Question about Philips Irons
My Azure iron has just stopped working after two years. As dead as a DoDo. Checked fuse and wiring inside is intact.It still looks brand new, do I really have to bin it?! Bob Harvey.
  • 46 Answers
Yea you probably should! irons are no point fixing and by the sounds of things its blown up! i bought an expensive one and it didnt even last a year! we had warranty so we got a new one free
Posted on Jun 30, 2009
My Azure seam glide plus leaks water when I am ironing. What can I do
hmm sounds like the water tank could be damaged on the inside of it i would have to say it needs fixing ASAP as in some cases it could lead to electrical shock to its owner
Aug 22, 2017 | Irons
Just stop working. seems as if no electric power is reaching wherever it is suppose to. Iron is about 2 years old.
Those types of problems are usually one of two things... the cord where is enters the iron, the wires are broken. Or the thermostat has gone bad...
The iron will need to be taken apart and the wiring checked witha meter to find the problem for sure...
heatman101
Sep 27, 2011 | Euro-Pro Shark GI490 Iron
I have a Bosch Sensixx Comfort Power iron. Not had a lot of use as I live alone! One day it worked perfectly the next time I went to use it didnt work. Checked fuse.
check Ac cord for bad contact, more caused cutoff wire inside the cord, then try, if not ok,, try to check wiring inside the unit for loss connections.
Aug 11, 2011 | Bosch sensixx TDA 8333 Iron
Euro Pro Irons: Less than a year old stop heating up.
hello,
some time no part of our property go bad but what will need is to service them from there dysfunction
the problem of your iron could be from the element and the wire ,the element is the heat provider while the wire is the power supply from the electric
But the fact is that ,the problem of your iron is disconnection of element from the wire what you need to do fix it to unscrew your iron and trace the wire down to the element and see the disconnection am toking about and fix it back
thank you and thanks for using fixya.
May 31, 2010 | Euro-Pro Shark GI490 Iron
Iron just stopped working, no lights, no heat no iron Opened back panel to make sure no loose wires or damage inside. The inside still looks bran new and the wire cap connectors are intact. Iron may be 2-3...
check plug fuse, if ok, check continuity of the live, neutral and earth conductors for a break. if ok, element may be faulty. Any smell of carbon burning?
Oct 26, 2009 | Irons
The iron will not turn on or light up. It is not the cord.
There should be screws in the back where the cord is inserted, remove these screws. Now you should see the cord, check to make sure the wires are connected, both the ground and hot wire. If all wires are ok, then check the on/safety shutoff switch for damage with a voltmeter.
Aug 12, 2009 | Euro-Pro Shark GI490 Iron
STOP WORKING NOT GETTING WARM.PLEASE HELP
Damaged plug, cable or even the element inside the iron. It may be cheaper to buy a new one from wallmart or similar store.
Jul 30, 2009 | Irons
SHARK IRON WITH TANK.GREAT BUT SUDDENLY STOPPED.
these along with coffeemakers have a thermal fuse for safety the fuse looks like a cilinder with one flat side and the other side pointed with a wire protruding on both sides. it is located inline with the heating element under the cover "Appliance Parts" on the internet sells the part
Apr 21, 2009 | Euro-Pro Shark GI490 Iron
Sunbeam Steam Master Iron 4048-015 stopped working after cleaning. Will not heat. Can it be opened to look inside?
any steam iron more than a few years old...usually isn't worth repairing.  Just buy a new one.
Mar 24, 2009 | Sunbeam Irons
Irons Logo
462 people viewed this question
Top Philips Irons Experts
ray gallant
Are you a Philips Iron Expert? Answer questions, earn points and help others
