Question about SanDisk Sansa e270 MP3 Player
How to select next song from a list
I am using sandisk E270 6gb mp3 player.I have installed rockbox 3.2 version in my player. I have one question about how to select the next song while you are listening a list of 50 songs. NEXT button is not working in my player , it only fast forwards the current song.
    President:
  • 942 Answers
Do you see the circle in the center you just swing it left to right or right to left
Posted on Jun 30, 2009
I have rockbox on my sansa fuze mp3 player and i want to reset it
Rockbox has a dual-boot feature. To boot into the original firmware, press and hold the
Left button while turning on the player.
The player will always boot into the original firmware if it is powered by a USB
connection, and additionally will do so if USB is inserted while rockbox is running without
holding Select. This feature may be removed in the future when Rockbox is able to
handle USB transfers natively.
3.
Jul 05, 2010 | SanDisk Sansa Fuze MP3 Player
My Sansa Clip died after installing Rockbox!
Maybe installing Rockbox makes your device corruption. If plug the device to pc, the pc still recognize it, update new firmware from sandisk official site, http://forums.sandisk.com/sansa/
Good luck
Apr 19, 2010 | SanDisk Sansa Clip MP3 Player
I bought a 4GB PNY Micro SD HC card for my e250, which will not show up on my computer. Is this the right card for the e250?
Sandisk Sansa e200 models will NOT detect cards over 2GB capacity. There is a firmware known as rockbox that will allow up to 32GB of space but its only recomended if you are familiar with transfering and installing files to your player. Rockbox firmware can be found at http://www.rockbox.org/ by just selecting your model.
Jul 16, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e260 doesn't recognize my 8GB sandisk expansion card
Sandisk sansa e200 series players only allow up to 2GB expansion, BUT with rockbox firmware up to 32GB is available. Only download rockbox firmware if your familiar with transfering and installing files.
Jul 15, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e270 next song play problem
if you are holding it down (all you are doing ff or rewind), but if you tap it will skip...plus you can also go to menu settings playback settings and change the skip / backward from seconds, mins and whole track...
hope this help
Jun 30, 2009 | SanDisk Sansa e270 MP3 Player
Sansa e270 playlist in rockbox
all tracks will be in their proper folder, but as far playlist (that is winamp playlist) rockbox will create a playlist unless you change it .....
here read 4.4 of rockbox http://download.rockbox.org/manual/rockbox-sansae200/rockbox-buildch4.html#x7-650004.4
Mar 18, 2009 | SanDisk Sansa e270 MP3 Player
Cannot install rockbox on my sansa e250
did you extract rockbox...........did you patch it you need this also (DOWNLOAD THIS FROM HERE) http://download.rockbox.org/bootloader/sandisk-sansa/sansapatcher/win32/sansapatcher.exe
once you do this plug device to pc...copy what was extracted and paste to root of the device
installation link http://download.rockbox.org/manual/rockbox-sansae200/rockbox-buildch2.html#x4-60002
manual http://download.rockbox.org/manual/rockbox-sansae200/rockbox-build.html
have fun rock with the box
Feb 03, 2009 | SanDisk Sansa e250 MP3 Player
Max. micro sd card size compatible for Sansa C240
It depends on the version. v1 players can support up to 2GB. v2 players can support up to 8GB.
You can find out what version you have by going into Settings -> System and look at the version. If it starts with a 01 then it's a v1, if it starts with an 03 then it's a v2.
You can use a card up to 8GB if it's a v1 player by installing Rockbox on it. It's a 3rd party firmware for some mp3 players - although you should make sure to read any instructions for installing it, as well as read the manual.
-> Rockbox.org
I will stress this again: make sure you know what you are doing by reading installation instructions and the manual.
In order to install Rockbox on your player it needs to be in MSC mode (Settings -> USB -> MSC). If your player doesn't have the USB option in the Settings menu then you will need to downgrade your firmware. There's info on this in the Sandisk forums about how to do this.
Jan 29, 2009 | SanDisk Sansa c240 MP3 Player
Why my sansa c250 does not record the voice in mp3, only in wma?
Unfortunately, Sandisk didn't include any options in their firmware to record in any other format.
If you happen to have a version 1 c250 then you can install Rockbox on it and have 4 recording format options, as well as being able to choose what bitrate to record in for the mp3 format.
To find out if your player is a v1 go to Settings -> System Info
If the version starts with 01 then it's a v1 player and you can install Rockbox on it. If it starts with 03 then it's a v2 player and you're stuck with the wav format, as Rockbox is not yet available for v2 c250 players.
Jan 13, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Computer doesn't recognize songs
I've worked mine out.
When I put the songs on my MP3 I used Vista, I then changed to an XP install and this is when I couldn't see the songs on my MP3 player.
When I went back to my Vista install I could see and edit the songs.
Now I have cleaerd it I can go back to my XP install and use it as normal again.
Basically you need to use the same version of windows you put the songs on with to edit them.
Jan 11, 2009 | SanDisk Sansa c240 MP3 Player
SanDisk Sansa e270 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
