Question about MSI 945GCM5 Motherboard
Unable to save date in m/b bios
Unable to save date in mother board bios,replaced cmos battery and checked nogo..
    Scholar:
  • 70 Answers
Make sure your using new cmos battery not yet been use and then set date in your bios and save it after finish.
still doesn't work?
try update your cmos that migth be the problem note! remember always take care of the risk on updating flashing cmos on power interuption never power off if still flashing. or if you update and flush it before it might be a bad flash of your cmos try bring it up to early state or restore your backup cmos firmware or download it to its main manufacture
Posted on Jul 01, 2009
My HCL LAPTOP Serial No:         8074AX076106 Laptop Name:  P21PDC After restarting this laptop it's date and time become default and I had a bios password which I had forgotten please help me to recover...
hi if you have a member of your family or if you know what you are doing then go for it. "* PLEASE TURN OFF AND UNPLUG ALL POWER SOURCES (Battery and Power outlet) *" remove the back cover of your laptop and remove every screw to get to the BIOS/ CMOS Battery. Simply remove BIOS/ CMOS battery on mother board. first on the bottom of the laptop there is a large cover plastic thing. unscrew that and a small circle battery will be there, take out battery. secondly: plug in battery or mains then, go on to the bios and add a password. last: once added, save exit then go back on bios page , insert the CPU battery and then save and exit turn off laptop wait 30 seconds switch back on go on bios and it should be done.u may need to insert date and timeXD ( PLEASE NOT THIS IN NOT 100% effective some laptops BIOS chip need to be replaced)
Hope this helped. Thanks
Apr 03, 2014 | Computers & Internet
P4P800-VM BIOS was Upgrade but BIOS Date & Time can't save from BIOS
If your cmos battery is new and the date and time not change. Try the following.
1. Clean the cmos battery terminals.
2. Check your mother board if there is bulges capacitor.
3. Check the memory you have using if in the same voltage requirements.
Hope this will help to you.
Jun 15, 2012 | ASUS P4P800-VM Motherboard
How to save BIOS and change mother board CR2032 Lithium battery
if you only take 5 to 20 sec you might not lose any bios Cmos settings
im not sure what or why you want to save the settings for
once the Cmos battery has been removed for more than 30 - 60 sec your cmos settings will be restored which means no password and failsafe defaults
you could just restore failsafe or optimised defaults if you lose any Cmos settings
you will need to reset the password and the time and date
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps you
Oct 16, 2011 | Computers & Internet
Hello, when I put my pc running it says CMOS checksum error press F1 to enter or Del to enter setup, but I press Del when I save changes "save and exit" the computer restarts, but this time...
The Checksum error basically shows that boot settings which were previously set has been changed or reset. This usually happens when the battery loses its charge and thus fail to retain the CMOS settings. This can also be caused by a power surge or a damaged motherboard. But most of the times it would be the battery problem.
You can try replacing the CMOS battery and enter the values back into CMOS or reset values to default. Then switch off and boot up again.
Hope this works. Good Luck. ~SmokinJoe~
Apr 28, 2011 | EliteGroup KM400-M2 Motherboard
How to chang bios settings password intel Dg43nb board i m loss my bios password
All mother board has a CMOS, complementary metal oxide semiconductor, battery. The main purpose for the CMOS battery is to store the system time, date and bios settings even if the computer is turned off or the main battery dies.
Turn off the computer (laptop) unplug it. Remove the Phillips screws that secure the motherboard cover then release the cover from the clips on the bottom of the plastic casing. Lay the cover aside then locate the CMOS battery cable on the right side of the motherboard. Unplug the cable then remove the battery. After a few minutes plug the CMOS battery into the motherboard... Replace the screws then turn the computer (laptop) back over. The CMOS battery is unplugged for more than a few minutes your BIOS will be reset to the default manufacturer settings. (Password removed) now you can set new password for your bios..
Apr 20, 2011 | Office Equipment & Supplies
Bios rom checksum error.. system halted
This error comes when there is low cmos voltage so motherboard flash memory forgot the bios settings.
For that open cpu and then pull cmos cell from mother board buy new cmos cell and replaced it.
Then when you power up the computer press F1 or F2 or "del" key to enter in bios and set time and date and boot option in bios then save settings.
Then it works again if it not works then you need to update firmware for your bios .
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 07, 2009 | Foxconn K7S741MG-6L Motherboard
IBM Thinkpad will not hold date & time.
Replace the backup battery and run BIOS Setup Utility to reset the time and date. This will resolve the issue.
Sep 15, 2009 | IBM ThinkPad T22 2647 Notebook
My computer's bios doesn't save anything
Here's the manufacturer info link
http://www.intel.com/products/motherboard/DG31PR/configs.htm
BIOS Loses Date and Time (or Changed Settings Not Saved)
A coin-cell battery (CR2032) powers the real-time clock and CMOS memory. When the voltage of the CMOS battery drops below a certain level, the BIOS Setup program settings stored in CMOS RAM (for example, the date and time) might not be accurate. If you find that date and time is incorrect or if you make BIOS setting changes but they are not saved, replace the battery with an equivalent one. Caution Risk of explosion if the battery is replaced with an incorrect type. Batteries should be recycled where possible. Disposal of used batteries must be in accordance with local environmental regulations.
To replace the battery, follow these steps:
  1. Turn off all peripheral devices connected to the computer. Disconnect the computer’s power cord from the AC power source (wall outlet or power adapter).
  2. Remove the computer cover.
  4. With a medium flat-bladed screwdriver, gently pry the battery free from its connector. Note the orientation of the “+” and “-” on the battery.
  5. Install the new battery in the connector, orienting the “+” and “-” correctly.
  6. Replace the computer cover.
Jul 10, 2009 | Intel D915GAG Socket 775 Motherboard -...
Mercury motherboard pi945gcm cmos setting dose not save shut down machine then power on machine see press f1 date & time not save
This sounds like your battery may be bad or not locked into place fully. Also on the mother board there is a cmos jumper that is used to clear your bios check to make sure the jumper is set correctly an also inspect the jumper to make sure it will make good contact to the jumper posts. Good luck I hope this helps. Also when you set the time in your bios make sure to exit with f 10 key or whatever the save and exit key is for you bios.
May 15, 2009 | Computers & Internet
Password for 486
Remove the battery from the mother board.
Jumper the CMOS to discharge it. You may
want to check you Mother Board manual, to
see which jumper it is. Some require you to
turn the Mother Board BACK ON for two seconds. (It will NOT come up, just will
discharge the CMOS and the battery will NOT
be there to replace the energy, so everything
is GONE. You will know if you have done it right, when
you boot up again, the BIOS will NOT recognize the hard disk (need to set it up
again), the date will be wrong (set it up again also) and the floppy drive will not
be recognized (new setup). But then try your password. It should let
you right in then. Let me know if it works. Best Regards, PS Make sure you have the right mother
board jumpers to discharge the CMOS, YOU
CAN DO DAMAGE ALSO, if they are not the
right ones.
Jan 25, 2008 | Grandstream HandyTone 486 ATA (HTATA486)
MSI 945GCM5 Motherboard Logo
333 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
