for service name and the IP address of the xbox.
    Posted on Jun 30, 2009
    NAT IS STRICT
    STEPS TO CHANGE NAT SETTINGS TO "OPEN":
    1- Using your Browser, Log on to your router (by normally typing in the 192.168.1.1 address check your router's manual to see what the default gateway address)
    2- If you already know how to log in to your router, then skip this step. If you have never logged on to your router then more than likely you still have the default initial log in credentials (username: admin - Password:1234 ..... Again check your router's manual to be sure). The minute you log in you need to change that password immediately, most network-savvy folks know that 90% of the people out there never reset their router's initial password and they can log on and make any changes to suit their needs, including locking you out of your own router.
    3- Once you are logged in, you should be able to find two advance settings (One if for NAT - and the other is for Upnp)
    4- Let's start with the NAT setting changes, and we will move on the Upnp at the end. I have personally tried the NAT setting changes and it didn't fix anything, I still had a "Strict" NAT setting on my xbox360, Only when I checked for the Upnp "allow authorized incoming traffic" options when the NAT settings on my XBOX finally came back as "Open" and not "Strict". But I will still explain what I did anyways with the NAT table cause I know it may work for some other routers.
    5- So what I did with the NAT setting is this. I located the NAT advanced setting on my router, I click on the NAT (Edit List setting) or whichever link/button you have on your router advanced NAT settings to access the table needed to open certain ports (TCP and UDP - 88 & 3074) .
    6- You will need to find out what the static/dynamic (preferably Static) IP address you xbox360 has. To do so, go to the Dashboard, go to the Console settings page, and click on the network settings to see the IP address (should be something like 192.168.1.x). You will need that IP address to enter into your NAT table on your router.
    7- Once you got your XBOX's IP address enter it in the NAT Port Forwarding table (From - To - IP address: those are the 3 fields you should have on the table if you are using SUA NAT)
    8 - In the first line enter 88 under both "From" and To" fields, then enter the IP address of the xbox in the field where you are to enter an IP address. (this is for UDP port)
    9 - Repeat the same step for port TCP (which is 3074)
    10- If these changes do not help open your NAT settings, then try the Upnp option. Click on your Upnp Advances settings and click on the "Allow Traffic" option, this is mostly secure because you are only accepting the incoming traffic that matches your outgoing traffic.
    Mar 02, 2011 | Belkin Basic Wireless Router
    Xbox360.cant get in to games online.my nat is saying strict,when before it was open
    Your IP address may have changed or ports need to be forwarded in your router. Follow this guide from Microsoft to solve the problem:
    http://support.xbox.com/en-us/pages/xbox-live/troubleshoot/connection-issues/nat-type-strict.aspx
    Jan 03, 2011 | Activision Guitar Hero Warriors of Rock...
    How do you change nat on my xbox360 cause i car'nt
    Set Static IP on Xbox 192.168.1.66 (depending on the type and brand of router) Gateway and
    - DNS 1 = 2.2.2.2
    - DNS2 = 2.2.2.3
    Mar 31, 2010 | Computers & Internet
    Xbox360/netgear WGR614 V9 connection issue
    Do you have encryption enabled on your router? If so you will need to enter the encryption key of the passphrase in the network setup of the xbox 360
    Sep 19, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
    Opening NAT for xbox360 on WPN824
    u need to loginto the router page
    on the left side of the screen u will see an option called WANsetup under advanced
    1.disable spi firewall
    2.nat filtering to open
    apply the setting
    it must work
    Dec 14, 2008 | NetGear RangeMax WPN824 Wireless Router...
    NAT settings
    The easiest way to fix this is to replace your router.
    Here is a list of routers that are Xbox approved
    http://www.xbox.com/en-US/support/connecttolive/xbox360/homenetworking/equipment.htm
    The model you mentioned that you have is not on the approved list from Microsoft.
    Here is the problem behind your Xbox connection
    http://www.xbox.com/en-US/support/connecttolive/xbox360/connectionmethods/troubleshootliveconnection-testnat.htm
    Jul 25, 2008 | Linksys (NH1005) 5x10/100 Mbps Networking...
    Nat type
    I have the same router (WRT300N) and this is what I did. I don't know if it will work for more than one Xbox360.
    - Go to the Setting of the router.
    - Applications & Gaming
    - DMZ
    . Enable the DMZ
    . Choice the Mac Adress under the Destination.
    . If you don't know the Mac Adress of your Xbox360 click on the tab: DHCP CLIENT TABLE
    .Now from there choice your Xbox360 ( the Xbox360 won't have a Client Name but hopefully you only have your Xbox360 and your computer)
    and now save your setting and restart your Xbox360 and there you go NAT open. This also help if you get any kind of  LAG while someone is on the computer using the internet, your Xbox360 will be high priorty to the router.
    HOPE THAT HELP
    Apr 05, 2008 | Linksys WRT300N Wireless Router
    How to Open NAT?
    Look for a setting like "Virtual DMZ Host". It's hard to tell for sure without knowing the make and model of your router.
    Jan 14, 2008 | Dell TrueMobile 2300 Router (000001)
    Xbox360 connection problem
    The generic connection and configuration document
    http://www.microsoft.com/windowsxp/using/networking/setup/xbox.mspx
    This is a good description of possible router options.
    http://www.ianarchbold.com/xboxlive/index.html
    If you need assistance setting this up in your environment leave a comment on this problem and I will respond.
    Dec 22, 2007 | NetGear WGR614 Wireless Router
    NetGear WGR614 54 Mbps Wireless Router - Wireless router - EN, Fast EN, 802.11b, 802.11g Logo
    493 people viewed this question
    Top NetGear Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
