Question about Jensen VM9510 Car DVD Player
Why doesn't my remote doesn't work for jensen VM9510? I b
I bought new batteries and still nothing
SOURCE:
jackboy
  • 2985 Answers
SOURCE: vm9510 wont play cd/mp3 formats
Does it say it will play MP3 somewhere? This is a recent innovation with CD players Regular players do no include MP3 in the firmware.
Posted on Jun 16, 2007
Benimur
  • 6966 Answers
SOURCE: whats up
The color coding and wiring connections are illustrated in the owner's manual. An online copy is available for download here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 01, 2008
SOURCE: i need an origenal owners manual for my jensen
www.audiovox.com/manuals/owners/vm9510_manual_final.pdf If i'm not mistaking, this is the closest thing that i could find for the Dual 8180 also
Posted on Feb 28, 2009
lostinfamily
  • 149 Answers
SOURCE: Replacement remote
You can go to the site below to order a new remote. The one that is the factory model is about $52 and the generic one is abour $40.
http://www.remotes.com/store/jensen/vm9510.html
Good Luck I hope this helps
Posted on Mar 03, 2009
SOURCE: Need the parking bypass code for jensen vm9510
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote, listening for the beep for each number entered
4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen.
5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen
6. I am not responsible for whatever you do with this code!!!
Posted on Jun 20, 2009
Jensen VM9314 remote does not work...not the battery
Your remote may be faulty.
I would either take it to an autozone and check it is working there ( they have an infrared remote check on their keyless remote battery center that will show the IR signal being sent).
OR
you can point it at almost any of the security cameras in production and view the 'IR flashlight' on the video screen/ monitor.
If the remote is in fact not producing a light , I will assume the unit needs replacement batterys or remote.
Alternately , you can disassemble the remote and check the IR emitter with an Ohm/Volt meter.
should the signal be present on the meter and yet no 'light' is being emitted , then replace the emitter with a new one (avail. at radio shack...)
If the remote does emit a signal , chances are the reciever is bad.
My Jensen came with two remotes... did you try the other one ?
Oct 04, 2011 | Jensen VM9510 Car DVD Player
I lost my remote need a new one
you lost BOTH remotes?
there is a place on the web that does nothing but remotes..
http://remotes.com/store/jensen/vm9510_full.html
Sep 30, 2010 | Jensen VM9510 Car DVD Player
I bought jensen vm9510 used it did not with the
does it plugg in. then it should be fine.allot of manufactureres make the newer modles have the same wiring harness as the older ones
Mar 06, 2010 | Jensen VM9510 Car DVD Player
Replacement remote
Mar 03, 2009 | Jensen VM9510 Car DVD Player
No Audio on Jensen UV8
I just bought the uv8. Ist I must say i hate it, it was the worst purchase made. Amoungst others problems, your answer to solve no audio is this.
<<push mute button>> then volume up. you'll have sound. good luck
Jan 03, 2009 | Jensen VM9510 Car DVD Player
Jensen in dash dvd/mp3
PUT IN A DVD FIRST AND THEN PUT IN THIS CODE (543210) HOLD DOWN THE 0 FOR 4 SECONDS.
Jan 16, 2008 | Jensen VM9510 Car DVD Player
Jensen in dash dvd monitors
jensen double din dvd monitor it a uv8020 model to bypass the e brake or parking brake
Dec 19, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9412
ON YOUR REMOTE GO TO THE SETUP MENU SELECT, LANGUAGE TAB ENTER CODE 5,4,3,2,1,0 THIS WILL BRING UP MENU TO DISABLE PRAKING BRAKE SET IT TO THE ON POSITION. THIS WILL DISABLE THE E BRAKE. I NEED A CODE TO DISABLE MACROS
Aug 10, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9510 Car DVD Player Logo
103 people viewed this question
Top Jensen Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
