Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave not heating was fine then not?????
Was fine then used again and didnt heat. works as usual tho no buzzing lights still on??? weird
  • 65 Answers
It could be an internal fuse, but these fuses are very high rated ( typically 5kv 8amp) and should be fitted by a qualified technician only.
Posted on Jun 30, 2009
Sanyo EM-SL40S microwave everything seems to be working fine but food doesn't get hot?
see this causes and fix it. GOD BLESS YOU
Power Diode
A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat and you will hear a buzzing noise. Test the diode to determine if this is the cause of your problem. Replace it if it is defective.
High Voltage Capacitor
A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating but you are hearing a buzzing or humming noise. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.
Magnetron
A defective magnetron is the third possible cause of why your microwave is not heating, but you can hear a buzzing noise. Test your microwave's magnetron. Replace it if it is defective.
Thermoprotector If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
High Voltage Transformer If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
Oct 01, 2012 | Microwave Ovens
Kenmore microwave Model No. 721.62463201 runs but does not heat and has a terrificately loud buzz. All lights displays are normal
Hello there:
There's no heat, but it buzzes loudly When the microwave won't heat, but you hear a loud buzz, you usually have a defective power diode, high-voltage capacitor, or magnetron. I recommend that you consult with a qualified appliance repair technician for help in determining the problem and deciding what to do about it.
And if you have your warranty for this you can use it to ok
Hope this helps best regards mike
Nov 19, 2010 | Kenmore Microwave Ovens
Microwave won't heat, light ,clock works the microwave just won't heat the items in it.
hELLO THERE
when a microwave quits heating but every thing else is ok normally
investigate these 4 areas
Investigate these three areas if your microwave won't heat but you hear a loud buzzing or humming noise:
microwave_diode.jpg Power Diode
picturena.gif High Voltage Capacitor
microwave_magnetron.jpg Magnetron
Nov 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave jvm160wj01 was working and suddenly started buzzing, gave bad electric/burnt smell and buzzes. Still buzzes and does not seem to heat now.
Sounds like the magnetron just shorted out. Its the part the generates the microwaves that heat the food. Buzzing sounds are a symptom of a shorted mag. Usually not worth fixing since the magnetron costs almost as much as a new oven. Sorry.
Jul 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave will not heat
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
 Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section.
Mar 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave does not heat and makes loud buzzing noise.
I have just replaced the magnatrton for a Kenmore microwave model # 665.606.5900 as before replacing the part there is still the buzzing sound and non-heating
Dec 10, 2008 | Whirlpool GH8155XM Microwave Oven
I purchased a GE microwave oven in March 2008. It was working just fine, then I went to use it again, and it will not heat anything. The light comes on, the turn table turns, but does not heat naything. ...
I'd say you have a bad magnetron, but it will have a full one year warranty on parts and labor.
Let GE fix it for you free. GE Customer Service is online here.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 25, 2008 | GE Microwave Ovens
Microwave Buzzing, Still Heats, but Turntable And Fan Not Working
This is not safe. If the fan is not running, the magnetron will quickly overheat and be destroyed. We answered this in more depth in the other place you asked it.
Feb 24, 2007 | GE JVM1441 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
291 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
