Question about Kitchen Ranges
Glue failed on thermostop glass and it fell out oven is 3months old. how do i refit it ?
3 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: GE Profile range oven door
theres a bottom trim that installs from under the doorwith 3 phillips screws, this is what holds the door in place. it probably rests under the hanndlesupport and is held up by this strip, take a close look at bottom of door and you see the removable metal strip..
Posted on Mar 20, 2008
  • 18 Answers
SOURCE: replace glass on front of oven
Hi You need a high temperature silicone adhesive designed for this purpose. There are a number of companies that make a suitable glue. There is also a company, http://ovendoorglue.co.uk that make a small kit specifically for the purpose of fixing your oven door. Do not use normal adhesive, as the correct adhesive not only is heat proof to 300 degrees centigrade, but also remains flexible when cured. This ensures that as the oven heats up, and the metal and glass expand, the flexibility in the glue prevents stress in the glass. Dow Corning make a glue that can be used, but be aware that it is red, and so may show. Other glues are black. Indeed the black glues tend to be slightly thicker on application and dry quicker.
Posted on Jun 08, 2009
My Siemens HF759 (Stainless steel) front has come away from the glass and is only hanging via the top of the glass by the handle. How do I put it back?
You can remove the front glass and trim by removing the two torx screws at the top of the door, they are the ones next to the prongs that stickup from the door when open. Once these are removed the door front lifts up as the bottom is only hooked on. It looks like you need to remove more screws but you don't. A two person job as the door needs to be held in the nearly closed position as you lift off the front. Once you have the door off remove the two screws holding the handle on and it is then just the glue holding the trim on which in your case and mine has failed. I googled for oven door glue and found a very good site which has excellent instructions and video for application. The biggest hassle was cleaning off the old glue (scraper and acetone) and making sure it was aligned correctly before gluing, I used masking tape for a few dry runs as you only get one chance with the glue and it goes off quickly. Hope this helps.
Oct 08, 2013 | Siemens HF87950GB Convection Microwave...
Replacing broken door frame; can I remove old glass and hot glue into new frame?
get a tube of RTV compound at Home Depot, Lowes, etc for a caulking gun. Much neater to use as the pros use it also
Oct 09, 2012 | Whirlpool GH7145XF Microwave Oven
H4080bm Miele microwave handle fell off
Hi Try not to open door with handle as this may cause to glass to smash. When you open the door you will see two pin sticking forward near the top of the door just further back on the top of the door is two small barbs push down on these barbs located in line but further back from the pins.This will release the top of the outer door.The bottom of the glass is hooked into the hinge. with the top released lift door glass away.You should find screw in inner door refit screw with some loctite.
Aug 23, 2010 | Miele H4080BMSS Oven
Glass panel unstuck
if product is beocenter 9000/8000/8500/9300/9500 remove screw under l/h side of panel, push panel to side and remove.careful to note position of plastic attachments and metal screw socket.lay face down on bench and apply thin ribbon of epoxy resin where double sided tape is,do not clean off old tape.apply glue over top.assemble plastic parts on top and leave to set.refit to machine and refit screw.
Oct 14, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Replace glass on front of oven
Jun 07, 2009 | Kenmore Kitchen Ranges
Inside glass fell out , how do i glue it back.
Everflex Heatmate
Temperature Resistant Glue upto 300 degrees c
Apr 24, 2009 | Zanussi ZBF360X Electric Single Oven
Hotpoint ew83p oven has no heat
The oven fan element has failed, you need to fit a new one.
Remove inner rear panel of oven and you will see the round element at rear.Unscew screw(s) that secure element, disconnect leads, and fit new element.
Refit element cover.
Job done..
Make sure you have power off to oven before you start.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Neff B1641 Single circotherm super...
INTERIOR REARVIEW MIRROR FELL OFF
Just about all auto parts stores carry a little kit that includes slovent and glue to replace the metal "nub" onto the glass. There is a screw on the mirror that attaches the mirror to this "nub". Do not use force to remove the old glue or nub, windshield will crack.
Jul 27, 2008 | Honda Odyssey Cars & Trucks
Mar 20, 2008 | Hotpoint RB787 Electric Kitchen Range
Kitchen Ranges Logo
46 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
