Camera is new, when trying to shoot outdoors, brightness overwhelms the picture
I do not know the S6800 model specifically however, nikon cameras all generally work in the same way. Somewhere on your camera, probably a button or in the menus, there is an exposure compensation setting. The symbol Nikon uses for the button is a "+/-" enclosed in a circle (often half black on white/white on black printing). Press the button and you will either see a zero, a positive or negative number or a a scale with zero in the center with positive numbers to the right and negative numbers to the left.
If the exposure compensation is not at zero, set it to zero. Your exposures should now be correct. If it is already at zero, set it to a negative number to reduce exposure and darken the picture and to a positive number to increase exposure and lighten the picture. Let me know if this solved your problem.
