Question about Sony STR-DG820 Receiver
Humming noise through surround sound
when i play my blu rays through my ps3 which is connected to my sony strdg820 amplifier via hdmi i get a very slight hum through my surround sound speakers is there anything you recommend
  • matthewmould Jun 30, 2009
    i only bought my amplifier 3 months ago though and nothing else seems to have the same problem and i have my sky and dvd player running through my amplifier. and i have just bought a new hdmi cable recently so i cant imagine it being that.
  • 2,071 Answers
This a problem of input grounding,the cable input is already loose or crack solder that why you hear a hum or distorted sound because not properly grounded it is a loose contact already thats why also is need to warm up and it will come.First change the cables with a new one with identical size and value then if problem still exist open the back cover ,when open look for the cable input connection parts joints reworks or resolder all soldered joints there .Then checks if it works then cover the unit.If you have no knowledge of electronics dont attempt to open to avoid electric shock.Find a electronics repairman or bring this to a authorized electronics repair shop maybe it cost you only $50.
Good luck;
Dont forget to rate...
Regards:
VOTIT
Posted on Jun 30, 2009
  • LORETO LACARON
    LORETO LACARON Jun 30, 2009
    Yes that is the symptom of not properly grounding maybe it is a loose contact. Check this out..
    Regards
No surround sound when playing PS3 through HTDDWG700 via 2 HDMI
The HTDDWG700 does not transfer the audio through the HDMI cable that the vision goes through. To solve the problem i got an optical cable and connected the PS3 to the receiver with the optical and put the HDMI cable from the PS3 to the tv.
Oct 18, 2009 | Sony Playstation 3 (PS3) Console
Surround sound speakers distort when playing blue ray dvd.
what you have to do is turn off your system then turn it on until you get 2 beeps. then go through the on screen instr.
Jun 28, 2009 | Sony Playstation 3 (PS3) Console
Can't get 5.1 audio from bose surround system using PS3 blueray
Yes but first thing, the blu-ray disc you are playing must be 5.1 to get true 5.1. If it is an older movie/TV show, then it might be only 2 channel audio. If this is the case, then your Bose system needs to create simulated 5.1 surround sound, which is not true 5.1. However, if your blu-ray disc is a true 5.1, then your PS3 needs to be set to output 5.1. I am not familiar with the PS3 so I am not sure where to located that setting. Also, try other blu-ray discs.
Apr 25, 2009 | Sony Playstation 3 (PS3) Console
Connect PS3 for playing/viewing blue-ray thru surround sound
I just finished setting up my system last night and was facing similar problems with sound/video from my PS3. The only option I could get working was to have the HDMI cable connected from the PS3 to the TV and then connect the Optical cable to the receiver for sound. I was under the impression that HDMI handles sound and video but for whatever reason the PS3 does not agree.
I have DTS sound and fantastic picture now through my PS3, hope this helps.
Cheers
Oct 05, 2008 | Sony DAV-HDX500 System
No sound through tv speakers
Well the problem is that the PS3 only allows output on one channel. So, this is only going to be optical out, or hdmi, or even AV. You only get one option for the output.
Now, if your TV has the capability.. Run the sound through the HDMI to the TV and then let the TV output the digital sound to the surround system. This will give you the option of turning off the surround and re-enabling the TV's stereo speakers.
I hope this gives you an idea of what the problem is. If I were you, I'd just do as I said. This is exactly how I have mine setup. I have a 600w sub on the surround, so late night movies can't be played on it without the neighbors being woke up. So, I simply disable the TV's output and use it's speakers. :)
Sep 13, 2008 | Audio Players & Recorders
PS3 Surround SOund
go to the audio settings, i'm not sure what it was it was called like linear pcm or something like that...it worked for em
Mar 08, 2008 | Sony Playstation 3 (PS3) Console
NO SURROUND SOUND WHEN PLAYING BLU-RAY
Your amplifier should "downgrade" the signal to 5.1, even if the disc isn't using it. It is most likely a setting on your amp that may need adjusting for "types" of digital to accept on its input. If you can, set your optical input on your amp to "auto". This way it will automatically detect and switch for the proper incoming audio feed
Jan 01, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
Open Questions:
See all Sony STR-DG820 Receiver Questions
Sony STR-DG820 Receiver Logo
453 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
