Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
The motor runs during hours without stopping - Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
  • 57 Answers
Check termostat control... f its ok replace timer
Posted on Jun 30, 2009
My Dolphin Deluxe 4 works through the cycle but doesn't shut off.
possible bad control board if not shutting off possible bad drive and pump motors or board if voltage to motors bad motors if no voltage to motors bad board
Jul 10, 2018 | Pool & Spa
Runs ok for about 5 hours then stops and y cant make it stars again until the next day
that must be that new "take a friggin break" module. seriously, after 5 hours of run time, is that run for 5 hours with no stop and then try to restart or is it normal use for 5 hours with several start and stops during that 5 hours? like for refueling?
Jun 11, 2011 | Garden
Washes one load without a problem, but during the next load after washing, and draining it stops. After 3 or 4 hours it will start the next step as if it hadn't stopped. Then it might stop again after...
hello the cause could be sticking brushes on the motor 2 plastic blockes sit either side of the motor these are made of carbon and wear down can causing motor problems also check the belt at the back make sure it's not sliping the other causes could be module board or programmer hope it helps
regards
shaun
Apr 01, 2011 | Washing Machines
During cold weather spell pool pump was pretty much staying on, as much as 24 hours a day, for 3 -4 days, and during that time the booster pump was set to turn on for 3 hours. Apparently one of the hoses...
what may have happened is the pump seal has run hot a welded together preventing the motor from running
that would hav tripped the thermal overload if it has one or the start run capacitor may have failed
pull the pump apart and if it is just a seal it is around $30.00 to replace
if you do not have the knowledge to fix it , take it to a pump shop and get a proper diagnosis and quote before replacing the unit
May 21, 2017 | Hayward 6060 Pool Cleaner 34 HP Booster...
U-line 75 WC makes a screeching noise on and off during the day. What can I do to make it stop?
You may have one or two fans on the unit. One normally next to the compressor and one in the evaporator With the unit running listen if the noise is comming from inside or outside. Outside is easy, spray Q20 onto the motor and run untill you are able to buy a new one and replace. If inside, defrost a few hours then remove inside panel and locate the evaporator motor. Spray motor shaft liberally then motor will quieten down. Replace when possible.
Sep 15, 2010 | Refrigerators
GE TBF 17DB 17,2 cu.ft. refrigerator/freezer runs continuously.
Set both controls to their middle settings. Put a glass of water in the frig with a thermometer in it and check the temperature in 48 hours. I is normal for the newer appliances to be on longer than off. Power consumption is highest during start up and it is more efficient to start less often and run longer. When adjusting controls ONLY change one by one number and wait 24 hours before making another change.
Eric
Apr 18, 2010 | Refrigerators
I have a kenmore side by side and the icemaker makes a ticking noise that last about thirty seconds and stops. It happens maybe once an hour. How do we stop the ticking ?
the ticking noise is the icemaker motor. during ice harvest there is a time whne the icemaker motor "stalls" out against the ice before the ice releases into bucket. its during this time the motor is making the noise. this is a sign of motor gear wear. the motor module on the front of your icemaker needs replacing the part number is 8201515 and should run 60-80 dollars. this part is easily replacable. remove front i/m cover and there are 3 phillips screws that hold the module in place.
Hope this answers your question. any furhter questions just leave a comment here and I'll be glad to assist any way I can.. Peyton
Mar 01, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Whirlpool dryer
If your dryer stops during its cycle, wait ten minutes and start dryer again. If dryer starts, then the motor was overheating.
Solution, Check for lint blockage around the motor and for possible overloading. If dryer repeatedly stops during its cycle, especially during consecutive loads, replace motor.
Good luck
Aug 10, 2008 | Whirlpool LER5636P Electric Dryer
My whirlpool Refrigerator motor keeps running
Keep an eye on the running time and temparture of the refrigerator. It will need time to return to normal cooling temps since the defrost and hot temps inside will take maybe a few more hours to reach normal. If not, get back with me and I will go through a step by step process on eliminations,  If so I will need age of fridge, Make and Models Numbers, Thanks Sea Breeze
Oct 27, 2007 | Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
65 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
