Question about Samsung X620 X628 Unlocked GSM Cell Phone Brand
Even with full network, ''Limited Service'' message comes on screen
  • 389 Answers
Check your network settings trough your service provider
Posted on Jul 03, 2009
  • phoenix chi
    phoenix chi Jul 03, 2009
    check your network settings trough your service provider.
When i my pc on it show me generic host problem after this msg windows stop network services?anyone tel me
You may occasionally get an error message that reads "This connection has limited or no connectivity. You might not be able to access the Internet or some network resources." It indicates that your PC is having a problem trying to access your network device to connect to the Internet. Very often, a bug that typically affects Windows XP Service Pack 2 causes this error message. This bug causes a loss of your network connectivity in workstations that use Microsoft's L2TP-based VPN (virtual private networking) client to connect to the NAT-based networks. You can fix the "Limited or No Connectivity" problem in a few steps. (If your connection works but you still get the error message, go to Section 2 to learn how to disable it.)
Review the following symptoms and determine if you experience any of them after you install the Windows XP Service Pack 2:
You get the error message "Limited or No Connectivity" when you attempt to connect to your network.
You have a problem connecting to your local area network or to the Internet.
You keep on receiving an error message: "Acquiring IP Address" message. If you experience these symptoms after installing Windows XP Service Pack 2, then this bug is causing the problem. In this case, go to Step 2; otherwise, skip to Section 3 Download the Microsoft patch (KB884020) from the Microsoft website. Run this update to install it. Create a registry fix by launching Notepad and typing: [HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Services\\IPSec] "AssumeUDPEncapsulationContextOnSendRule\"=dword:00000002 Save the file as FixReg.reg to your desktop. Double-click the saved file to install it into your registry. Restart your computer and the error message will likely be gone. If you still see the error message, follow the steps in Section 2. b> If Your Connection Works But You Still Get the Error Message b> Navigate to the "Start" button and select the "Control Panel." Double-click on the "Network Connections" icon. Right-click the "Local Area Connection" icon and select "Properties" from the popup menu. Click on the "General" tab. Uncheck the option that is labeled "Notify me when this connection has limited or no connectivity." Click "OK." b> If the Patch Doesn't Fix the " Limited or No Connectivity" Problem b> Check your DSL router for any malfunctions. Re-configure or power cycle your router. Check your computer's network card configurations and network cabling to ensure that the problem does not lie here. Check your firewall to determine whether it is blocking you from connecting to the network or to the Internet. Disable the firewall and attempt connecting to the network or Internet while with the firewall is disabled. If the firewall is causing connection problems, then reset or uninstall and re-install the firewall. Reduce your connection speed to 10 Mbps and test this to determine if it fixes the problem. To do so, navigate to the "Start" menu and select the "Control Panel," "System" and "Device Manager." Review the properties of your network card. Click the "Advanced tab." Locate the "Link Speed and Duplex" section. Change the settings from "Auto Detect" to "10Mbps/Full Duplex." Hope this helps.
Dec 24, 2012 | Computers & Internet
Everything works ok except i have a limited service/ no service message on the screen - if i try to ring or text i get network error and emergency calls only.all was ok until about a week ago
U dnt hav 2 worry.Just switch off ur phone,remove ur sim card and replace it back,then switch on d phone.If it stil shows d same message,contact ur network service provider.
May 02, 2011 | Samsung Cell Phones
My SAMSUNG SGHE590 always has a display "LIMITED SERVICE" i can't call and text even the signal indicator is full... how to solve this problem???
THIS IS NETWORK PROUBLEM
THIS NETWOR IS DAME NETWORK
SO UNLOCK YOUR PHONE AND FLASH UR PHONE.......
THEN HARDWARE PROUBLEM.......
Oct 22, 2010 | Samsung E590 Unlocked GSM Phone
My Samsung SGH-D900I mobile phone comes up with 'Limited Service' at bottom of screen and I am unable to use it. At the same time the signal strength indicator fluctuates from 2bars to 5bars when phone is...
When you get a 'Limited Service' it usually indicates a problem with your SIM (check with Mobile Supplier) that is not fully acceptable to the network you are trying to use (is it a new SIM that needs activation? is your handset 'network locked'?).
You also get this message if you are in an area not fully serviced by your SIM mobile service provider.
Hope the information is useful: let me know how you go and good luck!
Sep 26, 2010 | Samsung Cell Phones
LIMITED SERVICE
plse reset your phone code 00000000 try it or contact cell service man
Jul 20, 2009 | Samsung SGH-G600 Cellular Phone
Problem in SGH X620, NO imei, Limited service
problem in sgh x620 ,no imei ,limited service
Jul 02, 2009 | Samsung SGH-G600 Cellular Phone
My samsung d600 wont let me regeister to any network
Try to check the network settings of your phone through your service provider. Have then reconfigure your calls and message settings for them to resolve your issue.
Jul 01, 2009 | Samsung SGH-D900 Cellular Phone
Samsung e330 limited service
Limited Service shows up on my E330 when I'm almost out of network range. I usually find when I move to a better location, the signal strength improves, and the message disappears.
Apr 10, 2008 | Samsung SGH-E330 Cellular Phone
Limited Service
I WOULD TRY A NEW SIM FIRST JUST TO MAKE SURE IF THAT DIDNT WORK THEN I WOULD CONTACT LG AND SEE WHAT THAY SAY ABOUT IT BUT MAKE SURE YOU TRY A NEW SIM FIRST JUST TO ME SURE AS ON MINE I HAVE A VERY STRONG SIGNAL MOST OF THE TIME WHERE EVER I AM BUT MINE JUST WENT WRONG NOW I HAVE PROBLEMS WITH IT POWERING UP IT TURNS IT SELF OFF ITS CRAZY IM LOOKING FOR SOME SORT OF REPAIRING SOFTWARE OR I WILL SEND IT TO LG THEM SELFS
BUT IF ANYONE DOES COME ACROST ANYTHING LIKE THAT PLEASE LET ME KNOW
Jan 24, 2008 | LG Prada KE850 Cellular Phone
Limited service continuously displayed
GO TO NETWORK SETTING N SET YOUR BANDWIDTH
Oct 01, 2007 | Samsung SGH-D900 Cellular Phone
Samsung X620 X628 Unlocked GSM Cell Phone Brand Logo
90 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
