Question about Honeywell Programmable Thermostat Heater
How do i remove my st699 honeywell programmer from the wall.just cant do it.
Because there are no apparent screws to remove the front of this unit it can be very confusing if you have not done it before. Underneath and to the right hand side you will find a small notch in the plastic, it can be difficult to see when the unit is on the wall, using a small terminal screwdriver push upwards on the plastic tab which locks the front in place and with a slightly larger flat bladed screwdriver prise the front off bottom first then the two locking tabs at the top.
You will probably find that the back case is fastened to the wall with two screws.
Replacement is simply a matter of snapping the front back into the case.
Posted on Sep 22, 2009
  • 3 Answers
In my case there was very little clearance below, so I used a have-duty unbent paper clip as a short tool to poke through the notch (it's at the back of the bottom of the unit, just where one of the possible cable entries is). The paper clip pushes a plastic clip, of the sort used in all sorts of clipped-together devices, not visible from the outside. In my case no need to pry with bigger screwdriver, easily pulled off by hand.
Posted on May 29, 2013
Manual says the plug in module can be removed by depressing a locking catch with a screwdiver...but where the catch is I don't know...not visible on mine. I also want to remove it to replace the battery.
Posted on Aug 25, 2009
    Problem Solver:
  • 12 Answers
Try their tech support - 1 800 468 1502.
Posted on Jul 23, 2009
Our heating and hot water keeps turning off
Sounds like a glitche in the thermostat. First, override the program & see if it does the same thing over the next few days.
Dec 11, 2013 | Honeywell Programmable Thermostat Heater
Can you replace a danfoss TP9 with a honeywell ST699
I believe the TP9 is a programmable thermostat.
While it appears the ST699 is a timer that connects to a thermostat.
So yes, they both control 230Volt boiler-and-pump. But there are differences.
Google search each item and include .pdf in search parameter to find product manual for each, and then compare wiring differences.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 19, 2012 | Honeywell Hardware & Accessories
Replacing an ST699 with a ST9400C following repl wiring diagram, but programmer does not come on. Is the diagram incorrect? Wiring colours do not follow any of the plans. Syst has room stat, cyl stat,...
Disregard wire colors. Instead wire by terminal designation. In other words :
Wire on "R" Terminal on old thermostat to "R" Terminal on new thermostat no matter the color.
Jun 14, 2011 | Honeywell Heating & Cooling
How do i remove the cover of my honeywell st699 programmer
switch of the power; use a small screwdrive to press down carefully into the three small slots (two at the top, one at bottom left) to release the plastic clips while easing the front panel towards you.
Sep 06, 2010 | Honeywell Electronic Programmable...
Hi I have a Honeywell st699 programmer for central heating and hot water. The only problem that we have is that we can not change the time on the clock. This means that we cannot set any programmes. Is it...
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Aug 17, 2010 | Honeywell Programmable Thermostat Heater
I've just moved into an oldish house and there is a honeywell heating/water controller installed. its quite old and i cannot find any identifying marks on it. It looks like a st699, 2 on/off per day. I...
If you go to your local home depot, and get a new thermostat, it will come with different diagrams for wiring in the instructions that are pretty easy to understand. I hope this helps.
Nov 04, 2009 | Honeywell Electronic Programmable...
Cannot get central heating working,for honeywell ST6400 programme
with y plan 3 connections on programmer HW on HW off CH on HW on to cylinder stat then HW call to Orange on Mvalve to power boiler and pump HW off to grey wire on Mvalve to close hot water CH to room stat common then heating call to white on Mvalve
Jun 13, 2009 | Honeywell Programmable Thermostat Heater
Replacing Honeywell heating progrmmer
yep the wires will hook up to the same designations, just write down what color was connected where. You will need to set the thermostat up for your particular situation...gas, electric, heat pump, ect. The installation maunel is very clear on this aspect so you should not have a problem.
Oct 30, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
3,628 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
