Question about Epson RX620 All-In-One InkJet Photo Printer
When i print.,one of our ink is lost,the black color.,annd then i put it again a black ink and then when i print. the there is a problem occur it said that ink cartridges cannot be recognized.,.what i will do?
    President:
  • 942 Answers
You need clean the head of you ink cartridges, because there is an ink there that can be drained and become stick
Posted on Jun 30, 2009
Brother MFC 5860cn magenta color is not printing. I printed the test page and did cleaning on it but the magenta color is not showing on the test page. The only colors showing are Black, Yellow, Cayan.
This can happen if the ink dries out for a long time. Try to power flush the color that doesn't work.
Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
press 7 then 6 then 4 then start black copy. This will fill the tubes with ink.
press 7 then 6 then 3 then start black copy. You may use the right arrow to choose the color you want to flush before you press the black copy button.
Press 99 to exit maintenance mode
Press the ink button and do a test print for print quality and see if the color you flushed works. If not, try again.
This is the only way to fix the dried print head. Otherwise you have to replace the print head, in which case, you might as well buy a new printer.
Aug 03, 2010 | Brother MFC-5840CN All-In-One InkJet...
I recently replaced the black ink cartridge and do not wish to use the colour cartridge. However, the printer still keeps flashing the critically low level of my colour cartridge and does not print.How can...
Many printers always use a small amount of each color even if you are only printing black, to prevent the color nozzles from drying out and getting clogged (and, it forces you to buy more ink, which is a profit center for printer manufacturers)
For this reason, some printers will not work if ANY of the cartridges are empty.
It should work again if you replace the color cartridge. Make sure to select "black ink only" or the option to print in black and white or grayscale to minimize color ink usage. It may still use a little, but that's OK.
Apr 07, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Error message that color cartridge has low ink, so printer won't print. How do I override this? This message occurs when only one color is low and requires replacing the entire cartridge.
No way 2 override the message. Printer works on a combination of both black and color ink to print those perfect pictures and documents. If it is showing color ink needs replacement,you ve 2 change it in order to print even in black and white.
Jan 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Refilled my black ink but my color ink is empty so it wont print
Apparently I just had the same problem and I managed to fix it! Click on the OK button on the printer to ignore the low ink level error, then you'll be able to print and scan.
Jun 01, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
My Canon i860 just can't print out black words, it's frustrating
pull the ink cartage back out to see if a clear film is not on the cartage??? Check the area by cleaning the ink cartage with rubbing alchole, and also the area that the ink cartage goes into. Use a cotton ball the clean these area with.
Jan 31, 2009 | Canon i860 InkJet Photo Printer
Printing very light
I am not sure your printer cartrige with head or not, and it is color or black, it there any color lost, in general you may try
1) if the cartridge seperate print head, find a cartridge spacial clean liquor or steam water and take out the ink cartridge, put a little into the ink hole and back the ink box test it,
2) if printer ink with head, take out and put in team water (just touch water surface to the head hole for 1 Hr. and then put back and test.
3) check printer manu adjust darkness to darker.
Dec 28, 2008 | Lexmark X75 All-In-One InkJet Printer
PIXMA IP90V only prints in black and white
try unplugging it and plugging it back in.when you reinstalled it did you do a fresh install?if not install again.first take out the old one
Nov 19, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Problem with Canon MP730
hi, i was having the exact same problem with my printer. and i also tried reinstalling the driver. after reading your post i decided to see if the printing problem occurred when i used the other colors, and it looks like it's only a problem with the black ink. i printed out a sheet with the text in red and another in blue and they came out perfectly. but the black grid that surrounded the blue text, still looked problematic.
so... that means that the black ink is the problem. i haven't tried putting in a new cartridge. did you say that your problem occurred after you put in a new black cartridge, or did you try putting in a new black cartridge and you still had the same problem?
May 06, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Ink cartridge problem
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Mar 18, 2008 | Lexmark X6150 All-In-One InkJet Printer
MFC440CN PRINTING - ALL BLACK
I understand that the machine is printing only in BK. You have lost color.
If so, do run the cleaning cycles several times and run quality check test prints after each cycle.
There should be color again.
Otherwise the ph is defective!
Feb 11, 2008 | Brother MultiFunction Center MFC-440CN...
Epson RX620 All-In-One InkJet Photo Printer Logo
95 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
