Question about Compaq (101947-001)
Recieve error on start up system fan failed fan is spining just have to push f2 to continue to windows how do i get rid of error or how do i fix the problem. i recently took out the fan and gave it a clean then put it back in and now receive that error.
  • 46 Answers
In the "bios" go to hardware monitor or something similar you should be able to make the computer ignore it and the problem should go away
Posted on Jun 30, 2009
New case fan running but still getting error message system fan failed.
Did you try;
Power off, power unplugged to computer.
Press the Power On button, and hold it in. Hold for a count of 10 seconds.
Let go.
Do this procedure two more times.
Plug the computer back into power. WAIT 1 minute, turn the computer on.
This method clears CMOS Error Codes, and sets BIOS Setup back to the factory default settings.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00864946&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3340228#N436
CPU fan spinning at required minimum RPM's?
Not talking about the SYS_FAN (Case fan)
Regards,
joecoolvette
Jan 18, 2013 | HP Pavilion a1720n PC Desktop
When i on my system its start windows and stop and shows hdd error press f1 continue press 2 del f1 i press its booting failed
Your Hard Disk Drive is crashing or has crashed. You need to buy a new hard disk drive, and then you will have to reinstall windows and start over.
Jan 27, 2012 | Mercury Computers & Internet
When I startup my pc I have to press F1 before it starts . I am running windows xp home
This has nothing to do with windows, but is a cmos or bios issue. There should be an error something like, Time incorrect press F1 to continue or F2 to enter setup. Check the error and then press the correct key to enter setup. If the issue is the time, fix the time and date in set up. Most other issues will clear when you exit and save set up.
If you would like more information, please provide the exact wording of the error that you are pressing F1 to continue from.
Dec 14, 2011 | Microsoft Windows XP Home Edition
My dell gx 270 desktop shows alert! previous fan failer. Press F1 to continue and F2 to run setup utlity. How to solve it?
The fan failure alert on your Dell, is caused by the timings. There is no bios settings, for this. You need a new fan that runs at 1400rpm or more. This will solve the problem, also a clean install solves this problem. Best to buy a new quite fan, keep the 5pin header from the old fan copy the wire colour for the pins, make sure the fan is pwm. In the worst case, you will have to change fan, and overwrite harddrive and do a clean os install. This will fix problem, other methods, like fan speed software will redduce the fan speed cook your motherboard, but will not solve the fan failure alert. Also enter bios by pressing f2 and clear log error before you install new fan and os.
l
Aug 18, 2011 | Dell OptiPlex GX270 PC Desktop
Received 512 - chassis fan error on HP Compaq dc5100 ff - I replaced the front chassis fan after detecting fan was not working now when I attempt to log into windows - windows screen appears than...
if you download and install tune up 2010, it may fix your registry automatically for you however if it fails to, your operating system will continue to fail to shutdown or keep causing your system to hang at the f5 window which is the one your describing. Device drivers are very well known for causing this error and if you have installed a new device and your computer is not picking up the new device properly, then the computer will not shut down. There are several forms of viruses that cause the system to stay on, power problems may cause the system to crash during a storm and thus damage the computer registry. A system defragmentation, cleanup, along with a registry clean would be the first best ideas.
Jan 12, 2011 | Computers & Internet
if you download and install tune up 2010, it may fix your registry automatically for you however if it fails to, your operating system will continue to fail to shutdown. Device drivers are very well known for causing this error and if you have installed a new device and your computer is not picking up the new device properly, then the computer will not shut down. There are several forms of viruses that cause the system to stay on, power problems may cause the system to crash during a storm and thus damage the computer registry. A system defragmentation, cleanup, along with a registry clean would be the first best ideas.
Jan 12, 2011 | HP Compaq dc5100 Small Form Factor PC...
System fan has failed
Your system's fan has failed. If it is under warranty, you need to have HP made aware of this failure.
Jun 18, 2009 | HP Pavilion a1410n (ER890AA) PC Desktop
Gateway solo 9550 invalid configuration error when booting
Please look to see what error you're getting. You are getting one and it will tell you the problem.
May 29, 2009 | Gateway Solo 9550 Notebook
Strike F1 key to continue, F2 to run the setup utility
Please let me know what is the make and the model of the pc that you are using.. Also, go to the bios, under boot menu, make sure that you have hard drive as the first boot option.. For further queries please get in touch..
May 28, 2009 | Computers & Internet
Compaq (101947-001) Logo
218 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
