Question about Lands Phones
Cannot make outgoing calls
I am using a NORTEL MERIDIAN M7310 unit and, although I can receive incoming calls, I cannot get an outside line nor can I ring another extension on the 'phone. I currently have the DND button indicated, and am unable to clear that as well.
  • pgray898 Jun 30, 2009
    Carl, thank you for this - however, the feature button just brings up the number 1 and lights up the intercom line. Pressing any other button causes the 'phone to give an "Invalid Number" response.
    Should I look out my rubber hammer (small, technical adjustments)?
    Paul
    Carl,
    You're an absolute hero - I had cleaned the 'phone and that would seem to be the reason for the sticky key. I'll use the proper stuff in future!
    Thanks a lot for the advice, appreciate it.
    Paul
  • Lands Phones Master
  • 2,460 Answers
One doesn't necessarily equal the other, but start with the DND first :-)
Press FEATURE #85. DND off. (FEATURE *85 puts it back on).
Now, if everything works, skip the rest. If not, press FEAT *0 and press all the buttons on the strip below and above and note what it says. It should match what other phones have programmed. If it doesn't, post back as a comment and we can start working on that.
Carl
Posted on Jun 30, 2009
  • Carl Navarro
    Carl Navarro Jun 30, 2009
    The hammer is the LAST thing :-) Try the alcohol first (you drink it and your outlook improves)
    Look for sticky buttons. Or broken ones. The FEATURE button is absolute on a Nortel and it's really necessary as it starts your functions. The key is probably the "1" on the display.
Nortel m7310 cant use touch tone
Try Feature 808 before pressing the touchtone digit - it tells the Norstar to send Long Tones to the remote system.
Jul 22, 2013 | Nortel Meridian M7310 Business Phone...
My M7310 won't forward a call to the next open line but gives a busy signal
Hard to answer because your problem description does not match the part.
Nortel Meridian M7208 Corded Phone is a digital phone which works off a phone system.Also note that the carrier controls the rollover, not the phone or its system.
Once you have more/proper details maybe you can be helped.
Dec 14, 2012 | Nortel Meridian M7208 Corded Phone
All of a sudden the line lights on our nortel switch Meridian M7310 phones started blinking and the lines are dead. Any ideas?
If you only have one line,why not just lose the Nortel system? You can reuse the wiring from the phone sets to the contoller as regular inside wire,and just plug in regular phones(and maybe put the Nortel phones and controller on EBay and make a few bucks off it!)
Oct 26, 2012 | NorStar Meridian M7310 Phone
How do I activate the handsfree mute button on Norstar M7310? When I push outside line, then handsfree, I get dial tone, but cannot dial outside number. When call is incoming, after answering, I cannot...
familirize with devices user manual whether has feature functions requested. Second, ascertain that device was least malfunctioning since acquired. normally, familirising with innovative devices makes expertise in functionality.
Jul 20, 2011 | NorStar Meridian M7310 Phone
Meridian M7310; just installed replacement phone (used); line 3 disconnects when answered. Lines 1 and 2 work fine. They are in the loop. Line 3 is dedicated fax incoming but can be used as outgoing phone.
Normal 0 Hello, Gary.
Disconnect power and cables from all phones and faxes on the line 3. Wait 15 minutes and reconnect the line again, one at a time. See if the Meridian works. If not, it could be faulty.
Hope this helps.
Feb 01, 2010 | NorStar M7310 Corded Phone
Meridian M7208 Phone-Only 2 lines are working
Sounds like it might be a telco problem. Do lines 3 ,4 work on the other phones?
Switch lines 1 and 3 to see if the problem changes.
Apr 22, 2009 | Nortel Meridian M7208 Corded Phone
Meridian M7310-shows outside line in use and cannot disconnect
the easist way to reset that is to reset the system. unplug it for a moment that should clear it.
Mar 27, 2009 | NorStar Meridian M7310 Phone
Call forwarding for NorStar m7310
You have to know how to get into programming, and it depends on the type of telephone lines you have... if you have regular analog lines, on a out bound call transfer there is going to be line degragation. Meaning that the outgoing call is not going to be of the best quality.
Secondly, you have to see how many telephone lines you have, if you have 3 analog trunks, with a call forwarding to a cell phone, you will be using up 2 lines... 1 incoming and 1 outgoing to your cell. This leaves 1 trunk for incoming or outgoing callers.
Jan 22, 2009 | NorStar M7310 Phone
Lands Phones Logo
390 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
