If it is a plugged line, I would need help on accessing the line. I don't have a manual with this unit. I hope you can help me. Thanks.
This model is a top freezer unit, so check on the freezer first. There should be a drain in the back, behind the false wall, under the evaporator. Clear this if its clogged. Check all tubes and connection you just removed for ice or food. Now remove the control panel inside the refer section. (I assume you already unplugged this from the wall). Once the control unit in down look for the obstruction in the drain well toward the rear of the panel. If clear, check the tube below in the back by the compressor, this should look like a "u" shaped tube that sits above a pan. Make sure everything is clear, this is the complete drain system. Somewhere its obstructed. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
SOURCE: I have a magic chef
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
