Question about MSI 661FM3-V SIS661FX LGA775 2DDR 400 2 PCI S-RAID ATX (04661FM3V) Motherboard
SAT hard drive hook-up failed on mother board
Can I bypass on board SAT hook-ups by inserting a PCI SAT card to control my hard drive instead.
  • Z Laws May 11, 2010
    When you say "SAT hard drive hook-up failed" what exactly do you mean?
    The SATA socket is broken?
    The SATA BIOS doesn't load?
    The SATA RAID doesn't work with your drives?
    The SATA cable is faulty?
    More information would help.
    I am familiar with that board and the documentation is quite clear on how to get a SATA drive working - have you followed the installation instructions to the letter?
    What make/model of drive is it?
  • 3 Answers
Yes you need to go into the MB BIOS and set the option to use an add in card or alternatively set the boot priority to book from your add in card first.
Posted on Jun 30, 2009
The computer would not go on onle a orange light is in the start button instead of the regular green light. how can i fix this?
An amber power light that stays on indicates that the power supply is getting power to the motherboard, but the system can't process any data.
This is one of those cases where you would need to strip down the system and start with minimal hardware installed.
First remove all the PCI cards and the memory, as well as disconnecting the drives, to see if the system gives a beep code for no memory.
Next, add back the memory, one stick at a time if you have two in the computer. Connect the hard drive back to the system and see if it will boot up from this configuration. If not, then if you are using the onboard video, try an add in PCI video card.
If it still will not boot then the problem is likely to be the hard drive, mother board or processor.
You would want to try another hard drive to test. If you can boot from this configuration, then add back the other drives one at a time, then do the same with the PCI cards. At the point where the symptom returns, that will tell you which part is causing the issue.
Here is the manual
http://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_optiplex_desktop/optiplex-gx260_Service%20Manual_en-us.pdf
May 25, 2014 | Dell OptiPlex GX260 PC Desktop
Its an older compaqq and im not sure if im hooking the mother board up correctly or the hard driverss. it seems to turn on . the faans are going but nothing on moniter
the presario 5000 has whats called an integrated video meaning its built in to the board itself. the onbord video is known to fail pretty often. youll need to place a video card in one of the available pci slots and im certain that will resolve your issue.
Jul 08, 2009 | Compaq Presario 5000 PC Desktop
Need diagram of how to hook up my western digitial sata harddrive to mother board a asus a7n8x-e deluxe
this motherboard does not support your new Hard Drive. SATA is a connection type required for your hard drive. Your motherboard supports IDE connector. You probably can get a pci card that allows you to attach the hard drive.
May 24, 2009 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
HP a1712n How to troubleshoot MOB problem?
you can consider 4 factor on no video,it maybe video card or memory card,processor last mother board this if PSU was good,you also check memory card to other computer,somerime need only to clean terminal slot of memory by pencil eraser,eraser slot then put it back,also video card same process in cleaning try also to other computer.Instale good memory card and good video card even with out hard drive,cd room the mother board.if does not run,defective motherboard,
Mar 16, 2009 | HP Pavilion a705w PC Desktop
Asus 845 chipset pb4 mother board not starting
it may be the circuit problem,inside the mother board.send it to service center
Jan 16, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Wirring for my mother board
The board may have tiny words printed on it telling you what the plugs are.
Most newer boards are fool proof in that only the specified cables can be plugged in. generally the Hard drive plugs into IDE 1 or MAIN and CD drives plug into IDE 2
Video cards go into the First slot usually. It may be AGP or PCI or PCI express depending on the board. The extra PCI slots are for extra devices like NIC cards and Sound card. Power cables cant be plugged in wrong because there male to female and only fit into there designed plugs.
Make sure the motherboard is installed correctly and is not touching the actaul case but held up with spacers. you can find these at most Computer stores.
Really try and find the manual online if you can. It may be necesary when plugging in the little pins for the power switch and USB pins.
good luck.
Jun 12, 2008 | Lenovo Computers & Internet
Power up
pull everthing off board but power supply ram cpu and heatsink. then try to power unit.
May 08, 2008 | E-Machines eMachines Desktop PC
MSI 661FM3-V SIS661FX LGA775 2DDR 400 2 PCI S-RAID ATX (04661FM3V) Motherboard Logo
131 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
