The oven is from the 1970's and we have to use a screw driver to set the oven temp on the lower one. Also, it is not that accurate. Where can I get new thermostats ?
Get any and all numbers you can find from the original controls. Also make a note as to the length of dial shafts, direction they turn, shaft size and "flat" location when in off position and the temperature range and whether high to low or low to high.
Then go to this site and search for exact or something that you could live with. . . . http://www.uni-line.com/modules/catalog/SearchResults.aspx?catName=19145&pID=18668&mode=categorysearch . Hope this helps!!
SOURCE: New replacement thermostat needs calibrating on my Kenmore oven
There is no real way to calibrate the thermostat. Most ovens have the same problem. By lowering the setting slightly will help get a closer temperature. Sometimes similar thermostats are substituted and may not be exactly the same as the original that came with your oven. Hope my trying to answer your question was helpful, Thanks, Sea breeze
SOURCE: F7 code showing on double oven
NOT YET RESOLVED..... I DID NOT FOLLOW THROUGH WITH POSTING WHEN REALIZED THERE WOULD BE A COST. DID NOT ACCEPT THE 7 DAY FREE TRIAL. REMOVE MY REQUEST FROM YOUR WEBSITE.
SOURCE: Our oven doesn't work but the burners do. The
Check for power to the ignitor.... if you have power and it don't light... then the ignitor is bad...
if no power then look to see why there is no power...
heatman101
