Question about Ricoh Aficio 1085 Laser Printer
While I am running richo aficio 1085 Pcl, It stops and show the code sc550. I try to switch the machine turn on and turn off alot of time but the result is the same, How can I do to remove this problem?
  • 162 Answers
Oil Supply/Cleaning Web End. Change this and
Press the following keys in sequence.
Total Clear key 1 0 7 and clear stop for more of 3 second to enter to service program mode, eter to 1902 - 1... and change the value to 0%.
shut down the machine and turn on.
Posted on Aug 28, 2009
  • Delfor Tomás Acosta Oct 18, 2009
    For that
    they visit this post… nothing costs to be thankful…
  • bcxprint Jul 14, 2011
    thanks for the info.. didn't remember the 1902-1 value change.. couldn't remove the code after changing the cleaning web.. now i have an auger problem however - sc592... im wondering do I need to clear the code on this issue after I clear the toner from the hopper?? thanks again...
    Mike
How to fix sc990 on richo 1085 copier
Have you done the PM? If not perform PM.
Feb 20, 2015 | Ricoh Aficio 1085 Laser Printer
Sc550
That service code SC550 normaly is a fuser web end error, you must replace the web and reset the % in 1.902 to "0". But i dont think the Ricoh aficio 450 have a fuser web. does this SC550 coming from your Aficio 450?
Sep 18, 2011 | Ricoh Aficio 450 Copier
I have a Nashua sc550 Aficio 1013. Its displaying error SC550. message displayed is "Functional problems, turn off main power switch then on again. If error reoccur, call service" Best regards
Your question is somewhat confusing as to the model. There is no Nashua SC550 as that seems to be the service code you have an issue with. There is a model 1013F but there is no SC550 code for that machine. That being said I will tell you what an SC550 code means on most all Ricoh, Gestetner,Nashuatec machines. The SC550 means your fuser oil/cleaning web life is over. The solution for this is to replace the web and then reset the counter which requires entry into the service mode. Both of these are going to require a service technician to complete.
Good Luck and Thank You for using Fixya.
Sep 03, 2010 | Ricoh Aficio 1013F Copier
Sc 491 for ricoh aficio 1085
sc491 on a Ricoh 1085 is a problem with the fan that cools the polygon mirror motor, in the laser unit. The problem might lie with the fan motor itself, or it might be another problem inside the laser unit. You could try replacing the fan (part #A2941965) but that may or may not fix the problem -- and you may not even be able to find a new fan anywhere, since the 1085 is so old. Ricoh stops producing new parts for old machines after a certain number of years.
The laser unit sits under the scanner bed... remove the platen glass and the laser covers and try cleaning the unit out with some compressed air. Then reboot the machine and see if the code clears up.
Jun 21, 2010 | Ricoh Aficio 1085 Laser Printer
Multifunction machine doesn't work
I think you mean "SC550"....all codes are 3 digits. If this is correct, it mean that the Fuser web has expired, and needs replacement, then and only then can the code be reset in service Mode. Call a tech.
Mar 12, 2009 | Ricoh Aficio MP1600SPF Copier
Use as a scanner .... How to ?
you must first connect scanner interface drive board
Jan 22, 2009 | Ricoh Aficio 1085 Laser Printer
Hiricho aficio 1085
you need to activate scan to folder feature, under system properties
Dec 08, 2008 | Office Equipment & Supplies
Copier problume.
return SP1-902-1 to 0. Then, the SC will
be cleared.
Sep 23, 2008 | Ricoh Aficio 1085 Laser Printer
Aficio 1060 - SC550
• Web end (requires replacement) fusing unit
• Web end sensor defective
Note: After replacing the web with a new
one, reset SP1902 001 to 0 to
release SC550.
Jun 28, 2008 | Quasar SP-3235 32" TV
Ricoh photocopier 1075 code sc541
Ok, its a firmware bug, but you should be able to reset it. Press clear modes, 1, 0, 7, and press and hold clear/stop. Press 1 for copy sp. Scroll down to 7, (data log) press 7. scroll to 7807, and reset it. exit all the way out, and recycle the power.
Mar 18, 2008 | Ricoh Aficio 1013F Copier
Ricoh Aficio 1085 Laser Printer Logo
321 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
