Question about Canon Pixma MP500 All-In-One InkJet Printer
Why does my pictures have lines acroos them after printing?
The print cartridges probably aren't aligned - or running low.
I recommend going into word and pressing Ctrl-P, then pressing preferences and going into the maintenance tab. From there, complete all of the cleaning processes. It should definately help.
Luke
Posted on Jul 06, 2009
When tv turns on lines go acroos top half
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there.
Nov 27, 2012 | Hitachi 55HDS69 55 in. Plasma Television
Blue shadows and a yellow and blue arc acroos the bottom of the screen
Tv have a problems known as a convergence problems it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board it is dead.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 02, 2011 | Pioneer SD-582HD5 58" Rear Projection...
We turned the TV on and there was a rainbow curvy lines acroos half the screen
Ur tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 02, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Several lines run across the top of the screen
Several lines acroos the screen at the top along with picture is a typical fault. You are seeing vertical retrace lines. Either the supply smoothing capacitor to the power supply given to vertical output Ic or vertical output capacitor connected to the vertical output pin of that Ic may faulty. Usually the supply smoothing capacitor seen faulty. It may be over 1500Mfd eletrolytic capacitor used there. It may get value reduced by 40 percent or so, this falult will occur. Please replace the two capacitors together and will get the result.
Oct 15, 2010 | Toshiba 27A34 27" TV
ANYTHING I PRINT OFF HAS DIAGNAL LINES ACROOS THE PICTURE I HAVE PUT NEW INK IN BUT IT DOENT HELP. THANKS
Try to go to the setup for your printer then troubleshoot tab. There you could setup for cleaning the print heads and also the alignments.
Oct 04, 2010 | Canon i350 InkJet Printer
Just have horizontal line acroos screen. can hear channel and can change channel.
This is a problem with the vertical circuit. Usually it turns out to be a de3fective vertical IC. Can you please update this with the make and model of the set? With that info, I can provide additional details about the problem and its solution.
Thanks,
Dan
Nov 20, 2009 | Televison & Video
Blue line acroos the top and grey picture
not able to assist you with your problem, but if you give up on trying to get your issue resolved and decide to get rid of the tv and wish to sell it fo rparts then please contact me as i am in desperate need of the lense out of the front of this unit you have. Thank you i can be reached via email @ mrshadetree0222@aol.com, or via phone# 304-937-2369
Feb 16, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi VS-45607 45" Big Screen
Good Day, Delano1981;
It may cure the problem but I would suspect the 9 Volt source
CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND
IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH
ARE ON THE SIGNAL PCB.
This should resolve your TV"s condition.
Good Luck, big IRISH.
May 27, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Problem with picture
my tv got blue line acroos screen and a yeloow shade on top of screen What can i do
Nov 19, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Canon Pixma MP500 All-In-One InkJet Printer Logo
old marine
old marine
