Nokia N8 Cell Phone Logo
A
Anonymous Posted on Jul 31, 2014
N8 problems it goes up to step three wich it doesent complete it says "USB to nokia disconeccted"
1 Related Answer
Anonymous
  • 2360 Answers
  • Posted on Dec 17, 2010
SOURCE: can anyone provide steps on
you can get unlock codes here http://www.theunlockarena.com/nokia-n8/rs13wp9/ and instructions in the same site
My nokia n8 working only offline mode .not orking in genral mode how to repar
maybe check ur sim slot or try ur sim to other phone if is no signal ur problems its in sim if not at same try to hard format ur n8
If you're unfortunate enough to encounter a problem on your Nokia N8, a hard reset maybe what you need to do. This wipes the entire phone memory and settings fresh to how it was (or should be) when you bought it. It's also useful if you're also unfortunate enough to have to send away your Nokia N8 for repair or exchange, or maybe in future you maybe selling it and don't want your information/details/media stored onto your device for someone else to access.
Hopefully unlike the N97, the N8 will not encounter hard-reset bugs where we constantly have to hard reset.
To hard reset the Nokia N8:
1) Turn off your phone
2) Hold "Volume Down + Camera Key + Menu Key" and press power button until your phone vibrates.
or try this one
How to Master Reset Nokia N8 do the Factory Default Setting?
If our Nokia N8 have problem such as hang or not responding or slow or stuck or have problem or frozen, then what we can do is try to restart the phone first to erase all temporary file and clean the cache. If the Nokia N8 problem still there then the last thing we can try is to do Master Reset to Factory Default Nokia N8 with safety way.
#Option 1, Hard Reset Nokia N8 with Menu Setting:
If we still can access the menu, then do this step:
  1. Go to Setting Menu
  2. Choose Phone
  3. Choose Phone Management
  4. Choose Factory Setting, after that choose Delete Data and Restore
  5. The Nokia N8 will reset all data for factory default, please remember before doing this step for always backup any important data before it deleted.
#Option 2, Hard Reset Nokia N8 with Hardware Key Button:
If we can not access the menu with screen, or the LCD is not responding, we have to hard reset Nokia N8 with secret button key:
  1. Make sure you understand that all data will be deleted, so do backup as you can
  2. Turn off the Nokia N8
  3. Press the Hardware key together: Volume Down Button + Camera Button + Menu Button
  4. Still continue the no.3 step (do not release), continue with pressing Power Buttonwait until the phone vibrate to start the factory reset Nokia N8 automatically.
#Option 3, Hard Reset Nokia N8 with Secret Code and Phone Lock Code:
If we want to format Nokia N8 with security code, try this :
  1. Make sure you already backup all important data before do the factory reset
  2. From the Phone Positions, type : *#7370#, after that press YES
  3. It will ask the Phone Lock Code, if you never change it, the default Phone Code of Nokia N8 is 12345
  4. What about if we forget the Phone Lock Code of Nokia N8: We suggest to bring the Nokia N8 to nearest Nokia service center.
tip
Enjoy YouTube video on Nokia N8
The Nokia N8 is a Symbian^3 smartphone from the Nokia Nseries. Featuring Carl Zeiss optics , xenon flash, the addition of multiple home screens, customization abilities, multi-touch capabilities with gesture support. The N8 is the first Nokia camera phone to utilize a 12 megapiel camera sensor size of 1/1.83, making it the largest image sensor in a camera phone ar the time of its launch.
Nokia N8 supports video capture in 720p 25 FPS with codecs H.264, MPEG-4 and flash video. Also you can Enjoy Web TV on it as well as YouTube browsing and streaming. The video formats that supported are H.264, MPEG-4, VC-1, Real video 10 and 3GP. Like many other popular devices, Nokia N8 doesn't support FLV format. Therefore, if you want to enjoy YouTube video on Nokia N8, a related video converter that can help you convert YouTube video to Nokia N8 is necessary.
Before converting video for Nokia N8, you should pay attention to the specific parameters Nokia N8 needs. To get the most suitable video for Nokia N8, you have to convert the video with the following parameters:
Display Resolution: 16:9 nHD (640 x 360 pixels) AMOLED
Bit Rate: 720kbps
Encoder: H.264, MPEG-4
Frame Rate: 25 fps
Aspect Ratio: 16:9
To enjoy YouTube video on Nokia N8, you first have to download the YouTube video. Use Firefox free plug-in downloader to help you download YouTube video or you can try Orbit downloader, another free YouTube video downloader. Then, Convert downloaded YouTube video to MPEG4 or 3GP with parameters mentioned above. Tenorshare Nokia N8 video converter can help you convert youtube video to Nikia N8 within four steps
Step 1. Download Tenorshare Nokia N8 video converter and install it on your PC
Step 2. Import downloaded YouTube video to the converter
Step 3. Setting suitable parameters for the video
Step 4. Convert video for Nokia N8.
on Feb 17, 2011 • Computers & Internet
Network unlock codes
Hi, to which network has your Nokia N8 been locked to? You can visit www.Mobile-Unlocker.com to get the accurate unlock code for your Nokia N8 at affordable cost with easy step by step unlocking instructions. good luck mate.
Please unlock code for my nokia n8 on three network IME = 355944046321451
Unlock code are unique and every mobile phone has its own unlock code based on its IMEI number. You can get the unlock code for a mobile phone either from the respective network provider or from any trusted vendor online. Once you have received the unlock code, You can visit www.MobileUnlockGuide.Com This site provides free step by step unlocking instructions. This could help you understand unlocking process better.
I want my phone unlocking to t-mobile
Hi, You can't unlock your Nokia N8 for free. But you can unlock it at affordable cost from www.wickedunlock.com/nokia-n8/rs11wp9/ You haven't mentioned your country too. Anyway you can visit this site to get your mobile unlocked. This site provides unlock code for certain country's T-Mobile network.
STEPS FOR UNLOCKING NOKIA N8
1 - Switch on your Nokia N8 without any sim card.
2 - Don't bother as to what is displayed on your Nokia N8.
3 - Compose #pw+CODE+1#.
4 - The Nokia N8 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia N8 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
2answers
How do i unlock
To unlock the Nokia N8 easily use the unlock code,get the unlock code from the site Onlinegsmunlock.com/nokia/rs7wp8/ and unlock it from Network Lock.Follow the instruction below and unlock it step by step.
Nokia N8 Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Nokia N8 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia N8 mobile phone, your phone may get hard locked and sometimes become unusable.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia N
Hi pls help unlock my nokia n8 tied down to the three uk network....its imei number is 35533610495547398
To unlock your network with codes are some what better for your mobile to use without any problem, because codes are the best way to unlock your mobiles , just simply follow the instructions & enter the code means automatically your mobile get as unlocked,Just visit this site http://www.theunlockspot.com/nokia-n8/rs10wp9/ , it has the step by step instructions for unlocking your Nokia mobile from the network lock.............
Jul 13, 2011 • Cell Phones
Dear Sir please I have a question about Nokia n8 when buy nokia in my city ,when I use moblie nokia n8 unhappend restart ,I disappointed, how can I solve this problem? thanks for help.
Just follow this step then you will be free from this.
* Remove your memory card.
* Format it.
* Then start using your mobile.
* If you still face this problem restore your mobile.
* Then also if you still face then you need to visit the nearest nokia services center.
* They will take few minutes to solve your problem.
* They will do this for you that to free of cost.
If you are satisfied then rate me.Thanks for your question.
9helpful
3answers
How do u un freeze a nokia n8
Text below has been added by Nokia: Important information from the official N8 FAQ (http://europe.nokia.com/support/search?page=1&fullcontent=true&cat=support&cnt=1&qt=n8+reset)
You should not use the "three finger" reset (pressing volume down + camera key + menu key and pressing power button) to hard reset the Nokia N8-00 device. Doing this will delete some applications (Ovi Store, Ovi Maps, some preinstalled widgets) which cannot be restored. If the device needs to be reset, try the following methods instead of the "three finger" reset: Press down the power button for 8 seconds. Restore the factory settings by selecting Menu > Settings > Phone > Phone management > Factory settings > Restore. The "three finger" reset should be used only as a last resort if the device cannot be booted up in any other way. If successful, the device can be used after the reset but some of the applications are missing. The device needs to be taken to a Nokia Care point for reflashing to get the original applications back in the device.
Mar 07, 2011 • Cell Phones
1helpful
Error message that there is not enough memory to perform oprration
U may b running an application with more requirements like more RAM. 5230 has 128 mb RAM, and that application may need 256 mb wich nokia n8 has... this may b surely the problem with it.... and there's no solution 4 that...
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
