Question about Foxconn Computers & Internet
Foxconn 761gxk8mbm/b cant find old or new sata h/drives on reinstall of xp
  • 375 Answers
XP doesn't have the drivers for SATA - so it can't see them during the installation, and has nowhere to install to. You will need to make up a driver disk/CD/USB and use the "F6" installation option during the XP install to load new drivers.
Posted on Jun 30, 2009
The Bios sees my new SATA 750GB HDD but shows it as 0GB in Size and no options to format. XP does not see the drive. How do I format it from the BIOS Setup Menu? It is connected correctly.
so what is the 1st drive, and is it IDE or SATA.
or is one a
why are you using XP is it 32bit or 64? ill answer for 32..
its a dead OS,totally dead,and virus magnet and the MS PnP severs are shut down.
XP also MUST have the SP3 installed or the THING cant find any modern, SATA chips and many other devices.
im looking at your MOBO now,
it has 4 sata jacks
1 floppy
and 1 IDE jack let me guess this is what Drive one, IDE (pata)
is plugged in , then you add a new sata drive to the old sata ports
and XP pukesssss, as all XP does (cept mine)
SSDD. Same stuff different day,
so you can either use w7 like all savvy folks do
or find the driver missing that MS cant find, XP is dead.
but wait XP needs a Floppy drive to load the correct driver.
but if XP is running now, we dont need that only on XP installs.
ive no idea on what sata chip is there, in our shop
we scan it to find that and HP does not tell this.
Pentium D processor
Intel 945G Express
i think this is it , the 945G
load this driver from HP
https://support.hp.com/us-en/drivers/selfservice/hp-compaq-dc7600-convertible-minitower-pc/472276
32bit
File name:
sp38488.exe (2.0 MB)
Nov 16, 2017 | HP Compaq dc7600 Convertible Minitower PC...
I cant download op cd
If the new hard disk is a SATA hard disl then the problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Feb 18, 2012 | Computers & Internet
I want to instal a windows XP SP3 on Foxconn 915 series with north bridgegrantsdale G-i915G with a IDE H.D.D (pata) and sata O.D.D,it seems that i need a floppy disk for raid driver,but i lost motherboard...
There are a couple options.
  • Check in BIOS to see if your motherboard supports IDE emulation mode. If it does turn it on and XP will install just fine.
  • Download and read about using nlite to incorporate sata drivers into an Windows XP installation disc. (You will need another working computer. Download nlite and insert the XP disc run nlite and select your CD as your windows install file location. Download generic sata drivers, intel has a bunch you can get for free. In the nlite menu to add drivers select folder option and select the folder with the drivers. Set anything else you want in nlite and burn the new XP disc. This disc will install just fine as it now has sata drivers.
Comment if you need further instruction.
Aug 18, 2011 | Foxconn 915P7AC-8KS Motherboard
I want to disable sata mode on my sony vaio vgn-fs742/w, please help because i cant reinstall xp on the system and the lan and wireless in not working when i install windows 7 on it.
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Jun 29, 2011 | Sony VAIO VGN-FS742/W Notebook
Mine hitachi hard disk is 80GB SATA i cant able to install OS because it is showing error some virus found and u r not able to formate this. first when i put OS CD in drive it will install some files and...
Apr 15, 2011 | Hitachi (14R9464-20PK) 250 GB Hard Drive
Need raid pata driver for foxconn rc4107ma motherboard
Normally RAID setup on board, is handled in the BIOS settings.
Feb 21, 2010 | Computers & Internet
Ms 7142 Msi board, cant install xp with sata hdd
I think this is your board, K8MM-V. The following is the link to all drivers and info regarding said mobo:
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=173
Dec 30, 2009 | MSI K8MM-V Motherboard
Run a sata drive as main boot up drive. Xp on ide cant see new sata drive to format or install Windows 7?
XP installation does not have SATA drivers.
You need to have the SATA driver on a floppy disk and during the XP installation press F6 to install the SATA driver.
The other alternative is to change the BIOS configuration and set the disk controller to IDE or SATA native driver, then install XP.
After Windows installation then install the SATA driver.
Download the driver from the motherboard WEB site.
Oct 10, 2009 | ASUS K8S-MX Motherboard
XP DOES NOT SEE MY SATA DRIVE
Windows XP requires SATA drivers in order to see you sata drive. Download the appropriate drivers from your hdd manufacturers website. Hope this helps.
May 04, 2009 | Foxconn 655A01-FX-6LRS Motherboard
Can't reinstall windows xp
hmmm its seems your HDD is of SATA interface and XP is not able to detect the HDD interface. you can solve this problem by making SATA Disabled in BIOS setup.
Try to make disabled SATA from BIOS, and then make install.
If any problem... Ask me
Thanks
Iqbal
Apr 05, 2008 | HP Compaq Presario C304NR Notebook
Computers & Internet Logo
126 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
