Won't fill with water, water dribbling in.Possieble solenoid problem??
    President:
  • 1,185 Answers
Take off the pressure to the inlet valve or valves by turning off the wall supply
Unscrew the hose connectors making sure that you mark which ones they go back onto if your machine fills both hot and cold
Look inside the opening there will be lots of gung inside , pull out the filters carefully
You may need a pair or long nosed pliers
Wash out the filters and re-assemble
If that does not improve the flow , change the valve
Posted on Jun 30, 2009
LG WF-T653a - The cold water only dribbles out when trying to fill the tub, (the hot water comes out fast) which causes an IE error constantly stopping the machine. Any ideas what I can do, please?
You may need a new inlet water solenoid. But first check the small gauze filter in the cold water inlet connection. They can get blocked.
May 28, 2018 | LG Washing Machines
Water wont stop filling up
If water keeps filling or dribbling into the machine with the power off it's the water inlet solenoid. If it overfills only during the cycle then it is the pressure switch or pressure switch tube.
Jul 10, 2013 | Meiko Dishwashers
Cabrio washer won't fill normally but diagnostic shows valves are fine
when doing the diagnostic testing machine fill up almost full and stop display an ol mode
Apr 17, 2013 | Whirlpool WTW6400SW Cabrio Washer
Washing machine won't fill. i filled it by hand with water, it won't agitate either, only spins.
The inlet solenoid is probably bad. And it won't agitate unless it fills and stops filling automatically.
May 17, 2012 | Whirlpool Washing Machines
Hoover 700l Cold water is not fillingproperly. Only a verey small dribble comes into the machine. I have reversed the hot and cold hoses, making sure that the setting is on "hot". Problem...
Clogged screen in fill valve on cold side. Remove hose from cold side on valve. Pull screen out. Wash under hot water, and re-install.
Jan 23, 2011 | Washing Machines
Washer takes about an hour to fill halfway with water
Check the solenoids on the water inlet valve for continuity using a multimeter or ohmmeter. A lack of continuity indicates a faulty solenoid. I will attach a photo for reference. Hope this helped and best wishes.
Aug 09, 2009 | Fisher and Paykel GWL11 Top Load Washer
Our ice maker plus WHIRLPOOL is not working
If the fill tube gets choked up with ice, it usually means that the water fill solenoid valve is leaking. The valve is not closing properly and is dribbling water. If the leakage is slow enough, water may freeze in the fill tube. Over time it will freeze the tube completely shut.
Apr 28, 2009 | Refrigerators
My ice maker overflows
If the fill tube gets choked up with ice, it usually means that the water fill solenoid valve is leaking. The valve is not closing properly and is dribbling water. If the leakage is slow enough, water may freeze in the fill tube. Over time it will freeze the tube completely shut. or it could be that the ice maker is not level.
Apr 03, 2009 | Thetford Norcold RV Cooler/Freezer
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
