Question about LG LSC121PMA Split System Air Conditioner
How do i top up the gas (R22) LG gold 12000btu
    Scholar:
  • 70 Answers
If it is not freezing up freon is ok. Make sure compressor is running.If humidity in house is high It will not feel as cold as it should until air drys out some. Do not try to run just after house heats up as it may never catch up. LEAVE ON a set stat to cycle. Window units have no customer acess fittings and would need to be installed. Then you need gauges to read pressures. this is not auto refrigerant. 90% of the time the outside coil is dirty and needs washed out. fan blows back through coil so build up is on fan side you can't see. You may be able wash with hose from side you can see with a 30 degree down angle going from top to bottom side to side. careful to not bend fins Also do not spray water into fan motor. Also some times coil is too dirty to clean without taking apart.
Posted on Jun 30, 2009
  • 27 Answers
Is it a split system or an RAC self contained window mount unit???
Is the R22 gas applicable or does it have an impact to global
r22 gas has been found not to harm the environment and is available at leading hardware shops the sell refrigerant gas
May 06, 2016 | Hitachi A/C Compressor, R22, 12, 829 BTU,...
How do i know if the Freon has leaked our of my roof top ac
no cool air from vent or connect a manifold gauge set to machine and read suction pressure should be at 400KPA on R22 gas or 700KPA on R410A gas.
Jan 26, 2016 | Heating & Cooling
Is it better to by air conditioners with R - 410 GAS OR R - 22 GAS
R410 units are cheaper now but not as effecient as R22, also R22 is much more expensive and most likely you would have to use R22 a to recharge unit if it as allowed where you live .
Oct 02, 2014 | Cfm Daikin R410a Split System Air...
Capillary tubing frozen
When material has passed the filter and plugged it. If the unit is less than 20 years old it may be another problem like a txv bulb not working or low on charge.
Jan 28, 2014 | LG Heating & Cooling
Not cooling enough so can i add r22 myself ot i need a repairman?
If you are EPA certified go for it.If not handling is dangerous.Need access port,need gauges for r22 ,an you need to read the pressures on label,an mostly r22..If you do have some cooling it probably needs to be topped off,but can be expensive an always call an see what the service call amount is for just showing up!Be aware call around.
Jul 07, 2011 | LG Goldstar Electronic Window Air...
I want to know how to top up R22 gas for air con
topping up is illegal, system has to be evacuated, leak tested then recharged
Apr 04, 2011 | Heating & Cooling
The best pressure of gas in a split ac in
65 psi is the ideal pressure remember its not exceede from this pressure.
and it is valid for all season
Jun 05, 2010 | LG LSC121PMA Split System Air Conditioner
Lg artcool 12000btu mirror model
1.check remore battery.if week change it
2.check indoor unit sensar of remote.
3.check sirkit board.
Mar 09, 2008 | LG Art Cool LA1000PR Air Conditioner
Heating & Cooling Logo
759 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
