Question about D-Link Computers & Internet
D Link DSL 1500G link problem
My D Link DSL 1500G++ can have DSL link with wire just more than 3 meters, previously i can have DSL link with wire more than 300 meters long
How will configure d link router access point
Posted on Jun 30, 2009
How to configure d-link dsl 520b modem
The manual from D-Link should tell you everything you need to know.
1. Go to this site: http://www.dlink.com/products/default.aspx?pid=DSL-520B&tab=3
2. Click the Product Manual link to download the manual as a ZIP file.
Mar 05, 2011 | Computers & Internet
Ethernet Hub EN104 Hit and Miss.
Are you sure you got a compatible modem? They are not all alike.
Apr 05, 2017 | SMC Model EN104TP 4 PORT 10 BASE-T...
DSL-2640R I WANT TO KNOW THE DEFAULT IP FOR THIS DEVICE
Please use the link given below. This link will help you to connect to internet wireless and wired both ways.
http://www.fixya.com/support/r4581923-connect_wireless_laptop_or_wireless
May 18, 2010 | D-Link DSL-G604T Wireless Router
D-link dsl - 2640u ' the lan is up but wireless no...
i have a dlink dsl2640u when i go in 192.168.1.1 and try to turn on the wireless and save it reboots 3 to 4 times then it stays on but the wireless is off any help
Oct 06, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
This is my situation; I have a hard wire connection from my wall phone/DSL outlet to a Westell model C90 DSL router/modem. Since this allows for only one single hard wire connection to one desk top (I have...
So you are connecting the DSL Modem output to the D-Link's LAN port 1, right? In this case, you should connect the DSL Modem output to the D-Link's WAN Port, which is between the power input and the LAN outputs.
If it doesn't work that way, check this out:
http://www.voipmechanic.com/westelltobridge.htm
Aug 24, 2009 | Computers & Internet
How do i connect a d-link dsl-g624t to sky broadband
you can connect a d-link dsl-g624t to sky broadband by connecting the wire in to the appropriate slot or you can connect your d-link into the PCI slot on your motherboard
Nov 01, 2008 | Computers & Internet
D-link di514
Try the DSL modem directly connected to the PC.No D-Link Router(powered off and disconnected). Verify that the PCcould surf/browse/connect to the Internet. Go to Start, Control Panel,Network Connections, right click Local Area Connection, Properties,scroll down to/highlight Internet Protocol (TCP/IP), Properties button.Get the IP Add, Subnet Mask, Default Gateway and DNS assigned to the PC(write this down. This will be your WAN/Internet IP settings). Then Disable DHCP of your modem if it has one. OK, close, save or whatever is applicable.
Disconnect the DSL modem from the PC. Connect D-Link Router to PC (wired/LAN) without the modem connected to the router.Go again to Start, Control Panel, Network Connections, right clickLocal Area Connection, Properties, scroll down to/highlight InternetProtocol(TCP/IP), Properties button. Tick "Use the following IPaddress". Enter this IP Add 192.168.0.10, Subnet Mask255.255.255.0,Default Gateway 192.168.0.1 and the DNS from what youhave written down earlier). This will be your LAN IP settings. OK,close, save or whatever is applicable.
Open a browser and log into the D-Link router (192.168.0.1, using "admin" as a username and no password). Do not run Wireless Network Setup Wizard. In WAN/Internet/Modem setting of router enable/check Static IP Add.Usethe IP numbers previously assigned to PC that you have written down asthe router's WAN/Internet/Modem IP settings. OK, close, save orwhatever is applicable. Reboot router. Connect DSL modem to router.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Aug 04, 2008 | D-Link DI 514 Wireless Router (DI-514)
Adsl2+
don't go for the cd you configure your self abd it think that your dsl not get the perfect dsl link
Jul 10, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
D-link 2640
i think your problem is the configuration,in the security of your wap.try to configure it again.
Jan 27, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Computers & Internet Logo
681 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
