Question about Epson Office Equipment & Supplies
How to check ink levels on epson colour 680 printer when connected to new dell inspiron laptop
  • Epson Master
  • 511 Answers
Does you printer driver full support for your OS? have epson status monitor installed?
Posted on Jun 30, 2009
My epson stylus 680 printerwiil no work if i dont install all of the coloured ink but i just want to print black only
Hy, you can not print if you don`t have all the cartridges in the printer (this is a protection from the producer so your printhead dosent burn out. The only hay is to go to the printer menu in your P.C or MAC and in printing preferences select to print in grayscale. After that your printer will ony use BK ink.
May 25, 2012 | Epson Stylus Multifunction Inkjet Printer/...
EPSON R265 cd/dvd printer can not print in black colour I have tried to reintall the driver but still can't print in black ink. Other colours print well. Ink cartridges are new.
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or
poor ink cartridge contacts.
Jun 06, 2011 | Epson Stylus R265 InkJet Photo Printer
All colours except the black appear to be printing on my Epson C64 InkJet printer. What could be the problem?
On this printer, the black colour is a separate cartridge.
It is possible that is has run out of ink or maybe is blocked in some way.
Try removing the black cartridge and hold it up to a bright light to check the ink level.
Make sure the contacts where the ink flows out are clean and not blocked with dirt.
If there is plenty of ink but it still won't print then try a new black cartridge.
Please rate my answer if you find this helpful.
Many thanks,
Chris
Mar 05, 2011 | Epson C64 InkJet Printer
Epson colour 680 green and red lights on, will not print
  • Pressing and holding LOAD/EJECT and CLEANING buttons,
  • press POWER button and hold it until You will see blinking INK OUT and PAPER OUT leds.
  • Release all buttons.
  • In 2-3 seconds time press and hold LOAD/EJECT button, until all leds will blink.
Aug 14, 2010 | Epson Stylus 680 InkJet Color Printer
I've just installed both a new black cartridge and a colour one but after having to clean the heads a number of times to try and get the print quality back up to scratch the printer is now refusing to do...
.. is the light flashing alternate? if yes, then the printer porous pad need to be replaced and reset ink counter.. install your printer driver and status monitor and you should be able to find out whether it's the ink empty or maintenance needed. For this model.. I am sure your waste ink counter is full...
May 20, 2010 | Epson Stylus 680 InkJet Color Printer
Epson DX4850 problem getting ink levels to highlight using Vista
Checking the level of ink in an Epson printer can be done without having to remove the ink cartridges. This method works on black and white as well as color inkjet printers. Checking the level of ink can help you plan ahead when buying new cartridges
Instructions:
  • Install the Epson StatusMonitor software. This program comes on the CD included with the printer. It can also be downloaded from the Epson Web site. or from http://download.cnet.com/Epson-Status-Monitor-2/3000-2116_4-10024738.html
  • Open the Epson StatusMonitor program in any application (such as word processing, spreadsheets or Web browsers) that allows you to print. Click on the "File" menu tab in the control bar of the application
  • Select print or page setup from the "File" menu. A dialog box will open. In that box, click on the "StatusMonitor" icon, which will open the "Epson StatusMonitor" dialog box. Also, you can click on the "Utility" icon and then the "Epson StatusMonitor" button from the "Utility" dialog box.
  • Click on the "Update" button to update the display (if you do not think these levels are accurate) when the "Epson StatusMonitor" dialog box displays the relative ink levels for each cartridge in the printer.
  • Go back to the "Print" dialog box to change the way that the StatusMonitor utility monitors your printer and ink levels. Click on the "Utility" button again.
  • Click on the "Configuration" button in the "Utility" dialog box. The open "Configuration" dialog box will let you adjust settings such as ink level warnings and ink level monitoring before each printing.
Please let me know if the provided information has been helpful.
Please rate me if the information provided was able to help you.
Sep 16, 2009 | HP PSC 2210 All-In-One InkJet Printer
Epson stylus PHOTO R350 Repeatedly indicates 'out of ink' for all colours despite replacement and nil or minimin subsequent use----am extremely frustrated by this, am consideriing buying new...
Out of ink for all colours? If you don't use CISS, are the replacement ink tank new? Chip in ink tank stored ink level counter. If it reach zero, chip can't use. Check chip contact at ink tank, and chip connector at head carriage. Don't be frustated, man. I have thousands experiences like that. Two unsolved, that board is burning. If, chip conector is clean, use chip that no reach zero level. Good luck.
Jun 14, 2009 | Epson Stylus Photo R200 InkJet Printer
I can't print from my Dell Latitude D600 notebook to my Epson Stylus C60 printer -- a red light in the middle (ink?) button is on. How do I fix it?
If ok you have the correct driver showing a more or less ink level.
Problem is that one of the colours out, you need to refill (dangerous on Epsons, wrong refill ruins whole printer) or buy new cartridge. I prefer HP but do own that Epson also. First to come ourt then with high resolution
May 02, 2009 | Epson Stylus C60 InkJet Printer
Epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Apr 02, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Poor print quality
im sure your familiar doing the head cleaning from the computer / driver at least 3x consecutively
and still the issue persists, hardware problem
printer needs service / this might come handy : http://www.epson.com/loyalty
Jan 03, 2008 | Epson Stylus 680 InkJet Color Printer
150 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
