Question about Video Game Consoles & Games
Ok i ahve g force 8600GT jesturday all wos ok but when today i turn on pc there wos no picture at all from the card sow i connected my monitor to motherbvoard video card now i see that in controll panel in device menager is a ?-on vga controler is taht for my garphic card and when i try to install driver it say taht NOT FOUND :(
  • ccode1 Jun 30, 2009
    ok i acnt install the driver bicouse my computer dont realize that i have graphic card like its connected NOTHING only ventiletor is spining on graphic card and that is it when i try to install driver instalation say no specific hardver found for this instalation like teh garphic acrd is dead or somthing
    I turn my compter off last night--and this morning the monitor can get a signal from the video card BUT ONLY BLACK PICTURE . I try different DVI cables, different monitors, the other DVI port, nothing works. At this point I assume my video card is fux0rzed, yet the fan still runs on it and everything seems to be ok BUT ITS NOT,but i get picture from a motherboard graphic :(
    DIED OVER NIGHT WHILE PC wos OFF HOW!?!?!?
  • 40 Answers
If u find a ? mark then first uninstall the driver by a right click and then choose uninstall after this try reinstall... this might work or else ur g force hardware problem
Posted on Jun 30, 2009
  • darshanks
    darshanks Jun 30, 2009
    then might be ur hardware problem
I have a motherboard with an Integrated ATI HD 4200. When I install my EVGA GeForce 8600GT the fan runs but the card itself is not detected in device manager or anything like that. I disabled the onboard...
You don't disable it from there. Reenable it again and do it right: you uninstall its drivers from Programs and you reboot twice; you install the new card and you connect the monitor to it; when the pc starts you go directly in the BIOS and you disable the onboard card from there; you reboot one more time and you install the drivers for the new card.
Feb 26, 2011 | Evga e-GeForce 8600GT, GeForce® 8600 GT, ...
I'm getting only a black screen ?
sounds like the monitor aint supporting the graphics card, do you see your boot menu when you turn on the pc, have you tried booting up in safe mode and removing drivers and restarting then installing drivers. try a differnt monitor, make sure your bios settings are corect for that card, hope these few things help
Nov 29, 2009 | ASUS GFORCE 8600GT PCIE 2PORT DVI HDTV TV...
Nvidia Geforce 8600GT no signal
Go back into the BIOS and re-enable the on board video card.
Mar 24, 2009 | Evga e-GeForce 8600GT, GeForce 8600 GT,...
No signal on monitor when card is seated
the problem occured probably because of a power shortage of motherboard battery malfunction, if your motherboard has an integrated graphics card you then need to enter setup and disable it or choose which graphis card your pc has to use but you have to do this while connected to the on-board vga slot as the other one won't be working, you will problably find the choice under the
'integrated periferals" menu in the setup menu, and to access it you have to press the "DEL" button when your pc starts-F10 in some devices-
Nov 29, 2008 | Evga e-GeForce 8600GT, GeForce 8600 GT,...
I want to upgrade Compaq Presario SR5410F with Video card GE FORCE 8600GT, 512 mb. What are the requirements of DDR Memory (Presently 1GIG AND Power Supply 200Watts). Please explain what to add and take...
To install the 8600GT, turn off your computer, unplug the power cable going to your power supply, remove the side panel of your case, remove the current video card and firmly push the 8600GT into your PCI-Express x16 slot. Now plug in your monitor to the video card’s ports, close up your case, plug in your power cable, and turn on your machine. In BIOS turn off the built-in video and enable the PCIe slot for use. Restart. Insert the included installation CD and follow the onscreen instructions. The power supply is small but should work as long as you have not added other items. The memory is adequate and does not matter as far as adding a video card is concerned. Some games may require more memory, however.
Oct 20, 2008 | Compaq Computers & Internet
Alienware computer
Please try connecting monitor to known working CPU and determine if problem is with CPU (Graphics card etc) or monitor.Signal cable can also be a problem.
Please rate solution and provide feedback.
Samir
Jun 09, 2008 | BenQ FP71E 17" LCD Monitor
Black screen no signal
replace the graphics card, ours was going black here and there the last few months then finally it didn't work at all, we just replaced it today and the new graphics card (ati) works fine.
Jun 07, 2008 | Evga e-GeForce 8600GT, GeForce 8600 GT,...
Did you fix your Compaq 1220?
Any time you have a orange light . The monitor or video card can be at fault. First check the monitor. Turn it on and see if it goes from green to amber. Check all monitor cable connections. to make sure the all 15 pins are there . If monitor displays a message that check video signal most likely video card is the problem. Make sure you have the cable connection plugged in the back of the computer into the video card. Usually a picture of a monitor. Then afterwards turn the monitor on first then the computer. If you do the other way around then the video card most likely will not engage.
May 07, 2008 | Compaq Presario 5000 PC Desktop
Monitor is blank when plugged into Nvidia Geforce 8600GT
is video card pluged in tell bios pci express video snaped down good
Jan 19, 2008 | Dell Dimension E520 PC Desktop
Video Game Consoles & Games Logo
43 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
