Question about Samsung DVD-HR735 DVD Recorder/HDD Recorder
Fan doesn't turn off in standby
Hi everyone
I have recently bought a used (6 month old) Samsung DVD-HR735 but have noticed a wierd issue with the fan not turning off when I put the unit into standby. According to the manual (and common sense), the fan should only run while the recorder is switched on. It continues to run for hours afterwards. However, if I unplug the mains power from the unit and reconnect it, it'll go into standby with the fan off until I turn it on and off again next time.
Please help me with this issue. Is there a fix, is this normal behaviour, or should I return it to the guy I bought it from?
HAve you checked to see if it is the fan or the actual rom drive that is spinning, I had this problem, email me for any help
Posted on Jun 04, 2008
My samsung dvd hr753 will not tune to stations? Our region recently switched to digital so we no longer have analogue signals. Could this be the problem?
Yes this is your problem that you no longer receive an Analogue Signal.
This unit doesn't contain a Digital Freeview Tuner so you will need to purchase some sort of External Digital Freeview Box to connect to this unit to enable you to continue recording on it.
Jul 11, 2011 | Samsung DVD-HR735 DVD Recorder/HDD...
Delonghi Floor heater
As its only 6 months old it should be covered by the warranty, you should be able to get it repaired by your dealer, with no cost to you.
Oct 29, 2008 | Heating & Cooling
Teac DV-L800 noise: fan?
this is a common [rpblem nut nothing to worry about they all have a slight sound to them if you send it back the new one will have the same problem everyone that i have brought has had a slight sound in the background but as long as the picture is not jumping or freezing then it is absolutely nothing to worry about hope this eases your mind hope this is some help to you but i would keep the one youve got as the new one will be no different...............................................
Nov 08, 2007 | Audio Players & Recorders
Fan on outside unit will not turn on, will run once you give it a spin with a screwdriver however will not turn on by itself. Changed the fan and the capacitor both out with new ones, i am baffled!
That is wierd. If the fan and capacitor is the same as the old one. Although I'm thinking of capacitor issue, you should take out the fan and capacitor and test it.
I hope this helps.
Jul 01, 2009 | Heating & Cooling
Problem with overheating.
Hi Dear. Always Pick n Place notebooks very carefully. When need to pick with both hands you can pick it in any direction but when need to pick with single hand, always use vertical position, without pressing and forcing any area. Place it on any flat surface where you are sure that exhaust system of CPU's fan is well ventilated. Heating problem may occure due to many reasons. Verify CPU fan function in BIOS, Clean CPU cooling fan and exhaust system with Electric Blower. NEVER use continuous charging, plug out charger wire when battry is 100% full, charg again when low battry alerts. This will increase battry life & backup time.
Apr 15, 2009 | Dell Inspiron 1525 Laptop
Hi, I have a Samsung HLP 4663W TV and cannot get it to power on. We bought it used about 4 months ago, but has been fine.  Did not notice any problem when we shut it off, after a couple of hours would not...
Get a high pressure can of air and blow out circut boards with quickshort bursts (after removing lower back pannel! It may also be your flyback voltage regulater (about 60.00 for part!
Dec 11, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
I have a Samsung DVD-HR735 Recorder .The Problem Is Taci Turn
Jun 14, 2008 | Samsung DVD-HR735 DVD Recorder/HDD...
Fan check issue
ya need to get fan fixed is safe mode cuse they genrate alot of heat have to have it in well vented area on a nice power strip like monster
Jan 06, 2008 | Samsung HT-X50 System
Won't Read blank disc!!
I my DVD-HR735 wont recognise any discs at times, and is getting worse. I've now discovered (out of frustration) that if I tip the front up to between 30-45 degrees, it will play all the discs it says were unreadable. I've started jamming three dvd boxes under the front of the machine when i want to play dvds.
Nov 18, 2007 | Samsung DVD-HR735 DVD Recorder/HDD...
Open Questions:
See all Samsung DVD-HR735 DVD Recorder/HDD Recorder Questions
Samsung DVD-HR735 DVD Recorder/HDD Recorder Logo
120 people viewed this question
Jerry Greenberg
Jerry Greenberg
