Question about Acer PD116 Multimedia Projector
Software reset PD116P
My Acer PD116P projector does not show his menus anymore nor do I have the option to select an input source. How can I reset the projectors software?
  • matthew_depu
    matthew_depu Apr 02, 2012
    I have the same problem with mine....please email me @matthew.Deputy@yahoo.com if you have found a solution with yours.
    Champion:
  • 205 Answers
Push and hold the circle arrow button and power up, then release. if not, make sure the hide button is not enabled.Not much help on this one good luck
Posted on Jul 07, 2009
I have been using this Acer projector but it suddenly locked. The display shows the acer logo, no signal and a lock. I can not unlock it. What must I do to unlock it. I am not using any password.
it means the projector
locks on this source type and there is no such type of input
signal found,
so you need to try new input source type . means : if you use for example VGA, try to use other input type such DVI , HDMI
Nov 10, 2016 | Acer Computers & Internet
It say no source found
Hello Abugah,
For "no source found" errors, we recommend starting with the input device and the wires (assuming you have selected the correct input on the projector). Swap wires and sources until you figure out if the problem is with the projector or not.
If you are using a computer, make sure that it is on the right settings. On laptops there is usually a button you can press to cycle through display options (normally a function key + another).
If you figure out that it is, in fact, a problem with the projector we recommend going to a professional to fix the problem. If you are in the United States we can fix the projector. Projector AV Systems Repair Services
Before you send in the projector to anyone, contact Optoma to see if it is still under warranty.
Hope this helps!
Jun 30, 2014 | Optoma EX615 DLP Projector
Need to reset projector to factory default settings
hold the power button until it beeps or turns on ect but keep holding it and it should reset
Dec 07, 2013 | Acer X1261P - DLP projector - 3D - 2700...
Locked in searching source
Click menu, go to the third screen, unclick source lock, and select the proper source, remember that the format need to be setup according to your output that's coming in to the projector. Under each source format there are sub menus for various input types as well.
Tony
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Feb 09, 2013 | InFocus ScreenPlay 5700 Multimedia...
The screen is upside down and when I click "set up" or "System" it reads "Source Unavailable" and I have no options to choose from.
Apply the Factory Reset within the projector options. You should be able to select that option without a source attached to the projector. What the option does is set every settings of the projector back to factory default.
Aug 07, 2011 | InFocus LP280 Projector, Factory...
I have connected laptop to infocus projector and both are powered on. I have pressed Fn/F4 to toggle the laptop to project. However, Nothing will project!!! What can I do. I have checked the connections...
make sure you have the settings correct on the projector. select computer on the top panel. if still nothing, reset the settings to factory default (in the menu). also make sure you have matched resolution.
Nov 21, 2009 | InFocus ScreenPlay 4805 Multimedia...
How achieve maximum resolution acer projector
When you connect a source to the projector, the unit will match the resolution input to it. As long as you don't exceed the max resolution, which is considerable, the unit will display it. Go into the menu and select auto-image to have the projector give you the best quality image. Hope I helped you!---Rick
Jul 08, 2009 | Acer X1160Z Projector
Not recognizing any source
Hi, i hope this works for you, all you need to do is press the source button this makes the projector search for active inputs.
Nov 06, 2008 | Acer PH110 Multimedia Projector
SRC button on cinego projector will not read source
Three (3) things you can try:
1. Lower down the Screen resolution of your laptop as well as the Color quality and the Screen refresh rate before doing the Fn + F5. If it works, adjust thereafter;
2. Do a soft (Factory) reset of your Cinego in the in the Management Menu (credit to Cooljazz); and/or
3. it is just "slow" in sensing the presence of a VGA source as it cycles in its selection, internal DVD, VGA, Composite Video IN. Since it does not have a manual source selection, your only option is to really wait or ...Verify that "Auto Source Select" is enabled in the Management Menu (buttons-Proj/Setup then >/9) and "tap" the "SRC" button on the projector itself to manually initiate the input/source selection.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 14, 2008 | Radio Shack Cinego D-1000 Multimedia...
Acer PD116 Multimedia Projector Logo
530 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
Marvin
Marvin
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
