Question about Sony VAIO VGN-A230 PC Notebook
Vgn a230 i want to know one thing is the security chip makes battery goes down
  • 324 Answers
Re: vgn a230
The security chip should draw an extremely small amount of power. So the answer to your question is no.
Posted on Nov 09, 2007
0 characters
3 Points
My sony vaio vgn n230e/b laptop won't recognize a new replacement therea sony program that could be disabled or turned off?
If you replaced the battery from one of the many sites that promise complete compatibility with the original OEM battery with specs that meet or exceed those of the OEM, you're on the wrong track. They don't work in my experience. Sony has a proprietary chip in their battery packs that identifies it as an "original" The battery sites state that you have to update the BIOS drivers to make it work and if you have Windows 7, it will be problematic. I've gone through this several times, and what I've had to do is do a restore to a point prior to installing the software that the battery site provided. Although I received a notice that the restore was unsuccessful after it had been run by a system restore CD that you should make; I received notice that the restore was successful after reboot. I then ordered the battery from Sony, installed it, and all is well. Best advice is to be very circumspect in getting batteries from any source that says they are brand new and are completely compatible. A place I know to go to replace bad cells is or (same site). They replace the cells, leave the original chip, and the computer sees it as an 'original' Sony battery.
Dec 04, 2010 | Sony VAIO VGN-N230E/B Notebook
My sony vaio VGN-FS980 PC Notebook wont shut down gets frozen at the windows is shuting down screen
yah i dont know waht your question is but try unplugging the power and taking out the battery or hold the power button down till it turns off
Apr 06, 2010 | Sony VAIO VGN-FS980 Notebook
I have to remove the battery pack and reinsert it
have you tried holding the power button down for about 5-10 seconds to manually shut down laptop? make sure the system is up to date with the current updates and clean out the system using your antivirus program. also try microsoft security essentials if you dont already have it.
Apr 01, 2010 | Sony VAIO VGN-FS920 Notebook
I have a Sony Vaio CR VGN-CR353, one of the keys (apostrophe) doesnt function, the rest are fine. Please help to set this right. Soundar Rajan Mysore, India
Hello and thank you for using Fixya!
This can be caused by a couple of things; either dust, liquid spill or just malfunctioning of the chip on the bottom of the key.
You can try a few things to see if it resolves the issues:
First, get a can of air from any electronics store and turn the laptop at an angle, facing down. Blow the keyboard with the air to remove dust and debris.
If there was a liquid spill or splash on the keyboard, you may want to try and gently pull the key off and clean with a small rag and a little dab of alcohol. Make sure the laptop is unplugged before attempting this.
If the problem is a malfunctioned chip under the key, you will probably end up having to order a new keyboard and replace. You can visit the manufacturer's website for the service guide free and see if this is something you can do yourself.
Please let me know if this helps and thank you for using Fixya!
Dec 06, 2009 | Sony PC Laptops
Hello plz can u tell me where is the battery of my laptop?i cant fint it... regards
Make of Laptop.
Turn upside down, placing on soft surface.
There should be either push fit panels or small screws, securing panels, seek and you shall find?
Nov 02, 2009 | Sony VAIO VGN-CR305E/R Notebook
Does anyone out there know how to install memory upgrade module into the Sony Vaio VGN-TX650P. Sony's website won't tell you because they only want sony products installed by sony technicians. Therefore,...
there is likely a small rectangle shaped cover on the bottom that looks like it should come off with the removal of maybe a screw or three. there may be more than one cover but if you know what a memory module looks like then you'll immediately know you have found the right cover.
the existing memory chip (or chips) will have been snapped into place and you should see a spring action type thing on either side of the chip that you have to pry away to get the existing out and put the new one in.
usually with laptops the memory chip goes in at an angle an then you press down to snap into place (you'll know if it's seated right).
check back if you've found the cover but aren't quite sure how to proceed. once you do it you'll pretty much know forever how to. :)
Jul 11, 2009 | PC Laptops
Sony vaio vgn nr120e no power
hmm well i could of helped you if that was the problem, but that has me stumped could be anything, i can run through some diagnosis tests to try and narrow down the problem tho, 1. turn the laptop upside down and remove the panel which has the ram cards (ram cards are rectangular chip boards relatively small with 6 or so little black microchips on them in a row or just google it) under it and remove the ram cards then try turning it on. there any noticeable damage to the laptop such as damge around the battery and charger ports? 3. try turning it on without the battery in at all just the charger. sorry if any of these didnt help
May 26, 2009 | Sony VAIO VGN-NR120E/S Notebook
Where is the ''full stop'' on keyboard of the note book?
On the right hand side of the keyboard, the 3rd key to the left of the Shift key (counting the Shift key as the 1st key) and the comma key is the 4th key to the left of the Shift key.
Mar 06, 2009 | Sony PC Laptops
VGN-SZ330P laptop stays on opening VAIO screen after two beeps
Just hold down the F1 key after the two beeps and the computer should continue to boot up as normal
Dec 19, 2008 | Sony VAIO VGN-SZ330P/B Notebook
Sony VAIO VGN-A230 PC Notebook Logo
67 people viewed this question
Top Sony PC Laptops Experts
micky dee
danielle yancer
danielle yancer
Jax Planet
Jax Planet
Are you a Sony PC Laptop Expert? Answer questions, earn points and help others
